Sponsored by:
Sponsored by: CARiD
Lancer Evolution X News, Info, Pics, etc... | [ALL THREADS MERGED]
Old Mar 12, 2007 | 08:11 PM
  #7591
Mitchubishievo's Avatar
I like the interior...but I'm doing that to my IX anyways .
Old Mar 12, 2007 | 08:47 PM
  #7592
Nissaka's Avatar
Originally Posted by Kordyte
The styling on it will grow on me, but I still won't buy one. Maybe as a DD one day. Like I said, I'll wait for the XII.
Heh, by the time that comes out maybe I will be able to afford one. I guess I am in the same boat.
Anyway I agree with a lot of the others, at first I hated how it looked but its starting to grow on me. Plus power is always sexy so if its fast it will look hotter in my eye!
Old Mar 12, 2007 | 08:50 PM
  #7593
Kordyte's Avatar
haha Miitch... R U 4 Serious? You had the IX interior in the VIII, now you'll have a X interior in the IX? Sounds cool, actually... but I'm not that baller.
Old Mar 12, 2007 | 08:57 PM
  #7594
Tim893's Avatar
i think the evo X lookz great. waiting for it to come out
Old Mar 12, 2007 | 09:03 PM
  #7595
SoR's Avatar
SoR
If that's how it'll look I don't like it but I'll wait till I see one on the street before making any final decisions
Old Mar 12, 2007 | 09:25 PM
  #7596
SDRfirmIX's Avatar
im lovin this evo thumbs up
Old Mar 12, 2007 | 10:40 PM
  #7597
Talonboost's Avatar
The new transmission
Everybody keeps saying DSG. Has anybody actually read somewhere that the new tranny is going to be a dual clutch unit like VW DSG? All I've found is that it will be some kind of servo shifted true manual with 6 speeds. I hope it won't have 2 clutches, because that has got to be harder and more expensive to mod. I am hoping it will have a single clutch. That would be like the BMW SMG, Audi R Tronic like in the new R8 road car, and every modern Ferrari with paddle shifters. The 2 clutch system is smoother shifting, true. But someday when your modded X needs a clutch to handle 450 ft-lbs of torque, you will be glad it is a single clutch system. (Or the 5-speed traditional manual with a clutch pedal which will also be available).
Old Mar 13, 2007 | 01:32 AM
  #7598
x838nwy's Avatar
All the trannies you mentioned are all unfortunately going to be tricky to work with mod-wise anyway, twin-clutch or not. I mean, these are still fairly rare items unlike the normal manual trannies we know and love, and that applies to all of them.
If it's not the number of the clutch plate then it's likely to be the other bits involved. For example, let's say you upgrade the clutch and thus the clamping load - this would then increase the load on whatever the heck it is they use to actuate the clutch and you'll need to beef that up too. Granted, with a twin-clutch you're going to need double the bits that move and you're going to work probably both ends of it. But the others aren't exactly easy.
Then there's the control parameters to worry about - much like tuning the engine you'll probably need to tune this too if you're faffing around with the innards of the gearbox. The common manual clutch has the driver as the infinitely variable and adaptable user so if you make a change to the drivetrain, you automatically adjust to cope. Now an ECU will try to shift a tranny with a triple plate clutch and super-light flywheel the same way it does a stocker. Which probably won't be nice. I'm sure there's a certain amount of adjustability in there somewhere, but when you're asking for it to take more than 2x what it was born with, I'm sure they hadn't designed it in.
The main point here is that I hope Mitsu allows for considerable power and torque headroom in their system in the standard form. Obviously there has to be some kind of ceiling to keep costs down (the cost of a 1,000whp capable 'box in a 300whp car). But fingers crossed they've worked out that the major part of the evo's appeal is in the moddability.
Better yet, I think they should stick with the normal 6-speed, just make it beefier, more efficient and nicer to use. That's really all they need to do. Offer that and perhaps an auto for the lazier of us and be done with it. IMO these trick 'boxes aren't really needed for the evo. Spending that money on something like 16-step adjustable ohlins on all corners, some weight reduction and perhaps an i/c spray system that works would be so much wiser, I think.
{p.s. I've only tried two such systems. The Maserati Quattroporte uses a system that makes the otherwise really nice car appear to have in the passenger seat, an invisible and blind retard who randomly shifts gears for you whenever he feels like. The Bentley Continental GT uses the Audi system and that's really good but it gets a bit busy in slow traffic.}
Old Mar 13, 2007 | 06:28 AM
  #7599
blitzkrieg79's Avatar
Originally Posted by FLK
Just google it.
Pound for pound, aluminum is four times stronger than steel. It has greater tensility (the greatest longitudinal stress a substance can bear without tearing apart) and yield (how much stress a material can tolerate before permanently deforming).
Apparently in a crash, aluminum absorbs two times the energy compared to steel.
Aluminum can replace iron and steel in automobiles with weight savings of 45 to 50 percent with increasing performance and no safety loss.
http://www.autoaluminum.org/main/ind...0&ArticleID=20
http://www.aluminum.org/ANTemplate.c...ContentID=9015
http://www.streetrodderweb.com/tech/...aluminum_axle/
Ahhhh, it's so refreshing to read a post by a member that actually did some research and knows his stuff. Aluminum engines are not as bas as everyone is making them to be. Hell, if Ferrari, BMW, Mercedes (all high-end companies where money/pricing of vehicle is no object) have been using aluminum engines for a while now (they also switched from iron blocks). Of course if the engine is badly designed from the get-go, it won't be able to handle much boost whether it's iron or aluminum. It's all about good engineering. And to add to your comment, Aluminum absorbs heat a lot better than iron, meaning the engine won't get as hot as it's iron counterpart.
Old Mar 13, 2007 | 07:15 AM
  #7600
smokey's Avatar
I like the way the X looks...and it has some cool new stuff......but in one of the articles I read...it said because of the new 4B11 engine and not having forged internals..and do to the fact that it is not the 4G63...that it will be a problem to turn up the boost. The boost is up almost as high as it will go...for what the engine itself can handle.
That made me sad
Old Mar 13, 2007 | 10:37 AM
  #7601
o2thag's Avatar
That made me sad
Where's your link to the source?
And who would know about the internals anyways or how the 4b11 will be over-all if no one except Mitsubishi has driven and worked on it and they aren't saying anything yet. Therefore I have to say, if you in fact did read something like that, that it was some major BS.
Old Mar 13, 2007 | 10:41 AM
  #7602
psycho 4 life's Avatar
+1
Old Mar 13, 2007 | 12:04 PM
  #7603
futurevowner's Avatar
yes source please, because i read as much as i could before i made this thread, and i didnt read anywhere that it will not have forged internals, not saying it will, but i haven't read anything pointing either way
Old Mar 13, 2007 | 12:25 PM
  #7604
Lt. Boomstick's Avatar
Oh man, I was with you all the way until:
7. The interior looks great in the concept, specifically it kicks the crap out of the horrifically outdated gauges in my IX.
The interior is terrible IMO and is probably the sole reason why I would not purchase this car right now (Lame reason to some I know but you spend your time on the inside of the car, not the outside). Hell, the interior of the STi was one of the reasons why I decided to go with an Evo instead.
Otherwise several good points and I really look forward to the new X :thumup:
Old Mar 13, 2007 | 12:40 PM
  #7605
read a couple posts down on the first page, that is what somebody put, i was just adding it to the list
