View Poll Results: EVO X Transmission Problem POLL
Notchy, grinding, or difficult to engage gears (all the time)
689
40.08%
Notchy, grinding, or difficult to engage gears (only when car is cold)
646
37.58%
Difficult to engage Reverse gear (cold or warm)
146
8.49%
No problems at all
238
13.85%
Voters: 1719. You may not vote on this poll
The official Evo X notchy/grinding transmission thread
Old Feb 26, 2010 | 12:18 AM
  #571
FFRGTM's Avatar
Well today I think I finally figured it out... no grind even with low temps (20F). It has to do with the rev hang... on the one two shift just pull into neutral and WAIT...wait... wait for it.... then it will drop right into second... same with third but it's not as bad. We really need to disable this stupid rev hang... rev matching and even just regular shifting is very hard considering how light the oem flywheel is.
Old Mar 2, 2010 | 07:53 AM
  #572
Toxin's Avatar
I would think that rev hang actually happens because of a heavy factory flywheel... More rotating mass takes longer to stop...
Old Mar 3, 2010 | 05:02 AM
  #573
JiNSOO619's Avatar
Yeah, seems like it'd be from a heavier flywheel. I don't drive a manual, but I did test out the Evo X GSR. It took a while for the revs to go back to idle.
This maybe a dumb question, but does the fact that the stock tune makes the engine run richer than it should.. affect the revs going back down to idle? Like make it slower, 'cause when I hear running richer.. I'm thinking more fuel is being added to the compression ratio??? Maybe I need a lesson on what running rich means too, lol.
Old Mar 3, 2010 | 08:16 PM
  #574
FFRGTM's Avatar
The oem flywheel is extremely lightweight. Those who have put in aftermarket flywheels still report the rev hang does not change. This is a programmed event, I know the new civic si has the exact same problem which cobb recently fixed through accessport.
Old Mar 3, 2010 | 09:11 PM
  #575
Djstorm100's Avatar
amsoil / thread
Old Mar 4, 2010 | 09:52 AM
  #576
LRM1981's Avatar
Originally Posted by Djstorm100
amsoil / thread
This didn't help fix the issue for me.
Old Mar 4, 2010 | 10:35 AM
  #577
tsitalon1's Avatar
I am going to try to find a correlation between the shifter play that all Evo X cars seem to have and the notchy shifting...
Shep stated my Tranny shifted great on the bench, something's gotta be up with the shifter....
Old Mar 7, 2010 | 03:15 PM
  #578
Bear.914's Avatar
2008 evo x gsr
When its cold its hard to get into 1st or reverse also 2nd gear gets hard to go into and feels like ima brake it lol...
Old Mar 7, 2010 | 03:16 PM
  #579
Bear.914's Avatar
2008 evo x gsr
Old Mar 14, 2010 | 01:15 AM
  #580
ZEKE010's Avatar
just got a 2010 X
i have the same damn problem. Its been notchy/grinding since day one.
i have about 500 miles on it now. going to try BG syncro shift and Motul Gear300
see if either one will help any.
Old Mar 14, 2010 | 01:16 AM
  #581
07subie's Avatar
I'm having the same problem. When first start in the morning. Cold start. 1st is hard to get into and resverse. My 1st to 2nd is bad and 2nd to 3rd. Any thing to help with this?
Old Mar 14, 2010 | 01:19 AM
  #582
07subie's Avatar
What helps in the morning to reverse is pop it in 2nd then 3rd then reverse. Goes in smooth. But popping in to 2nd rough.
Old Mar 14, 2010 | 09:17 AM
  #583
LRM1981's Avatar
Originally Posted by ZEKE010
just got a 2010 X
I put Motul Gear 300 in my car at 1000 miles but it didn't really help much at all. The best thing I've done to improve the shifting was adding a weighted shift knob.
Old Mar 14, 2010 | 10:12 AM
  #584
Djstorm100's Avatar
there is no tranmission that is smooth in every gear. Not even 100k+ stop your whining learn the sweet spot.
Old Mar 14, 2010 | 10:51 AM
  #585
aftershock141's Avatar
Exactly.
