Mk V Supra - My Evo's Replacement?
Old May 27, 2022 | 02:49 PM
  #1501
EVO8LTW's Avatar
Originally Posted by razorlab
Apparently faster and longer lasting. Holy grail, so we'll see if that is actually true.
Longer lasting than previous RE71Rs? That might not be saying much, especially compared to the NT01. .
Old May 27, 2022 | 03:19 PM
  #1502
lv05evo's Avatar
Originally Posted by kaj
B-stones, in my size, are $100 more, per set, than NT01.
I'm good with that if they are faster and wear anywhere near as well.
I don't remember 100% but the old tires where good for autocross but not road course due to heat tolerance? Maybe someone who knows can correct me if I'm wrong.
Old May 27, 2022 | 08:04 PM
  #1503
kaj's Avatar
kaj
I got one, maybe two hot laps before they needed to cool down. They were a really good time attack tire, also good for autocross. Horrible for full length hpde sessions, especially on heavier, high-powered cars.
I never ran them long enough to go bad, but if I remember reading right, they heat cycled out pretty quickly. Usually long before they ran out of tread.
Old Jun 1, 2022 | 01:20 PM
  #1504
Lumpy Sticks's Avatar
5 Year Member
Shiny new parts are starting to show up....
Old Jun 1, 2022 | 01:21 PM
  #1505
RazorLab's Avatar
Nice, looking forward to how you like those.
Old Jun 1, 2022 | 01:32 PM
  #1506
5 Year Member
I think I am more excited to see how this 315 square setup is going to work! Next race is in 2 weeks. Will be installing the coilovers this weekend and will report back.
Old Jun 1, 2022 | 02:25 PM
  #1507
Dallas J's Avatar
Veteran: Army
Oof, the 315 A052s have gotten damn expensive. 2gs a set.
Old Jun 1, 2022 | 05:28 PM
  #1508
Grimgrak's Avatar
I would have looked into get a set of tractive active dampers made from core having driven ttx's and tractive-ace
Old Jun 1, 2022 | 06:06 PM
  #1509
5 Year Member
Rt660s are just about there too. It would have been $1800 shipped to my door if I got them from tire rack or discount tire. But my tire guy hooked me up. $1500 mounted and balanced.
I'm not going full race car just yet. Maybe for my next set I'll try something way overkill haha. I drive the car a decent amount around town (5000 miles a year) so I wanted something decent on the street and better than stock on the track.
Old Jun 1, 2022 | 07:47 PM
  #1510
5 Year Member
Got the coilovers all pre set and ready to go on. Got confirmation my tires arrived today at the tire shop. My 2 wheels and rear toe arms showed up. Tomorrow my camber plates should get here. Going to be a busy weekend.
Old Jun 2, 2022 | 11:02 AM
  #1511
Crzykdd's Avatar
remind me what wheels again...?
Old Jun 2, 2022 | 11:10 AM
  #1512
RazorLab's Avatar
Those are Apex SM-10 18x11
Old Jun 2, 2022 | 11:11 AM
  #1513
RazorLab's Avatar
Not sure if you are upgrading your sway bar links in the front but people have been having an issue with bending them when using the Ohlins because of the position of the end link mount on the strut body. Something to watch out for.
Looking forward to the fitment overall as I am leaning towards 18x11 and 315's after this season.
Old Jun 2, 2022 | 11:37 AM
  #1514
5 Year Member
Yep thats them
I did not know that. Interesting. I will see how everything lines up once it goes together. I am almost wondering if people arent clocking the shock body correctly? If things look weird, I will go aftermarket or just make my own. I was planning on putting my car on one of the lifts at work to do the sway bar so that would be the perfect time.
Old Jun 2, 2022 | 12:58 PM
  #1515
RazorLab's Avatar
It's more about the length of the bracket on the strut I think. You can only clock them one way since there is a tab that goes into the hub mount.
The front sway bar is a piece of cake to install. It literally took me longer to take the undertray off than install the sway bar.
Are you also installing SPL lower control arms? If so, most adjustable aftermarket sway bars hit the LCA. I run the Cusco sway bar which only has one hole and it just BARELY touches the LCA at full lock. With the steering centered, there is probably 2-3mm clearance.
