Focus RS
Even if it uses the brakes for the front LSD, I'm sure Quaife or similar will shortly come out with a real front lsd, and the intrusion of the electronics/brakes to act as an LSD would be mostly minimized
It looks as if it will have better performance than that of the Evo X S-AWC. However the clutches will get hot and it is sort of a limited use system, it will add the extra performance as needed but it can't sustain long periods of use and the system will need repairing when worn out. I can see this system causing a lot of issues. It's very close to the Evoke platform system but it's being used in a hod rod.
I know the evo has clutches inside its ACD but I don't think its used as much as the ford system will be especially when a magazine tests it at Laguna all day. On top of that it uses the brakes as a torque vector and we know this cooks the brakes quickly.
Also with this system being turned on and off the car won't have the full time performance feel since it uses this system only when it requires it. Seems to me it would feel mundane most of the time and when it gets into trouble it will step in and work then go back to being a front drive Focus where as the Evo has a full time race feel.
i drove one in Lime green, and some mods on it.
Good car, BEAUTIFUL engine sound,
It wasnt as convincing as the Evo, neither as handy.
But i have big hopes for this AWD version, because this old one would be a different animal too, with a good AWD system.
As Robevo well can attest, weight is the enemy!
My Evo 8 is 3110lb fully wet on scales. Since than I installed carbon seat, Titanium exhaust, and at the "scales moment" it worse 24lb heavier/set of 4 wheels than others I usually use on it.
So I think its down to 3050lb fully wet: full equipment. Nothing removed..AC/interior is OEM.
My TME is less than 3000lb for sure, it feel slighter than E8, has to be.
And the lightness and nimbleness is obvious. Its signficantly more "pleasant' to pedal it on backroads.
Its lighter weight, smaller dimensions, really help enjoy the process.
So if this the Focus RS AWD is 3500lb or more even, it will never perform better than Evo 9.
Let alone smaller TME.
Nobody built better sport sedan that can be, with moderate upgrades, the fastest A to B vehicle, than Mitsubishi Evo V, VI, TME, VII-IX.
As much as it would be fun to experience something better, I don't see it coming!
GTR is great technology, but its not faster on road than Evo...that has been tested.
Evo with few simple mods:
Ohlins Road and tracks, HKS turbo, S2 GSC cams, retune.
Its so perfect, if you have the skill, you 'll be amazingly fast. Equal tire...nothing much stands a chance...on real roads..that Robevo knows...real roads, not Freeway...real roads like California Canyon/mountain roads, like European B-roads...
Freeways are congested, nowhere to go.
Well, let's see it.
I doubt it will be great as we hope, the Focus.
Nobody makes lightweight cars any more...even GT86/BRZ/FRS is 2800lb...and they call that Lightweight.
Well, let's see it.
It is sad that cars have gotten heavier and heavier, but a good bit of that weight can be shed if you want to make a track car.
Can't explain stuff like that to the mustang crowd, that does not realize a stock new base GT (not 15), that I just picked up since they were cheap, is a horribly handling car. Thing is a pig, closer to 3700 with auto (is easy to drive relatively quickly in normal traffic, no lag, no shifting, quiet, smooth, etc...).
The current Focus ST FWD is already 3214lbs. I predict the RS will be approx 3400lbs.
The 2015 Golf R, which the Focus copies much from, chassis and suspension wise, is 3,340lbs. That is 200lbs heavier than the FWD Golf GTi.
Tire tech advances,
"New Evo IX" on same tire as Focus, would not be surprised if laptimes were same:
And who will, of us, buy new Focus, strip and build racecar?
That is not its purpose at all.
For track/racecar a we get salvaged dogs, and build.
So no, the Focus like Evo should be looked at full weight and with moderate mods:
Reflash/exhaust, maybe cams (Duratec turbo usually does not get upgraded cams) and maybe Ohlins R&T for both cars...brake pads/tires
As we can see, weight is weight, Evo IX can accept 275/40x17 tire, but even limiting to 265/35x18, doubt Duratec will/can make more power reliably on stock block and provide any handling/braking advantage.
Just ask Group N boys...nothing beats Evo...yet: Subaru Sti Group N is Spec-C/RA-R special and its a challenge but nothing else.
What you're talking about is basically outfitting the Evo with 10+ years of research and then "comparing" it to a brand new car with a relatively new engine. How on earth is that a fair comparison?
You either compare them stock, or not at all. Once you start modifying cars, you're naturally going to enter the realm of biasing the comparison one way or the other.
Based on your previous post though, it seems pretty clear you're drinking the Mitsubishi kool-aid. I don't know how someone can say with a straight face that the Evo is the best A to B car in the world, or that the Evo is a faster road car than the GTR, unless you're comparing heavily modified Evos to bone stock cars that have superior reliability, luxury, prestige, etc.
When I read old threads speculating performance of the VIII, IX, and Xs, before they came out....everyone was so far off, it was comical. LOL
We all could be very far off again.
I could see this car matching the ct9a due to it's tech and added power to offset the weight.
But that would mean it'll eat it's fair share of tires too.
We'll see. I'm stoked.
