COBB EVO AccessPORT released and DYNO results
Old Nov 15, 2007 | 11:25 AM
  #241
CDO's Avatar
CDO
Originally Posted by CPA5
I am hoping to mount it on the passenger side Transmission Tunnel right next to the Cigarrette lighter faced on an angle towards the driver's seat....I saw some kid have 2 gauges mounted there from a feature in Modified Mag and really like that spot.
If I can make a suggestion, have them mount it on the steering column. Staring down to read a guage just isn't the safest thing to do. Especially when you've got your foot to the floor.
Old Nov 15, 2007 | 11:34 AM
  #242
CPA5's Avatar
100% agree........these gauges will give a peak boost readout and I think even a 30sec. playback...i think...
...but I don't drive like most evo drivers do....I'm more on the grandpa side...very conservative...sometimes I drive the wife's civic harder ....so when I do use a WOT pull, generally, if I do look down for a split second its because no one is near by.
I just like the look of the gauge mounted there....most people I chat with say they rarely view their gauges anyways....let say you had like 3-5 gauges...on a WOT pull there is no way to look at them all no matter where they are....
anywho...I do agree with you though....safety is the better part of valor
Old Nov 20, 2007 | 06:27 AM
  #243
mchuang's Avatar
So when is speed density coming out and real time tuning while the car is on? You said you want feedback from evo owners, so I feel that the more people come in hear ask for speed density, the wish will be granted. (I can see it now, driving my stock ecu car in speed density mode to pass inspections hahah) But honestly, I read this entire thread(speedread) and whoever saying speed density does not make more power than a maf need to do a search. Every instance that I have seen on this forum (lots of them) when someone switches from stock ecu to something that uses a map sensor there has always been very reasonable gains over the stock maf sensor.
Old Nov 20, 2007 | 08:41 AM
  #244
Christian.'s Avatar
What you are speaking about is a difference between fuel metering strategies, and the different strategies will not make a difference in power production. If a difference in power production is recorded on a chassis dyno it is because of some other factor. Alpha N, MAP, & MAF are three different fuel (load) metering strategies and the power production of an engine will be the same unless one particular metering strategy imposes a mechanical restriction.
Take care,
Christian.
Old Nov 20, 2007 | 06:13 PM
  #245
mchuang's Avatar
Take care,
Christian.
Yea I have thought of it that way too, but results dont lie.
Old Nov 21, 2007 | 07:41 AM
  #246
CPA5's Avatar
So, it seems that still the main thing here is whether or not COBB will allow for this in their software.. not whether or not there are better results...since things are so new I would assume that this would be well later down the road.
Old Nov 21, 2007 | 07:48 AM
  #247
CPA5's Avatar
Stephen's response below I think is pretty well stated in regards to this issue. It sounds like there are definite benefits after a certain point...and probably before as well...but not a necessity
Originally Posted by IA Performance
To all- we will have updated coverage of the upload process for the EVO. We're going to try some new cinematography ideas Thursday
Brian_H- I definitely do not know more than Rob or Christian at COBB I'm a Dealer / ProTuner of their products. But, we are willing to test and deliver a bit more information to the public than most companies would. In the end, I turn to COBB's staff for information regarding their product.
In regards to a MAF, the following is from personal experience and is of my own opinion. The factory MAF has some limitations, but offers wonderful benefits to the vehicle. We've pushed stock MAF EVO's to 475 whp on our Mustang Dyno, roughly 525 on a Dyno Jet. At this level I start to question the strength of the internals. In the end, the stock MAF will accomodate roughly 90+% of the EVO moding community. For those that desire more, there are stand alone systems. It is my opinion that a car with 500+ whp has become more of a race application than a street driven errand runner. Race applications generally accept the fact of running 4" turbo inlets, BOVs, 1000+CC injectors, AEM EMSs', etc. This is what I've seen over the past 4 years of the EVO. This holds true for Subaru as well. They end up going to standalones at the 500-550 whp level. I'm not saying if you have 500+ whp that your car is unsafe and for racing only. I'm just trying to convey the reality that the stock EVO MAF can deliver results for 90+% of the EVO community. For blow through MAFs, speak to several tuners to see their feedbackson them. I've seen mixed results. More results are negative than positive.
In the end, if a person is die hard Open Source then they will not change to a new option, especially if you have to spend $$$ to so. Of course there is always someone that will. Maybe StreetTUNER will open some eyes, maybe not. Time will tell.
I foresee COBB's AP evolving very quickly. It is due to their dedication to their product as well as consumer feedback (such as this forum).
Now, my post is not intended to draw bad feelings towards you. Rather it is to contribute to the MAF discussion. But your continued inquires, although contributing, keep pitting the AccessPORT vs Open Source in a negative fashion. The AP is a newly released product, give them a break Time will sort out everything. in the end Open Source and AP will coexist for the EVO community. And yes, I've read where you support cobb and even sent your ECU to them For that, we all appreciate your help as it has helped the AP evolution.
Stephen
www.iaperformance.com
Old Dec 10, 2007 | 01:52 PM
  #248
CPA5's Avatar
It sucks this thread is falling by the wayside....IA did allot in the first weeks to get as much info out as possible.....
TO IA PERFORMANCE
Old Dec 10, 2007 | 05:41 PM
  #249
IA Performance's Avatar
Former Vendor
Looks like we are back on the top I'm going to try and aide in all threads in the AccessPORT forum as well.
Stephen
Old Dec 11, 2007 | 07:58 AM
  #250
raiceboi697's Avatar
is there any news on blow through maf set up for the access port, from how i see it if you have a blow throu set up and use a maf translator it should be shouldnt be read any different in the ecu. again this is only the way i see it and i migh tbe wrong....any thoughts IA proformance
Old Dec 11, 2007 | 08:27 AM
  #251
Former Vendor
raiceboi697- I believe ProTUNER will open the door to more options. A little bit of tinkering may net what you desire. Unfortunately, I only have speculation at this point as I have yet to touch the EVO version of the software Soon though, very soon.
Stephen
Old Dec 11, 2007 | 04:05 PM
  #252
CPA5's Avatar
Stephen
Hey Bro---Please chime in some more on this bog issue thread.
One gentleman (mrfred) has said that on a stock car/motor/ecu that knock counts of 10 is normal and even up to 25 can happen...but that anything over 3 begins to pull timing.
THis, obviously is not the same thing we discussed...nor did I get that effect from Christian either in my PMs to him....could it be that the AP is registering knock in a different way?
Old Dec 11, 2007 | 04:34 PM
  #253
mrfred's Avatar
Just want to be clear that when I said knock sums of 25, I did not mean a stock motor with a stock tune. The most likely reason for knock sums this high is a bad tune (or really bad gas). A knock sum of 10 is about as much as one would expect to see on a stock motor with a stock tune.
Also, just want to be clear that the ECU can pull timing at knock sums of 1-3 as well. The ECU handles knock sums higher than 3 counts differently though.
Old Dec 11, 2007 | 05:36 PM
  #254
CPA5's Avatar
Okay, so knocks of 25 or so = aweful tune, bad gas
would a good tune = maybe only 1-2-3 knocks across the rev range......and doesn't knock happen differently for maybe WOT vs. 3/4 throttle?
I generally see knocks of 3-4 at 1/2 or 3/4 throttle around 2500-4500 rpm usually 3rd to 5th gear.
at WOT I seem to never notice any knocks.....but I am concerned on this issue as now with the AP stage 2 91oct map that is supposed to only hit 21.5psi is now hitting 23psi.......obviously it is colder now....but since there is no way to tune yet with the AP I guess all I can do is not go into boost as from 3rd-5th gear since it is boosting higher
Old Dec 12, 2007 | 09:21 AM
  #255
CPA5's Avatar
The above is very concerning.....I am wondering if maybe with the base maps having the secondary pill out is the main cause...not the weather...for boost creep or spikes above what the maps are intended to be set at.
