New stock frame turbo options from Blouch
Ernest, if my HKS works, we can work out something with that 10.2 housing. the only thing is i think it has a crack. that wasn't going to matter for me building the 71HTA, but i'm 99.9% sure FP won't want to mess with it.
Doesn't a little turbo have to work extra hard to try to hold boost on a stroker motor? Boost really isn't what one can use to determine if you are overspinning the snail. I would prefer to look at airflow and by the numbers it looks like he may have been making that gerbil run its **** off to produce those torque numbers. My guess is a bigger turbo would have been a much better choice for an output demand like that.
Talking with Aaron at ER, when we did our fist pull and duty cycle was flat he said where tq starts dipping is where we're really running out of turbo. Be it too much backpressure, not large enough compressor, or a combo. Mine really fell off around 5500rpms with the 1.0XTR. I don't want boost spikes and just wanted to hold 25-26psi as long as possible so we ramped up duty cycle on the top end. I think I'm around 65% and ramp to 90% from 5500rpm to 7500rpm.
The gate flapper shaft on mine creep'd (surprise!) so I have it all disassembled while I try to figure out a way to repair it. HKS USA was all surprised about the failure mode and said they'd have to get in touch with Japan to see how to proceed. FP didn't want to machine my spare 10.5 housing for it which I thought was a bummer. Now I'm stuck trying to pull the shaft bearing out to re-weld the assembly. PITFA.
So what happened to your 7460?
My car made very little power before. I thought it was the turbo, but it was reaching 25-27psi, so that shouldn't be the issue. I was gonna swap on the one I have for sale, but decided to do an OEM rebuild on the engine.
For future reference, can you let me know if you find a fix? Just in case....
just got done reading this whole threat. My tuner was telling me about blouch turbos and how great they are. Now, my question is. Should i go with bloush 2.0 or should i go with my old option FP green or red? My goal is around 450-500. I know FP is been around for years and all i hear is good reviews about them.
chad if you reading this will a bbk full handle my setup without any over spin? last setup with e85 is 500hp.
I am in the market for a new turbo fp red or anything that can handle my setup. I am done with blouch turbo's it left a bad taste in mouth if you know what I mean.
