Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old May 26, 2010 | 09:08 AM
  #391
RoadSpike's Avatar
Link the next time you try the valet mode thing can you log
MUT00 = 8D06
MUT01 = 8D07
This is the countdown timer so we can see if its really counting down.
Old May 26, 2010 | 09:17 AM
  #392
link62's Avatar
MUT00 = 8D06
MUT01 = 8D07
ok cool lol i was about to head out and give the knock light a try so u posted just in time ill get u the logs in a bit
Old May 26, 2010 | 09:33 AM
  #393
link62's Avatar
email sent and ill brb gonna test the knock light
Old May 26, 2010 | 10:13 AM
  #394
RoadSpike's Avatar
Cool got both logs the timer doesn't seem to be decrementing so something is going on with that.
Old May 26, 2010 | 10:45 AM
  #395
link62's Avatar
new log sent
Old May 26, 2010 | 10:49 AM
  #396
RoadSpike's Avatar
new log sent
Same story something must be resetting the countdown or its not hitting the right code loop not a big issue but annoying lol
Old May 27, 2010 | 07:36 PM
  #397
RoadSpike's Avatar
new log sent
So i'm back got off early which was nice. Think I know whats going on with the code for map switching sending you a new rom link
Old May 27, 2010 | 07:41 PM
  #398
link62's Avatar
awesome ill get on the car and give it a try
Old May 27, 2010 | 09:33 PM
  #399
link62's Avatar
valet mode works now and log sent
Old May 27, 2010 | 09:43 PM
  #400
RoadSpike's Avatar
Cool already emailed but i think maybe time to try alt maps
Couple ways to try it that are super easy.
One mess up the injector scaling so it idles rich or lean
Two mess with the timing fuel map and check the logs
Old May 27, 2010 | 09:54 PM
  #401
link62's Avatar
ok ill try the injectors first then the timing map
also i put 1 in the box to turn it on right cause i get three options and what do that others do?
1) ADC0F
2) AutoICS
3)TPS
edit: also i would do the same as valet to active the alt map?
Old May 27, 2010 | 10:21 PM
  #402
RoadSpike's Avatar
1) ADC0F
2) AutoICS
3)TPS
I would use option 3 becuase thats TPS. I've updated the xml hence forth a few times but ADC0f is a input channel into the ecu but we don't know where it is on this ecu so its not worth testing.
AutoICS doesn't exist on this ecu so its completely disabled and wont work so you only option at this point is 3. I'm keeping option 1 open in case its found.
And yes you enable it in the exact same manner as valet maps.
Old May 27, 2010 | 10:35 PM
  #403
link62's Avatar
ok cool ill go give it a try, ill report back in a bit
Old May 27, 2010 | 10:46 PM
  #404
link62's Avatar
Alt map works also put my injectors scaling really low and was super rich at idle didnt try the timing yet but will give it a shot in the morning
Old May 27, 2010 | 11:29 PM
  #405
RoadSpike's Avatar
Cool pretty close to being totally tested and finished for publish use
You may as well test mdp averaging at the same time its pretty harmless.
Just log mdp and see if it puts out sane values
