random evo 9 motor question
Old May 9, 2011 | 11:37 PM
svt_lightning01's Avatar
Hey guys i have an evo 8 mr. This may be a silly question but i have a spare evo 9 mivec motor haha.... Anyways i have it incase my motor goes kaboom. First question, would that be a direct swap? I know they are basically the same other than the mivec. The spare motor doesn't have the turbo. is an ECU swap required or anything IF and hopefully never that i have to change it out? Second question, is there anything off that 9 motor that i can put on the 8 motor to up the performance threshold? Are the injectors or anything bigger?? Thanks in advance.
Old May 10, 2011 | 12:09 AM
awdordie's Avatar
Ecu will def have to be swapped. The injectors are the same only other main difference I can think of is the ix turbo which is larger. That's really the only thing you could swap to gain power.
Old May 10, 2011 | 12:38 AM
thats what i figured just thought i would ask to make sure i wasn't missing out on power!!!
Old May 10, 2011 | 05:58 AM
JakeTheVIII's Avatar
You'll need the IX ECU and engine wiring harness to run the evo 9 engine/mivec. You could use the block though as a spare if you wanted to keep it as an evo 8 engine.
Old May 10, 2011 | 06:14 AM
spooldursti's Avatar
Isnt there a mivec oil port in the block though that you'd have to block-off somehow?
Old May 10, 2011 | 07:02 AM
Yea back of the block, you can just plug that feed hole.
Old May 10, 2011 | 07:44 AM
Really? I thought it was a port on top of the block itself that flows down from the head. Do you happen to have a pic of it by chance? I just ask bc I also have a evo 9 block Im looking to build with an evo 8 head
Old May 11, 2011 | 04:38 AM
I'm not sure about that. Check these threads out and you can see pictures of where the VIII block is being drilled out to accept the banjo fitting for the mivec oil feed. I thought that the oil pressure was produced from the block, and flows to the mivec oil sensor unit thing. Not sure about it flowing down from the head, I don't think that's right.
https://www.evolutionm.net/forums/en...gine-swap.html
https://www.evolutionm.net/forums/ev...k-ix-head.html
This too: https://www.evolutionm.net/forums/ev...k-build-9.html
Old May 11, 2011 | 06:59 AM
Thanks for the links. I figured it out. I wasn't sure about the block oil port thats just what I heard by word of mouth. nontheless thanks alot!
Old May 11, 2011 | 10:06 AM
testa corse's Avatar
that's the best thing you can do
shadow_X
May 4, 2013 09:49 PM
Tmosser
17
Mar 3, 2013 08:18 PM
Evokid03
Mar 25, 2011 08:53 PM
overlord2kx
Nov 30, 2010 08:55 AM
KenRed
Aug 26, 2009 10:21 PM
