***ECUFlash Now For Base Lancers!***
Old Jan 11, 2007 | 06:04 PM
  #361
MarkOJ1011's Avatar
It was my car that we fitted the 65mm DSM TB on...
Three words... TWIST THE TPS!!
You can manipulate idle that way on the DSM TB...
Which generation DSM is your TB?
Old Jan 11, 2007 | 06:09 PM
  #362
krnzzang84720's Avatar
1g NT DSM TB, with 2g sensors!
so is your idle okey now?? plz help me
Old Jan 13, 2007 | 05:47 PM
  #363
Silens's Avatar
ok got the cable, download everything fine no errors picked the 04 lancer, and i cant see anything? im lost, is it working for you drucea? or any other 04s?
Old Jan 14, 2007 | 10:48 AM
  #364
baileysboostdoz's Avatar
well its good to see that there is one out there finally
Old Jan 14, 2007 | 11:39 AM
  #365
Silens's Avatar
i tried using the 03 definiton from z lancer but its not correct, there is no high octane fuel map and the low octane map looks off and is missing values. I searched around ecuflash forums and i cant find any help or direction on how to go about creating definitions :/
Old Jan 14, 2007 | 12:10 PM
  #366
drucea's Avatar
Yeah I'm stuck with mine. I can't get it to do anything with my car. Is there anyone anywhere in texas that can help me out in person because I can't figure it out? Thanks. Sorry I can't help you out Silens.
Old Jan 14, 2007 | 02:37 PM
  #367
Z_Lancer_Man's Avatar
Silens - sounds like a definition file for you needs to be made as well. Can you post or email me your stock ROM? Did none of the definition files work for you? Send it to me and I'll see if I have one that works and if not, we'll get one made for you.
Old Jan 14, 2007 | 03:38 PM
  #368
Silens's Avatar
Yes none of the Lancer definitions worked, i even tried yours, but there was no high octane fuel map, and there were values missing from a lot of the tables.
i posted on the openecu forum for some help, my ROM ( that is the .hex file downloaded from the ecu right? ) is posted there
Hopefully we can get this to work for us 04s too
Old Jan 14, 2007 | 07:21 PM
  #369
drucea's Avatar
you're manual right? if so, I would need a def. file made too. If only I could get my rom DLed to my computer now
Old Jan 14, 2007 | 07:30 PM
  #370
sethrice90's Avatar
Hey to everyone who knows what they are doing with the Ecu Flash!! I need to know exactly what I need, how much, and were to get it!! I also need a complete def file for my mirage oz 2.0T, Lancer Oz 2002 Motorswap,T3/4 super 50 turbo, Port&Polished, 300cc inj. 60mm TB, Feul regulator,Safc2, FMIC, Ect. I need the flash for 7-10psi!!! Want to datalog also. Thanks
Old Jan 14, 2007 | 10:36 PM
  #371
hey guys, my cable and open ECU communicates with my car fine but i also do not see High Octane Map, I only see low octane fuel Map. But i see both high and low octane Ignition map under timing. What's wrong??
Old Jan 15, 2007 | 05:46 AM
  #372
Wallesasuaz's Avatar
u PROBABLY need a definition file created to correctly decipher your ROM. If not, you're gonna see erratic numbers everywhere and won't be right.
Old Jan 15, 2007 | 07:48 PM
  #373
hmmm i uploaded the rom to my ecu and it worked fine.. everything seems right except i don't see high octane maps
Old Jan 30, 2007 | 01:56 AM
  #374
monsta's Avatar
Drucea- are you connecting the cable to the computer BEFORE you open ecuflash?
otherwise it wont up load the rom
If you get a connection- just keep trying different models to inherit from until it loads.
Once that is done post your rom and Ill do a def in a couple of hours (allowing for the fact im in New Zealand)
If anyone has a rom without a definition, or there are scrambled tables etc- post it and ill do them too.
I know heaps about the ecus- so should be able to help. I have an Airtrek Turbo, which is based off an Evo but with different ecu- so I had to learn lots to get things to work.
Old Jan 30, 2007 | 04:15 AM
  #375
Silens's Avatar
Well heres my rom , it is for an 04 Lanzer OZ Manual, none of the other Evo or Lancer definitions work
