View Poll Results: Warranty claim problems/ No claim problems.
Submitted claim, wasn't honored or had problems
129
58.90%
Submitted claim, no problems getting it fixed.
93
42.47%
Multiple Choice Poll. Voters: 219. You may not vote on this poll
Warranty Issues <Mega Merge>
Old Nov 19, 2006 | 03:02 PM
  #3196
Evolution2003's Avatar
Already bedded correctly them and they are the slotted ones
Old Nov 19, 2006 | 03:07 PM
  #3197
Czubaka's Avatar
Do it again and see if that fixes your problem. It's possible to create uneven pad deposits at anytime, even after properly bedding in your pads. Especially if you come to a complete stop with the brakes cooking.
Old Nov 19, 2006 | 06:12 PM
  #3198
kapolani's Avatar
Have you checked your tires?
Have them balanced.
I've had the Stoptech StageII upgrade for a year now. I'm really hard on my brakes at the track etc.
Old Nov 19, 2006 | 06:17 PM
  #3199
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by Czubaka
Do Stoptech's pad bed-in procedure. It's most likely pad deposits on the rotor.
+1. If you've done as you say, no way the rotors are warped.
Old Nov 19, 2006 | 06:24 PM
  #3200
EvoDan2004's Avatar
hey guys who are running stoptech slotted rotors. did you notice if there lighter then the stock rotor???????
Old Nov 19, 2006 | 06:42 PM
  #3201
Actually i did it again on my way home from work tonight again on a long side road and i think that took care of the problem
Thanks I really should have thought of doing that again
Blinded by anger....lol
Old Nov 19, 2006 | 06:58 PM
  #3202
Czubaka's Avatar
No problem. I have to do it on a regular basis myself (stock brakes).
Old Nov 20, 2006 | 04:42 PM
  #3203
EvoDan2004's Avatar
anyone??????????
Old Nov 20, 2006 | 05:25 PM
  #3204
caligula's Avatar
i didn't weight mine,but by the feeling i think they have the same weight.Dan
Old Nov 20, 2006 | 05:42 PM
  #3205
anyone??????????
I have a different brand and they weighed about the same. Unless your using a two piece, I wouldn't think you could save much weight.
Old Nov 20, 2006 | 06:16 PM
  #3206
EvoDan2004's Avatar
thanks to the 2 above poster's. i dont mind the same weight as long as it is better then stock and not heavyer. thanks again
Old Nov 21, 2006 | 08:41 AM
  #3207
StopTech's Avatar
Our 1 peice stock repalcement EVO rotors weigh 22 pounds each while our 332mm BBK 2 peice rotors weigh just over 17 pounds each. That comes out to about 10 pounds of reduced rotating mass on our front only kit vs stock.
Old Nov 21, 2006 | 02:48 PM
  #3208
EvoDan2004's Avatar
ok but how much does a stock rotor weigh??? lighter or heavyer then the 1 peice rotor
Old Nov 21, 2006 | 03:00 PM
  #3209
Greg Haymann's Avatar
What may seem like a warped rotor could be new pad build-up creating the same effect.Stoptec used supply axxis brand pads which do not work so well in the northeast.Temperature being the issue,street driving around here doesn't produce enough heat therefore blotching pad material on top of the rotor.Stoptec rents very aggressive pads that you use for ~1 hour to clean off the high spots.
Old Nov 22, 2006 | 10:39 AM
  #3210
StopTech's Avatar
Our stock replacements should weigh more or less the same as stock
