***ECUFlash Now For Base Lancers!***
Old Aug 30, 2006 | 04:34 PM
  #121
Sicktght311's Avatar
440cc Injectors have been known to give idle issues from what i've read. The injectors are too big for the car and unless you runstandalone or some kind of injector size compensation the ECU alone cannot scale back the fuel delivery enough. Perhaps i'm wrong, but i am still tryin to retain driveability. Plus i am still almost positive 370cc injectors can handle around 10psi in terms of fuel delivery. I know they are whats included in the RRM stage 2 kit and thats what, 9psi? I dont see any reason why 1more psi would create a serious lack of fuel from 370cc. Plus why do 10-11psi when 9 psi is still a kick in the face, and a little more reliable If i want to get 250whp i might as well just buy an evo and go from there hehe which i will be doing in a year or so when i leave NY. Then i'll be in the hunt for a clean 89' 240sx to garage and build a weekend s13 drift machine
Old Aug 30, 2006 | 05:48 PM
  #122
Wallesasuaz's Avatar
in new york we have 93 octane.
If we're lucky some Sunoco stations carry 94 oct.
Old Aug 30, 2006 | 08:45 PM
  #123
senate6268's Avatar
Well, allow me to be the first to state that Z's METAdata definition file doesn't work for me. The addresses for proper scaling of the axis on my ROM are different from his. However, the data value addresses from his definition file do match up to the ones from my ROM.
Old Aug 30, 2006 | 10:44 PM
  #124
Lancerguy'03's Avatar
i was able to pull the ROM off my ECU tonight an view all the defintions that he had got so far....meaning....i can tune my stock ECU.....i did not however try to load his ECU settings to mine.....so it has worked for me.
Old Aug 30, 2006 | 11:02 PM
  #125
rhyzin's Avatar
the reason(or at least what i believe) for larger injectors not working are for just the normal piggybacks because of their lack of ignition timing. they do not modify fuel adjustment directly, but rather indirectly by modifying the airflow signal. a side effect of this method is that ignition maps are also indirectly modified as ignition maps are based on airflow(or more rather LOAD) vs rpm. I just have a modified MAS and i already have a jump in timing ignition from 5 degrees(stock) to 16 degrees due to an increase in airflow readings at idle and AFC adjustment. ECUFlash could resolve this. i haven't fully looked into this and am waiting for a final definition file.
370cc injectors with the vortech fmu could support more than 10 psi if the fuel pump tops out at 90psi, although i don't know why anyone would want to tax their fuel pump like that all the time. also, the vortech fmu does have a small minority who have had problems. the RRM piggyback may also be a reason for the 9 psi limit due to my reason above. not a lack of fuel, but a lack of timing.
Old Aug 31, 2006 | 02:31 AM
  #126
EvoGLH's Avatar
Send me a copy of your rom & I'll see what I can do for ya to find your proper data value addresses.
Old Aug 31, 2006 | 07:02 AM
  #127
senate6268's Avatar
Here's a copy of my ROM file. I thought we might run into this problem. It's actually a common one if you look on the OPENecu forums. Let's see if we can figure out all the METAdata value addresses for all the different Lancer ROMs and get a collection of xml files going!! Thanks!!
ROM File
Old Aug 31, 2006 | 07:10 AM
  #128
yea.. if the metadata value changes for each ECU in each vehicle... That's something we should take into consideration....
But i've noticed, that alot of you have 2003's? does no one drive a 02 or what?... lol
Old Aug 31, 2006 | 07:13 AM
  #129
N1te's Avatar
I have an 02, I just need money to buy the cable.
Old Aug 31, 2006 | 07:22 AM
  #130
sdhes's Avatar
03's Rock
What? Am I speakin Chinese
Said by: Paul Silas, one time coach of the Cleveland Cavaliers, after a loss.
Old Aug 31, 2006 | 07:29 AM
  #131
senate6268's Avatar
I don't think that every vehicle has a unique ECU. I think that there will be a handful of different META data files for each year.
Old Aug 31, 2006 | 07:35 AM
  #132
^ yup.. u probably right.
Old Aug 31, 2006 | 07:45 AM
  #133
Hey Wallesasuaz. 1) whenever u wanna get together and tinker with your fuel maps let me know. and 2) i'm moving to brooklyn in about a month or two so we'll be much closer, lots of tinkering to do
Old Aug 31, 2006 | 07:57 AM
  #134
Where in Brooklyn?
my name is david. lol... but now you know. YEa, fo sho! I'll def. let you know.
Old Aug 31, 2006 | 08:33 AM
  #135
Not sure yet, lookin at a place in bensonhurst this weekend. We'll see what comes about. I'm Tom. Let me know when your cable gets here. We can meet up halfway maybe in nassau or something and see what we can come up with. I'll bring my laptop
