Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Ultimate Rattle & Noise Fixes for Evo X
Old Mar 19, 2013 | 07:17 PM
  #121
KeepItLow's Avatar
Originally Posted by momostallion
I think my driver side vent drifts. Its been hot as hell here so i set it to hit my face and next time I jump in the car I feel like I have to do it again.
The passenger side vent is noisy
Edited, looking at fixing the rattling blade piece on the passenger AC Vent.
Old Mar 24, 2013 | 06:34 PM
  #122
Evoool08's Avatar
So far, blessed with zero rattles. Knock on wood.
Old Mar 24, 2013 | 06:50 PM
  #123
Thomar's Avatar
Heh, car has almost 1000 kms on it, and when the cab is cold theres a rattle from the rear.
Also, when music is playing the right door has a vibration somewhere. Typical Mitsubishi.
Old Mar 24, 2013 | 06:51 PM
  #124
momostallion's Avatar
i took my passenger side vent apart and put a piece of felt on one side and the bottom which has removed the drifting feature and the noise.
i will eventually do the same to the drivers side.
Old Mar 25, 2013 | 09:07 AM
  #125
Veronica's Avatar
Originally Posted by Jeffredo
[snip]
My big issue now is the ticking/popping type rattle coming from my Sportback's hatch.
^Me too!
The noise was like a 'flutter' and only when driving. It was intermittant. Seemed worse in the winter time. My theory was that it was the hatch 'wing' itself making the noise.
This weekend my Lovely Bride (on her own inititiative ) climbed back there while i was driving and pressed on the trim. That was it!
The fix was removing all the hatch trim - it basically pulls away after you remove the screws for the handle. You do not need to remove the black'buttons' that hold the cord for the deck cover.
I filled the cavities with thin medium density foam and reassembled it. Good to go!
Be careful with the flimsy white tabs that hold the panels - they are brittle - so ensure the foam doesn't block the hole- because pushing harder will only shatter the white tabs. Ask Me How I Know..
Theory is that either the washer tube or the rear window de-icer wires were touching something... or the panels themselves were touching something...
I figured foam it all since i had it open.
Old May 31, 2013 | 04:27 PM
  #126
mitra88's Avatar
Thanks for nice info!
Old Jun 8, 2013 | 12:03 PM
  #127
ToMinLA's Avatar
I have a 2011 MR. When the car is parked for a short time I get a tweak when I first hit the breaks after driving a few feet. Sounds like coming from the breaks. . After hitting the breaks 2 or 3 times it is gone. All the time after the car is parked for a short wile. I looked for other post on this but did not see anything. Anyone know about this? Thanks guys.
Old Jun 10, 2013 | 06:27 AM
  #128
migs647's Avatar
Do you back up before you park or while parking? That could slightly slide the brake pads back, and when you start driving normal the pads would slide forward a little causing a small sound. Just a guess.
Old Jun 10, 2013 | 10:06 AM
  #129
AGinHD's Avatar
Has anyone found a solution for the AC control rattle? So annoying! lol
Old Jun 26, 2013 | 11:43 AM
  #130
ikt@evoxpod.com's Avatar
you guys need this stuff:
RAAMat
http://www.raamaudio.com/ensolite-iu...on-the-market/
just pop out your AC control unit and stick this across the back of it.
Old Jun 27, 2013 | 10:48 AM
  #131
ToMinLA's Avatar
I think your right. That's what I first thought. Just put on new Stop Teck pads on. that's when I go worse. Thanks for your time.
Old Jun 27, 2013 | 10:55 AM
  #132
ToMinLA's Avatar
I think you are right.
Old Jun 27, 2013 | 09:21 PM
  #133
the brake pads adjust themselves every time you move, probably just noticing it now since you have louder pads. Stock does it too.
Old Jun 28, 2013 | 10:49 AM
  #134
ToMinLA's Avatar
You are right. Thanks.
Old Jun 28, 2013 | 07:16 PM
  #135
xUP's Avatar
xUP
Yes! This thread is gold! Thank you
