Walbro 450 lph e85 fuel pump diy evo 8/9
Old Oct 1, 2013 | 12:35 PM
  #61
nikg's Avatar
Thanks for the write up! Made it really simple.
Old Nov 26, 2013 | 10:52 AM
  #62
IFuXwiTuZ's Avatar
to op thank you very much for this attempt / write up.
David bushur was actually arguing with someone about doing this...but i guess his argument proved to be pointless.
Old Nov 26, 2013 | 01:54 PM
  #63
xXANCHORMONXx's Avatar
No problem!
Old Nov 26, 2013 | 08:37 PM
  #64
OsideEVO's Avatar
I notice few ppl are running 450 pump with stock fpr, what is required to do that? drill the return if the pressure to high?
Old Nov 29, 2013 | 10:38 PM
  #65
WikdEvo's Avatar
nothing is required. I am running a single 450 with a modded stock hangar and 2150 cc injectors. The only mod needed is the cutting of the hangar and a tune lol.. good luck.
Old Dec 3, 2013 | 10:20 PM
  #66
OsideEVO's Avatar
Are you running your stock wires or are you rewire. My tuner said I need to be rewire to get the flow I need for my setup.
Old Dec 4, 2013 | 10:26 AM
  #67
evoiao's Avatar
Originally Posted by OsideEVO
Are you running your stock wires or are you rewsire. My tuner said I need to be rewire to get the flow I need for my setup.
What tom said is exactly how I'm set up...just different injectors.
Old Dec 4, 2013 | 04:48 PM
  #68
OsideEVO's Avatar
Thank. Im guessing you're still using the stock wiring ? Rewire ?
Old Dec 7, 2013 | 09:51 AM
  #69
WikdEvo's Avatar
stock wiring. If you rewire you will definitely need an afpr to set the base pressure. For others that did this. did you drill out the siphon? if so, what size bit?
Old Dec 7, 2013 | 01:27 PM
  #70
detroit pistins's Avatar
I didn't need to drill anything when I installed my gasoline version. I have pics in my 4sale thread incase anyone is interested.
cheers
https://www.evolutionm.net/forums/sa...rely-used.html
Old Dec 8, 2013 | 08:15 AM
  #71
evoiao's Avatar
Stock wire no drilling
Justed followed the exact steps in the thread... exactly. ..as shown.
No fapr no syphion drilling
Simple install.
Old Dec 8, 2013 | 09:30 AM
  #72
OsideEVO's Avatar
Thanks for all the info guys.... my tuner said if I want my fuel pump to support my power goal on e85 I will need to rewire it.. what kinda of power are you guys making on e85 w stock wiring...my power goal is 575-600hp on fic bluemax 1550/6265 turbo
Old Dec 8, 2013 | 10:25 AM
  #73
WikdEvo's Avatar
I made 575 on stock wiring in e85
Old Jan 9, 2014 | 04:42 AM
  #74
rick1024's Avatar
601 on a buschur double pumper and stock wiring
Old Jan 9, 2014 | 07:23 AM
  #75
WikdEvo's Avatar
625/500 on a 450 rewired with stock fpr and e85
