View Poll Results: EVO X Transmission Problem POLL
Notchy, grinding, or difficult to engage gears (all the time)
689
40.08%
Notchy, grinding, or difficult to engage gears (only when car is cold)
646
37.58%
Difficult to engage Reverse gear (cold or warm)
146
8.49%
No problems at all
238
13.85%
Voters: 1719. You may not vote on this poll
The official Evo X notchy/grinding transmission thread
Old Apr 5, 2010 | 09:16 AM
  #616
Jblade's Avatar
Originally Posted by pstl_pete
I have had AWFUL notchyness and grinding into third gear. Was hoping my first track day would loosen things up but the grind it still there.
At the track my revmatched downshifts were crunchy. I hope it gets a bit better when I switch out to MTL.
Is that Redline MTL you're referring to?
Old Apr 7, 2010 | 09:28 PM
  #617
TruSlide's Avatar
Notchy. very noticeable. Anyone try to replace the bushing and the shifter?
Old Apr 9, 2010 | 06:57 PM
  #618
Nauticabri's Avatar
It was cold this morning here about 35, 40ish in my garage and I started it up and it didnt want to go into reverse at all, and she only hd 100 miles on her.
Old Apr 9, 2010 | 11:01 PM
  #619
Djstorm100's Avatar
Evo doesnt have a deicated reverse gear. So this is actually normal. I put the car in 1st then R or 2nd to R
Old Apr 10, 2010 | 09:15 AM
  #620
Golden's Avatar
To get mine in reverse, I just let the clutch out, then push it back in. This gets the fly wheel moving a bit. It will click right into gear after doing that.
Old Apr 10, 2010 | 09:54 AM
  #621
monkey_187's Avatar
Originally Posted by ZEKE010
got the syncroshift II but havent had time to try it yet.
Didi you get a chance to change to this fluid? I would like to know how the tranny is feeling after using it.
Old Apr 10, 2010 | 10:39 PM
  #622
junetojudeto's Avatar
iv had the car for 6k and its still notchy and grinding
Old Apr 10, 2010 | 11:48 PM
  #623
futurevowner's Avatar
I just picked up my car today, and driving home i noticed that upshifting sometimes if i didnt wait a second in between gears, the revs would hang and the clutch would grab it, was really pissing me off, is it possible im just not used to the throttle and it stays open a second after i let off the gas?
Could be i just wasnt used to the car yet but it really pissed me off since im trying to baby this clutch for now
Also is there a type of clutch delay valve in these cars? i think that would help a lot with smoothness?
Old Apr 11, 2010 | 10:45 AM
  #624
CatalystGod's Avatar
there's already a clutch pill that ensures the clutch doesn't engage abruptly. Its also the reason for the high engaging point on the pedal. Search for more on the forums if this is what you're looking for.
Old Apr 11, 2010 | 11:21 AM
  #625
So basically this clutch pill works as a delay valve?
If its anything like the bmw delay valve, it will make a huge difference.
Old Apr 22, 2010 | 05:01 AM
  #626
1800bigk's Avatar
Just got a new evo and the gears grind so bad that if I didn't know about this post I would probably take it in for repairs, but seems like its normal. Other than the grinding / sloppy gear box (coming from hondas) the car is amazing.
Old Apr 22, 2010 | 07:32 AM
  #627
Djstorm100's Avatar
yea it does too mine out. same engagement point everytime all the time.
Old Apr 24, 2010 | 06:14 PM
  #628
MAX EVO's Avatar
I've had my EVO for about three months, and my first to second is notchy only when the engine is still cool and not up to temp.
Old Apr 24, 2010 | 07:53 PM
  #629
Hassan!'s Avatar
Today at auto cross I had problem shifting from first to second gear on high rpm it seems the clutch don't work on higher rpm
Old May 1, 2010 | 12:34 PM
  #630
brtecson's Avatar
I think I'm going to take my x in to dealer to have them look at it, mine i abnormally grindy/notchy
