Yet another thread about Turboing a 03 lancer.
Old Sep 24, 2011 | 07:29 AM
  #1231
burner67's Avatar
Im using the rom u started me with horn. I do I make both high and low octane the same
Old Sep 24, 2011 | 07:53 AM
  #1232
ryancb's Avatar
Dont mean to hijack but lets take it over to my thread haha. Just that way for everyone else it makes sense
  #1233
HornstarBU's Avatar
Oh kay, so when you feel sluggish, what's the timing at? I am at like 1-2 at low low RPM when entering boost and by about 5psi I'm at like 2-4 advance. Do you see knock when you stab the accel hard, or in the middle of a steady pull, or after a shift. Post a pic of a log, use that first option in evoscan that does like a line graph. Put timing, AFR, knock, RPM, TPS on it....then you can see real well what's going on (just make sure you zoom in on it on the part you are focusing on.
Old Sep 24, 2011 | 10:04 AM
  #1234
03lances's Avatar
Originally Posted by HornstarBU
2 things I'd like to add, first is that I see around 150 at 5-7 psi or whatever, so that's good to see you saw the same and that you added when I go to 10-12 I'll still be under 200 load probably
Second thing is about knock. I drove on the stock lancer ROM on 2 different cars, and logged them. I literally saw max counts of know all over the place just randomly cruising, acceling, not so much at WOT....but the basic idea is that I saw crap tons of knock without any changes. My car now doesn't knock near as much, but like some of you....I do see random knocking.
Oh, also about your timing changes not seeming to take effect....are you using the right map? Is it on the high oct? low oct? what rom you guys using?
I am adjusting the Main Maps High octane map then adjusting to low octane appropriately. I am thinking about making high and low the same while tuning to see what happens. We are using Tephra's V7 9417075, having a sneaking suspicion its using the low octane map but had more important things to focus on yesterday.
Old Sep 24, 2011 | 06:02 PM
  #1235
burner67's Avatar
it knocks a lot a lot when i shift at high rpms. and just randomly it knocks too. idk if i will have time soon enough to post a big log.... but ill try to get one asap maybe tonight
Old Sep 24, 2011 | 07:31 PM
  #1236
03lances's Avatar
How is the road you use? Do you use the same road for all your tuning? Is it relatively flat and smooth? Fast shifting seems to cause knock on our cars pretty commonly sounds like. Pretty much all of my false knock I have found out was being caused by two things.
1) the metal elbow I put in to keep the radiator hose from melting onto the header was rattling on the header causing alot of false knock
2) I didnt grind enough of the nub on my turbo and so it was rattling on the waterpipe causing more false knock.
If its not consistent knock then I chock it up to some outside source whether a dip in the road or something rattling etc. Especially if doing some general timing lowering in those areas seems to have no effect.
Old Sep 24, 2011 | 07:49 PM
  #1237
burner67's Avatar
well i use several roads but i know not to use bad roads. they are all nice flat roads in the country. i have heat wrap between the coolant pipe and turbo. like i said everthing is very well buttoned up.
on a positive note i did eliminate some timing up top by advancing the load areas. after taking a look at my log somehow timing got to -9 somehow in the 200 load where it should be -1 or 0... so i increased timing there and it fixed some knock... i could tell by the logs the more positive timing the less knock there was
Old Sep 24, 2011 | 11:20 PM
  #1238
03lances's Avatar
I use the same road 95% of the time. I have a backup road if I see more activity than I am comfortable with but my main road is literally 30 secs from my house. Very little traffic, two straightaways both plenty long enough for WOT 3rd gear pulls so I pull on the two straights then turn around and pull on them back the other way then pull into a little gravel lot on the side where I can check and adjust then do it again .
-9 is crazy low I can see how you would be getting some knock from that. We were seeing dips of -4 on ryans making me think its pulling from low octane map.
Old Sep 24, 2011 | 11:31 PM
  #1239
burner67's Avatar
nice. roads are a few minutes from my house.
a little off subject but what do we need to do to run nlts? anything because its not working lolz i read somewhere bout running a wire?
Old Sep 25, 2011 | 07:23 AM
  #1240
HornstarBU's Avatar
I think ntls and launch maps are from using the clutch switches. We have 1...not sure if we don't have both though or what the part number is...either of those aren't for me though. I don't want to tear my clutch and trans up launching, and I get nervous trusting the nlts stuff....also you have to let all the way off clutch or it will keep that rev limiter enabled.
We have 1 clutch position switch...never tested if either of those things work. Put the limiters real low and test it, don't do it out on the road, just do it in the garage or rolling down the road at 20 mph .
Old Sep 25, 2011 | 03:51 PM
  #1241
burner67's Avatar
i think steven knows...
Old Sep 25, 2011 | 06:19 PM
  #1242
03lances's Avatar
Hornstar is correct. At least about the nlts. Evos have two clutch switches one fully up position and other fully down. It needs both of these to operate. Probably correct on the launch maps too I just havent ever looked into that.
Old Sep 26, 2011 | 06:20 AM
  #1243
slatermvp's Avatar
is this like 2 step if so Steven got it to work on his.
Old Sep 26, 2011 | 08:42 AM
  #1244
burner67's Avatar
got it to work!!! ran a wire from the upper clutch switch (we have one) to the ecu..
so from the tan wire on the upper clutch switch to ecu pin 43. its on the 8 pin connector just 2 spots to the left of the pink (rpm) wire on the bottom row
Old Sep 26, 2011 | 12:49 PM
  #1245
slatermvp's Avatar
whats nlts??
