Kinugawa 25g turbo thread
Old Sep 17, 2013 | 05:59 PM
  #691
jaredh's Avatar
Originally Posted by Tom Stout
finally got my car finished on e85 with the 25g. I'm highly impressed with this turbo. absolutely a blast to drive. Big props to VIIIdriver and dmt tuning.
http://www.youtube.com/watch?v=bFLSr...ature=youtu.be
Nice power!
Old Sep 17, 2013 | 06:04 PM
  #692
WikdEvo's Avatar
Thank you. The car is an absolute blast to drive
Old Oct 8, 2013 | 02:36 AM
  #693
b00stah0lic's Avatar
I made 461/372 on 25psi with this turbo on e85.
Set up- Kinugawa turbo with 60-1 billet wheel and 2 bar wastegate actuator
1050cc injectors
255lph pump
innovative fmic w/ hard piping & APS 50/50 bov
megan o2 housing
3" exhaust
intake
Old Oct 8, 2013 | 02:48 AM
  #694
WikdEvo's Avatar
Time for some fuel upgrades and more boost.
Old Oct 8, 2013 | 03:51 AM
  #695
94AWDcoupe's Avatar
1050cc injectors
255lph pump
megan o2 housing
3" exhaust
intake
60-1 wheels is not same as 25g.
25g = 60.2/78mm
60-1= 59/76mm
I would think the 60-1 is a much better choice to mate to the 6SL2 exhaust wheel. why did you stop at 25psi?
Old Oct 8, 2013 | 03:52 AM
  #696
KurtVK's Avatar
Nice power
Old Oct 8, 2013 | 03:58 AM
  #697
94AWDcoupe's Avatar
very good results. do we get to see curve? how many miles you have on yours now?
Old Oct 8, 2013 | 04:02 AM
  #698
WikdEvo's Avatar
I'm going to assume he was out of fuel.
With a walbro 450 and fic 1250 I'm at 98% idc in evoscan at 32#. That netted me 575/434 on e85
Old Oct 9, 2013 | 08:16 AM
  #699
manden's Avatar
I have read the entire thread, and im very pleased with having orderen an watercooled kinugawa 25g 10cm with internal wg and v-band exit now
Old Oct 12, 2013 | 10:56 PM
  #700
25g = 60.2/78mm
60-1= 59/76mm
Need more fuel. I am also going to get head studs and build the head before turning it up all the way. It pulls really hard for what it is, I am happy with it.
Old Oct 14, 2013 | 02:44 AM
  #701
damien666's Avatar
Urgent help needed if possibile I purchased a Kinugawa TD06-sl2r-20g with adjustable wastegate actuator bought it 2nd hand, installed it with 1.2bar spring but cant get it too boost over 14psi when road testing bench tested the actuator and was sweet 1.2bar but driving it wont go over 14psi boost???? tried buying new actuatior and same thing happened so cant be actuator what could it be its stressing me big time!!! only thing holding me off the dyno. Damaged wheel?? does have fair b it of play is that normal beforte oil pressure is built up? alot more play then std evo turbos.
SOrry about taking over thread mate just thought u could maybe help me out.
Old Oct 14, 2013 | 09:21 AM
  #702
evoiao's Avatar
The wg are notourious for underperforming.
My 2 bar Never ever hit 2 bars.
I'd suggest swapping out the kinugawa wg with maybe a forge or forced performance waste gate.
Old Oct 15, 2013 | 07:08 AM
  #703
VIIIdriver's Avatar
Have you tried running the actuator with no boost source to it just to check if it will give you more boost? how about preloading the wg actuator arm?
Old Oct 15, 2013 | 09:58 AM
  #704
damien666's Avatar
Hey mate yes have bench tested it previously and gets to were it should be so cant understand why doesnt boost properly when installed
Old Oct 16, 2013 | 03:25 AM
  #705
damien666's Avatar
Had turbo off today and it appears that the flapper is not sealing properly i can press it down and move sideward by hand only slughtly but enough to create issues id say also theres fair bit of play thrust as can prettymuch make the wheel hit housing, so will get a kinugawa rebuild kit and maybe use my standard exhaust housing?
