New stock frame turbo options from Blouch
Old Sep 9, 2015 | 09:00 AM
  #271
kinein's Avatar
Dont buy blouch turbos they are crap. Maybe that is why cbrd stop working with them. I have to find a new turbo and it wont be from blouch. They gave me excuses for what went wrong but obviously they did not see it was on them. I was told the hotside was put together wrong.which wasn't allowing the wastegate close all the way. So therefore it is my fault and it isn't under warranty. I open the box and installed it. Soooooo it could've been ma performance when they ported the turbo. Who knows now i am out 1800. So chad what turbos you have for sale?
Old Sep 9, 2015 | 09:20 AM
  #272
LetsGetThisDone's Avatar
I would call MAP since they ported it.
That still doesn't make sense. The waste gate not closing would make it spool slow, and you would notice it..
Old Sep 9, 2015 | 09:55 AM
  #273
mrfred's Avatar
Definitely falls on MAPerformance. Question is whether you documented the condition of the turbo as it arrived from MAP. That might be a key factor in dealing with MAP.
Old Sep 9, 2015 | 10:15 AM
  #274
honda-guy's Avatar
i don't get how the hotside wasn't put on correctly. there's a pin to line up the housing to the CHRA. if the pin is not line up, it wouldn't seat correctly and would leak. also if it was clocked wrong, the compressor housing would be pointed in wrong location and the outlet would be hard to get on the LIC. sounds like they just making up excuse to void warranty.
crbd has badass EFR kits now.
Old Sep 9, 2015 | 10:52 AM
  #275
Erik@MIL.SPEC's Avatar
All I know about Blouch is from reading on the forums. But reading between the lines it seems that they are a pain to deal with, have little to no forum presence, and don't stand behind their products when something goes wrong.
Also, how the heck do you install an MHI hotside incorrectly? If Blouch was smart, they'd have some kind of forum presence because a post like that can kill sales.
Old Sep 9, 2015 | 11:17 AM
  #276
nemsin's Avatar
Is your hotside still good? Maybe you could you use it with a 71HTA chra? http://www.forcedperformance.net/mer...Category_Code=
Old Sep 9, 2015 | 11:32 AM
  #277
e_kobz's Avatar
71hta FTW!!!
Old Sep 9, 2015 | 11:42 AM
  #278
Can't. The blouch 1.0 has a bigger turbine wheel for which the turbine housing is machined..
Old Sep 9, 2015 | 12:39 PM
  #279
mrfred's Avatar
The clamp may not have been sufficiently tight, allowing the hotside to wiggle, come loose, and bend the pin or wallow the housing. Eventually it would contact the turbine wheel. I've seen an example of it happening, so I know its possible.
Old Sep 9, 2015 | 01:40 PM
  #280
evo8426's Avatar
FP even recommends to make sure the band clamp is tightened prior to installing. It's unfortunate but quite possibly the reason.
Old Sep 9, 2015 | 03:28 PM
  #281
kaj's Avatar
kaj
horrible luck, Ernest. sorry to see this happen.
Old Sep 9, 2015 | 04:55 PM
  #282
jaime8754's Avatar
those are nice number thank you cali for the awesome 91oct
What is your mod list? That is my power goal for my evo 9. im at 345whp
Old Sep 9, 2015 | 11:01 PM
  #283
kinein's Avatar
2.3 stroker
100mm Eagle crank
Manley rods and pistons 8.5:1 cr
Borla exhaust manifold*
70mm throttle body
Invidia 02
3in tb exhaust*
Gsc s2 cams
Rc 1200cc injectors
Sparktech non cdi
Ams 3.6 intercooler*
Injen intake,*
Blouch 1.0 xt turbo ported
Walbro 255
Arp studs
Acl bearings
Might be missing something on that list
Old Sep 9, 2015 | 11:04 PM
  #284
kinein's Avatar
Talk to Aaron at MAP he is going to look into it. They were the last to have it apart.
Old Sep 10, 2015 | 06:41 AM
  #285
CBRD's Avatar
I have some used BBK turbine housings here in good shape if ever needed- should be same turbine-
Blouch is a good company- we had our ups and downs like any company- but they are a manufacturer- and do not have a strong web presence- that is what CBRD brought to the table on our partnership-
Give everyone a chance to work through it!
cb
