Focus RS
Old Apr 15, 2016 | 07:28 PM
  #3151
Noize's Avatar
EvoM Administrator
That light blue BRZ is sick!
Old Apr 15, 2016 | 11:40 PM
  #3152
WestSideBilly's Avatar
El Jefe
Originally Posted by whtrice
Flash backs maybe........
I just don't like it... too pastel for my tastes. I've seen a bunch of Volvos in the same (similar?) color and it's just not appealing... and it's not appealing on any of the cars above.
Old Apr 15, 2016 | 11:41 PM
  #3153
moparfan's Avatar
Read all the way through the analysis to "In Summary"...
2. The new SH-AWD and the GKN Twinster (used on the 2016 Ford Focus RS) are intrinsically the same.
http://blogs.youwheel.com/2015/03/31...sive-analysis/
Old Apr 16, 2016 | 05:35 AM
  #3154
Robevo RS's Avatar
"No question, this has become the performance hatchback to beat."
http://www.caranddriver.com/comparis...omparison-test
Old Apr 16, 2016 | 08:19 AM
  #3155
LetsGetThisDone's Avatar
I read that as SH-AWD is better. Due to the use of planetary gear sets, the clutches see 28% of the load that the clutches in the GKN twister in the FoRS do. So it can handle constant torque transfer much better.
Sounds like Ford should have went to Acura for the rear diff.
Old Apr 16, 2016 | 09:00 AM
  #3156
whtrice's Avatar
Veteran: Air Force
Acceleration performance results between the STI and RS are almost identical.
Within a tenth and a mph here and there. Then you look at the weight of the two...almost identical!!!!
Then the interesting part.......
Advertised power of both:
RS ~ 350HP and STI ~ 305HP
350TQ and 290TQ
9.9 lb/hp and 11.3 lb/hp
The numbers should give a superior advantage to the RS but this
testing acclaim shows results are actually moot by comparison.
Uhhhhh FORD
Old Apr 16, 2016 | 09:07 AM
  #3157
nemsin's Avatar
...we know the GKN Twinster clutch pack is fully responsible to transfer power to the rear wheels. This means in the Focus RS, if each rear wheel gets 50hp, then this 50hp is transmitted wholly through sliding friction within the clutch. Hence, there will be serious wear and overheating issue if the clutch is engaged for a long time.
Old Apr 16, 2016 | 10:02 AM
  #3158
kaj's Avatar
kaj
A
testing acclaim shows results are actually mute by comparison.
Uhhhhh FORD
Moot 😉
Old Apr 16, 2016 | 10:50 AM
  #3159
ambystom01's Avatar
Cool, people had similar concerns when the Evo X MR first came out.
Old Apr 16, 2016 | 12:00 PM
  #3160
nemsin's Avatar
And there is a reason (cough heat) that people go with the manual over the SST for track use.
Old Apr 16, 2016 | 12:26 PM
  #3161
ambystom01's Avatar
There has been a big change in how the SST is perceived between when it first came out, and now. Big power SST builds aren't rare anymore.
Old Apr 16, 2016 | 12:50 PM
  #3162
And (cough) proper coolers resolve that issue...
Old Apr 16, 2016 | 12:53 PM
  #3163
ambystom01's Avatar
Say it isn't so, you mean tuners responded after they actually had the ability to test the car?
Old Apr 16, 2016 | 01:57 PM
  #3164
nemsin's Avatar
Despite what you say, I do not see very many X MR's being used at the track. The SST is rediculously expensive to repair.
Also, I don't think simply adding a cooler is going to solve the GKN twinster heat issue. More than likely the whole unit will get swapped out of a mechanical one (like on the RS RX).
Old Apr 16, 2016 | 02:00 PM
  #3165
ambystom01's Avatar
Also, I don't think simply adding a cooler is going to solve the GKN twinster heat issue. More than likely the whole unit will get swapped out of a mechanical one (if its even possible).
I see plenty with high HP.
Cool, so you know how to improve a car you've never seen or worked on? Awesome.
