***ECUFlash Now For Base Lancers!***
Old Aug 6, 2007 | 11:12 AM
  #646
senate6268's Avatar
The numbers in the cells won't be the exact AFR that comes out. It's just a number the ECU reads for adding and removing fuel. The lower the number, the more fuel is added at that condition.
Old Aug 6, 2007 | 11:14 AM
  #647
lancerrally45's Avatar
ok that makes sence. i have bigger injectors as well so thats why im prolly running pretty rich.
Old Aug 6, 2007 | 11:20 AM
  #648
senate6268's Avatar
Exactly. You don't enter in "11" or "11.5" in the cells and then the ECU will provide the fuel for that AFR. You will have various numbers in different cells that will give you the results you need. And also, like you said, since you have bigger injectors your numbers will be different from someone who has stock injectors at the same boost and setup.
Old Aug 6, 2007 | 12:20 PM
  #649
ok, thats what i kindda figured. thanks for all the help
Old Aug 7, 2007 | 01:28 PM
  #650
elcausa's Avatar
do all stock fuel maps have to look the same or can it have some variation?
Old Aug 7, 2007 | 02:08 PM
  #651
senate6268's Avatar
I'm not sure if the FED and CAL spec have different maps loaded or if the maps had variations when the returnless fuel system came about in 2004. That's a good question.
Old Aug 7, 2007 | 02:30 PM
  #652
elcausa's Avatar
i was asking because there was no def file for my rom so i had to edit one def file for it to display properly, i was aiming to get it to look like the one in the first post, is the same for the most part just some cells have different values so i wanted to make sure i did it right
Old Aug 7, 2007 | 02:33 PM
  #653
senate6268's Avatar
Post a screenshot of your high/low octane and high/low timing maps just to make sure before you start changing values.
Old Aug 7, 2007 | 03:06 PM
  #654
elcausa's Avatar
here are the maps the id number is 81900016
Attached Thumbnails ***ECUFlash Now For Base Lancers!***-highoctane.jpg   ***ECUFlash Now For Base Lancers!***-ignition-high.jpg   ***ECUFlash Now For Base Lancers!***-lowoctane.jpg   ***ECUFlash Now For Base Lancers!***-lowignition.jpg
Old Aug 7, 2007 | 05:27 PM
  #655
senate6268's Avatar
Those look right. Have fun!
Old Aug 7, 2007 | 06:35 PM
  #656
forgsix3wannab's Avatar
ok noobish question ...what do i need to tune my 03 es? i know where i can tune it i just need the hardware.
Old Aug 7, 2007 | 07:25 PM
  #657
senate6268's Avatar
You need a Tactrix cable, a laptop, a wideband O2 gauge and to get rid of your ZEX nitrous kit before you shatter a piston.
Old Aug 10, 2007 | 12:08 PM
  #658
slipshft's Avatar
Question Anyone
Anyone map an N/A 06 ES? I have read through this long thread, but didn't find anything on a 06. i was hoping that I didn't miss it.
Old Aug 12, 2007 | 09:17 AM
  #659
elcausa's Avatar
i dont think anyone mapped a 06 yet but if you post the rom file maybe somebody can get the def files
Old Aug 22, 2007 | 08:26 PM
  #660
Silens's Avatar
have you tried one for an 04?, it should work, same setup
