***ECUFlash Now For Base Lancers!***
Old Feb 28, 2007 | 02:34 PM
  #421
wickdaddy's Avatar
Originally Posted by Z_Lancer_Man
Now we need to see what your datalogs are to see where you can start removing fuel. Doesn't make any sense to start changing values without knowing why and where
EVENING LOG
Click here for my evening log with 450 injector scaling. I did a few 2nd, 3rd, and 4th gear pulls in this log.
It is in CSV, so right-clicking and selecting "Save Link As" and opening in Excel will make it a little easier to read
Also the rom I used along with the Read Image are attached.
File Type: zip
Last edited by wickdaddy; Feb 28, 2007 at 02:46 PM. Reason: attached rom and image
Old Mar 2, 2007 | 02:38 PM
  #422
iufan4lifeul's Avatar
I don't get a lot of this. With several of the maps you have posted it jumps from 14.7's AFR under low RPM/load to ~ low 11's under high load/RPM. The stoich fuel mixture of our cars is around 13 AFR's as tested by RRM. On my car, piggybacks a 14.7 would trigger a lean code. Low 11's are what it is factory. I do believe something is wrong or people just don't know how to tune their cars. At idle you should be low 14's and everywhere else low 13's. That generates the most power for an NA lancer.
Old Mar 2, 2007 | 03:22 PM
  #423
wickdaddy's Avatar
yes, I understand your reasoning for an NA lancer, but look at my sig... definately not NA I'm around 18-20 at idle and about 14.3 just crusing. the tune that it is at is not perfect, but it is definately not an NA tune
Old Mar 2, 2007 | 09:31 PM
  #424
drucea's Avatar
OK, I finally gave my car another try with this cable. It read my ecu but I can't see these tables like everyone is posting. But I did save the rom. Any idea what I can do about it? I think this means I don't have the correct definition files or something like that.
Old Mar 3, 2007 | 11:03 AM
  #425
Z_Lancer_Man's Avatar
That's correct. Post up your ROM and we can get those def files made.
Old Mar 3, 2007 | 07:14 PM
  #426
drucea's Avatar
OK cool, well it says I have the wrong file type so tomorrow I will upload my rom again and try then. THanks
Old Mar 3, 2007 | 08:53 PM
  #427
grapeapeoftokyo's Avatar
my rom i think??? i cant get it to post up. how do you put it in the thread?
Old Mar 4, 2007 | 08:35 AM
  #428
You can compress it into a zip file and then attach the zip to your post.
Old Mar 4, 2007 | 09:43 AM
  #429
drucea's Avatar
ok now its telling me my file size exceeds the limit of the forum, is there ny other way to put it up? or do i have the wrong thing?
Old Mar 4, 2007 | 04:05 PM
  #430
Sounds like you might have the wrong thing. In post 421, wickdaddy attached his ROM and it was only 95 Kb compressed.
Old Mar 9, 2007 | 04:26 PM
  #431
here is my rom, its for an 03 es auto. 8190006 i think was the ecu id. if that helps any.
File Type: zip
Old Mar 11, 2007 | 01:07 AM
  #432
^is it the correct file??
im pretty sure that is it. what does defining the file actually entail?id like to learn and maybe help out if at all possible, if not, the not being that it is ridiculously complicated, then im pretty sure it would be better to leave to you guys anyway. haha.thanks.
Old Mar 11, 2007 | 09:24 AM
  #433
That file will work. Making the definition file is mostly interpreting HEX code. If you'd like to learn more about what a definition file is, check out the forums at openecu.org. That is the major support site for ECUFlash, the Tactrix cable and even EVOScan.
Old Mar 11, 2007 | 09:14 PM
  #434
JohnBradley's Avatar
I was interested in this last night and while I have no problems with Evo .hex for some reason I cant get any of the ROMs you have posted up to work. I have all the listed definition files (I am running EF 1.30) but for some reason nothing is readable. Ideas as to what I am doing wrong?
JB
Old Mar 13, 2007 | 07:00 PM
  #435
Kid Lancer 7's Avatar
verry interesting!!
