Mk V Supra - My Evo's Replacement?
Old Sep 21, 2022 | 07:26 PM
  #1906
kaj's Avatar
kaj
Originally Posted by Lumpy Sticks
I may or may not have just invested in a big chunk of the Verus aero catalog.....
@razorlab Hope you are feeling better!
@kaj Throw an e20 mixture in there and I bet you see over 400whp with that downpipe.
What's needed on the car to run the ethanol? Sounds like a hassle to make sure the mixture is right, though. 😔
Old Sep 21, 2022 | 07:28 PM
  #1907
RazorLab's Avatar
Car can run it stock. Manual says up to E25.
E20 is only 10% more than normal pump gas E10.
Car uses STFT even at WOT to compensate.
Old Sep 21, 2022 | 07:37 PM
  #1908
kaj's Avatar
kaj
That's kinda cool. Since I can't run 93, at least I can do that. If I wanted to do the math anyway. I've grown lazy as I get older.
Old Sep 21, 2022 | 07:41 PM
  #1909
Lumpy Sticks's Avatar
5 Year Member
Exactly this^^^^^^^;
I technically run a 23-24% mix in my car (2 gal e85, 8 gal 91). You can tell the difference, especially on hot days. Just make sure to run the tank low enough to get 10 gallons in there everytime and the mixture should stay consistent.
Old Sep 21, 2022 | 08:40 PM
  #1910
kaj's Avatar
kaj
Meh. That's the headache I used to deal with before flex fuel.
We'll see. Good info, guys. Thanks.
Old Sep 21, 2022 | 08:50 PM
  #1911
5 Year Member
You are thinking way too much into this. Think of it as our cars are flex fuel but only until 25% (people do 30% all the time). Try it one tank and see if you notice a difference and see if the difference is worth it. Not going to hurt anything.
Old Sep 21, 2022 | 09:07 PM
  #1912
kaj's Avatar
kaj
I know. I just mean that I won't know the % unless I run it down and start over. Then it's off if I'm running around and top off then have to start over, etc.
I'll do it just to try it out, of course. Maybe anytime I run to the gas down far enough to try again.
Old Sep 21, 2022 | 09:30 PM
  #1913
5 Year Member
Thats exactly my point. Stop thinking about the %! The car will auto adjust. You can be off % tank to tank and it will be fine. Our gas sucks is the point, bad enough it pulls timing on the stock map. Any extra ethanol will only help.
Old Sep 22, 2022 | 07:52 AM
  #1914
kaj's Avatar
kaj
91 is amazing. I dunno what you are talking about.
Old Sep 22, 2022 | 09:26 AM
  #1915
Construct's Avatar
Seems reasonable to run morning sessions with whatever is in the tank and then target 25% on subsequent fillups between sessions. Ethanol content will asymptotically approach 25% with each fillup between sessions, which conveniently follows temperature rise throughout the day.
Old Sep 22, 2022 | 11:06 AM
  #1916
5 Year Member
I forgot that they add some good stuff in to the gas up your way haha
I dont know.... I mean, I wouldnt run straight 91 at all on the track. I should pull up some of my logs so you can see how bad it pulls timing. Literally goes into the negatives. Since these cars target a load #, not a boost #, when they see detonation, they dump the timing and raise the boost to try to hit the target load. Its all bad when you dont have enough octane.
Old Sep 22, 2022 | 01:22 PM
  #1917
kaj's Avatar
kaj
Old Sep 22, 2022 | 06:10 PM
  #1918
RazorLab's Avatar
Even though I was a big E85 advocate, I have to say, I LOVE not having to haul that **** to the track all the time now.
Part of it is because I literally couldn't even fit it in the car anyway. lol
Not changing wheels at the track every morning is also awesome, and again, I couldn't fit another set of wheels in the car anyway.
Sometimes constraints are great.
Old Sep 22, 2022 | 07:32 PM
  #1919
kaj's Avatar
kaj
I'm having a great time. I grab my helmets and go. I no longer have to take the fuel containers to the gas station, fill them up, go get the trailer, attach it, bring it home, load up the fuel and tools, load up the race ramps, load the car on the trailer, drive it all out to the hotel to find a parking spot, then to the track. Also reverse.
Eventually, I will trailer the car, but it's really, really nice to not be doing it right now.
All this after I find a trailer that's easy to load, with the winch, and spots for fuel containers LOL
Too little too late?
Old Sep 25, 2022 | 05:29 PM
  #1920
RazorLab's Avatar
@kaj
https://www.ebay.com/str/gftp2013
