Sponsored by:
Sponsored by: CARiD
Lancer Evolution X News, Info, Pics, etc... | [ALL THREADS MERGED]
Old Feb 1, 2007 | 12:57 PM
  #6901
ApexVIII's Avatar
Vtek!!!!!!1
Old Feb 1, 2007 | 01:31 PM
  #6902
derangedazn's Avatar
dual exhaust and 4B11T instead of 4G63T
Or could it be a Warranty that they will actually honor?
Old Feb 1, 2007 | 02:49 PM
  #6903
Vigo's Avatar
If you're the type that does not like to mod much this will the Evo for you. It will take some time for the aftermarket to do some research and development to extract the same levels of power in the MB11 as the 4G63T. There has been a few examples of aluminum blocks producing high amounts of power like the SR20DET, EJ257, and the VQ35DE.
As for the SR20DET it will hold a lot of power stock like the 4G63T even though it's a full aluminum engine.
For the EJ257 you will need to upgrade it to be fully closed decked to handle more power.
With VQ35DE you will have to upgrade the pistons and rods and put oil squirters.
In my opinion, as time goes by companies will come out with a closed deck upgrade for the 4B11T so it can hold more power.
Old Feb 1, 2007 | 02:55 PM
  #6904
articfury's Avatar
Originally Posted by BrrrPshBrrr
It's got swaybars. It was supposed to come with ARC. Active Roll Control.
How do I know? In a pic of the underneath of the rear,there is clearly a swaybar.
You are making 2 assumptions:
1) The Prototype X show car (which is not necessarily one of the prototypes that have been running around the ‘Ring) has all the things on it that the Production car will have.
2) The roll control system doesn't have "sway bar" end links.
I'll find a link to the specific pic,and provide the quote regarding ARC and the Evo X. I'll also find some info detailing ARC. Basically it's a system that diagonally connects the shocks together,so shock pressure rises instantly through displacement of the shock fluid.
Again you are assuming what type of roll control system Mitsu will use.
The company that Mitsubishi has a long history in the Dakar with, which is also the company that Citroen used for their WRC car, offers several versions of roll control systems. One of which still uses what look like sway bar end links - http://www.kinetic.au.com/rfs.html Of note in the pictures that we have all seen of the rear underside of the Proto X is that we can’t see the center section of the bars, therefore we can’t tell if they have an RFS style decoupler.
Here's the quote regarding the existence of the system on the prototype:
source: http://info.detnews.com/autosinsider...x.cfm?id=22793
Article regarding RS4 with a form of ARC:
http://cars.about.com/od/audi/fr/ag_07_audi_rs4.htm
Your first link doesn’t specifically refer to the show car. Instead it references the prototypes that have been running around the test tracks.
Your second link, while interesting because of the subject, doesn’t necessarily apply to whether the Evo X will have roll control.
This is the system that I understood the Evo X to have. There are other versions of Active Roll Control,including Semi-Active roll control. Mitsu had a version of it in a Dakar Montero/Pajero. It was banned. Only mechanical systems with swaybars were legal from then on. The semi-active version uses swaybars in conjunction with actuators that couple and decouple swaybars and/or increase/decrease pressure in the shocks. At any rate I think an Evo would only be deserving to have the full-on active system-as high tech as an Evo should be.
Here you discuss the type of system that would explain both Mitsus use of sway bar end links on the Proto X and still claiming roll control, but you dismiss the simple explanation.
Kinetix’s most advance system is still passive. If RFS was good enough for the all-conquering Citroen Xsara WRC car, I’m pretty sure it’s high tech enough for the Evo X.
Everyone seems to be looking for something to post about in this forum without having anything new to really discuss.
D
Old Feb 1, 2007 | 03:47 PM
  #6905
JondemandSales's Avatar
Very nice write up. Goes into better detail than most reviews I have seen
Old Feb 1, 2007 | 04:19 PM
  #6906
illmatic's Avatar
very interesting...
Old Feb 1, 2007 | 05:17 PM
  #6907
koffebean00's Avatar
Originally Posted by WickedIXMR
Hey whats up? What kind of bike do you have i just got an r6
I had an 04' GSXR 600 that I sold to my brother-in-law. I want a new GSXR 1000 and my wife wants a GSXR 600. We'll probably wait till spring to get new ones.
Old Feb 1, 2007 | 05:30 PM
  #6908
EvoTio's Avatar
Nice find. This is the best write up on the X that I've seen. I didn't know that the new 2.0 will have MIVEC controlling both cams instead of just one cam like the IX. I am very interested in the new clutchless transmission also. It will be nice to test drive one when they are finally released to the public. I may end up giving up my VIII for a X.
Old Feb 1, 2007 | 07:52 PM
  #6909
leogsx97's Avatar
Super light 4L Twin Turbo V8 and 600HP
Old Feb 1, 2007 | 07:56 PM
  #6910
Sap12687's Avatar
Spinners
Old Feb 1, 2007 | 08:05 PM
  #6911
si_eater's Avatar
undercar neons and around the plates
Old Feb 1, 2007 | 08:31 PM
  #6912
silex's Avatar
You guys and wanting the newest and greatest technological drivetrain available; now that is over-rated. Let's take S-AYC for example. USDM Evos never got it and who cares? Mainly it's the people who daily drive their cars alot. It's awesome technology don't get me wrong, but for a modded evo, it's just another electronic hurdle that can be fixed with mechanical parts like a beefier rear sway bar. Of course I'm referring to lessening the corner entry understeer by creating the neutral handling that everyone has grown to love.
Old Feb 1, 2007 | 08:46 PM
  #6913
Shwerp's Avatar
Are you looking for the $50k option or what? I'm sure if you are looking at the X but you want a more expensive car you could just pay more for it when you go to the dealer......
Anyways, specs released on the IS-F say it will have around 400hp but still have a 0-60 below 4.9. Must be a heavy beast. I highly doubt the X will have 400 hp, but I have a sneaky suspicion that it will still be faster then the IS-F.
I don't want to come off sounding like an a$$ but I'm just not sure that the X will be in the same class as some of the cars you listed. We will see though.....
Old Feb 1, 2007 | 10:11 PM
  #6914
evo150's Avatar
ill end up getting one in '09, that way they have all the "bugs" worked out of the car, especially the engine
Old Feb 2, 2007 | 03:51 AM
  #6915
Icon's Avatar
so they really having a optional 6 speed tranny for the purist?
