New stock frame turbo options from Blouch
Old Oct 9, 2015 | 11:58 AM
  #346
kinein's Avatar
that is the bbk full I am looking at. and yes I know blouch made the turbos for cbrd.
Old Oct 9, 2015 | 11:59 AM
  #347
kinein's Avatar
not running a stock block
2.3 stroker with all the bells and whistles
Old Oct 9, 2015 | 12:01 PM
  #348
kinein's Avatar
2.3 stroker
100mm Eagle crank
Manley rods and pistons 8.5:1 cr
Borla exhaust manifold*
70mm throttle body
Invidia 02
3in tb exhaust*
Gsc s2 cams
Rc 1200cc injectors
Sparktech non cdi
Ams 3.6 intercooler*
Injen intake,*
Blouch 1.0 xt turbo ported (piece of sh**)
Walbro 255
Arp studs
Acl bearings
Might be missing something on that list
  #349
LetsGetThisDone's Avatar
Idk why you would be concerned about it being a "BBK". Chad has confirmed that the Blouch "variants" are basically identical to the former BBK line.
Old Oct 9, 2015 | 12:20 PM
  #350
CBRD's Avatar
few mm changes on the inducer if I recall!
cb
Old Oct 9, 2015 | 03:50 PM
  #351
kinein's Avatar
Looking for fp red or anything else comparable
Old Oct 9, 2015 | 04:20 PM
  #352
A blouch 2.0...lol
I think your bad experience is isolated, and possibly not Blouch's fault. Bearing failure is indicative of overspeed or poor lubrication. Improper assembly (oil clearances, imbalance, etc) would lead to a failure much more quickly then what you experienced.
Old Oct 9, 2015 | 05:27 PM
  #353
mrfred's Avatar
The BBK Full is barely a 500 whp turbo. It takes a kill mode tune on E85 to hit it, although it might not be quite so hard on a 2.3L. Its a lot happier sitting at 480 whp.
Old Oct 9, 2015 | 08:25 PM
  #354
Dallas J's Avatar
Veteran: Army
In reality, 500hp is just a number to strain for on a BBK Full/1.0xtr. Mid range will be the same but you'll be fighting the fall off up top to achieve that number. Fighting fall off leads to over spinning and reduced turbo life.
The FP Red, 2.0 XTR, or maybe bw7163 is going to be a better solution if 500hp is a realistic goal.
Old Oct 9, 2015 | 09:39 PM
  #355
kinein's Avatar
Nothing else out there comparable to the red besides bkouch?
Old Oct 9, 2015 | 10:38 PM
  #356
Not in a "stock frame" and you still will be hard pressed to find an MHI housing red..
Old Oct 9, 2015 | 10:52 PM
  #357
kaj's Avatar
kaj
FWIW i'd have faith in a properly-sized Blouch turbo. i have no reason to doubt they are the same as the old BBKs.
an MHI FP Red is going to be ridiculously hard to find.
they are the only option i see for those of us living in CA.
Old Oct 9, 2015 | 11:08 PM
  #358
e_kobz's Avatar
Are you refering to the FP Reds with the 64mm comressor cover?
Old Oct 10, 2015 | 03:36 AM
  #359
Benja's Avatar
Originally Posted by kinein
2.3 stroker
100mm Eagle crank
70mm throttle body
Invidia 02
3in tb exhaust*
Gsc s2 cams
Rc 1200cc injectors
Sparktech non cdi
Injen intake,*
Walbro 255
Arp studs
Acl bearings
Yes it will however very maxed out.
I tuned a very similar setup to yours with BBK full, stock throttle, FullRace manifold.
Went ~500whp at 24psi.
No more power obtained with more boost.
Old Oct 10, 2015 | 08:36 AM
  #360
Dallas J's Avatar
Veteran: Army
Neither do I. Though I'm using a BB version, my 1.0xtr has been great.
