***ECUFlash Now For Base Lancers!***
Old Mar 14, 2007 | 05:03 AM
  #436
Redlancer's Avatar
I install the EcuFlash 1.30 few days ago and you need the .def file that you will find in the first post to read the file corectly.
You just have the Evo .def file in the package of the EcuFlash.
Old Mar 26, 2007 | 09:08 AM
  #437
grapeapeoftokyo's Avatar
any news on the definition?
Old Mar 26, 2007 | 03:39 PM
  #438
wickdaddy's Avatar
just hopped on now, and dled your zip file and I couldn't extract it... what did you use to zip it?
Old Mar 28, 2007 | 11:02 AM
  #439
i had to use winzip because the site wouldnt let me use any other. sorry.
Old Mar 30, 2007 | 12:54 PM
  #440
wickdaddy's Avatar
try saving it again... like this:
also try posting the working zipped file in the openecu forums... they got right back to me quickly...
Old Mar 31, 2007 | 11:05 PM
  #441
i did that but i couldnt find the folder it compressed to. sorry. but i did post the winzipped version on ecu.org thanks. umm. sorry i couldnt get that other zipped version up.
Old Apr 12, 2007 | 08:55 AM
  #442
i leaned out the high octane map and now i dont smell gas whenever i start it up. i cant feel a difference but i also have been trying to get rid of the knock at midrange rpms with high load. its cool though.
Old Apr 14, 2007 | 10:32 AM
  #443
Z_Lancer_Man's Avatar
Sounds like its working for you now, great!
Old Apr 16, 2007 | 07:53 AM
  #444
i advanced the timing a full point across the board except a little at one point but immediately after is when i felt the most gain.
Old Apr 16, 2007 | 08:44 AM
  #445
Are you datalogging at all? I'd just be concerned for any knock that you may be getting now that you are advancing the timing.
Old Apr 16, 2007 | 08:47 AM
  #446
yeah i have a nice little freeway on ramp that works great for WOT pulls. im using evoscan and tuning for knock mostly. so far ive been able to keep everything down. ill probably keep it where it is for right now and then here in a couple of days ill go back to tuning see what else i can get out of it.
Old Apr 16, 2007 | 09:10 AM
  #447
Sounds good!
Old Apr 18, 2007 | 08:47 PM
  #448
Noe18's Avatar
I have a 03 lancer es a/t does the ecuflash will work on it if not where can i find 1?
Old Apr 18, 2007 | 08:55 PM
  #449
ECUflash will work on any Lancer! The only thing you may or may not have to worry about is the definition file (the file that translates your ROM, or you ECU tune, to something that you can work with). So go ahead and get the cable and download the software for free and you'll be well on your way for tuning your car!
Old Apr 19, 2007 | 07:46 PM
  #450
Noe18's Avatar
Thkx z lancer man for the info, i never tuned a car before is there a thread that has step by step also after i tuned it can i still buy the ecu from road race
