Coilover questions
Old Dec 7, 2016 | 11:34 AM
  #181
MrAWD's Avatar
Originally Posted by Construct
TL;DR: Spring rates don't change load transfer. Carefully distributing lateral load transfer between the front and rear outside tires is important for optimizing lateral grip in the front-heavy Evo. Suspensions are difficult.
Nicely said man!!
I repeated this part above just to add a bit more to it - distribution of the lateral load transfer is heavily affected by the drivers input as well. Changing your driving style can affect most of the cars out there and make them to behave on opposite side of what they were doing before. For example, almost any car can be made to push when guided with "proper" inputs!
Old Dec 7, 2016 | 11:58 AM
  #182
kaj's Avatar
kaj
Originally Posted by MrAWD
Nicely said man!!
Interesting point. I recently drove a kart that kicked *** for me (2nd fastest), but my buddy hopped into it and turned his slowest time of the day. The complaints he had sounded like abrupt-input issues.
Old Dec 7, 2016 | 12:14 PM
  #183
MrAWD
Construct
Dallas J
ReaperX
griceiv
Thanks guys for adding those detailed specifics
Old Dec 7, 2016 | 12:19 PM
  #184
MrAWD's Avatar
C'mon man! Just admit it! You broke the damn cart so he couldn't catch you!!
Old Dec 7, 2016 | 12:21 PM
  #185
kaj's Avatar
kaj
Nobody saw nothin!
Old Dec 7, 2016 | 12:26 PM
  #186
LetsGetThisDone's Avatar
Weight transfer doesn't depend on spring rates. Increasing your spring rates doesn't reduce weight transfer, ignoring minor dynamic changes in center of mass height due to suspension articulation.
When you hit the brakes and the car decelerates, load transfer to the front occurs even in completely rigid suspension setups (e.g. karts). For acceleration/braking it's a function of acceleration, wheel base, vehicle mass, and center of mass height. Stiffer springs result in less compression for a given deceleration, but only because the stiffer spring compresses less for a given load. The load transfer is still there even though you don't see as much suspension compression.
This is also incorrect: In steady-state cornering, lateral load transfer is a function of the lateral acceleration, track width, vehicle mass, and center of mass height. You can't reduce that load transfer with stiffer springs or bars (again, ignoring dynamic center of mass height differences).
However, you can influence how that lateral load transfer is distributed between the front and rear wheels by adjusting the relative balance of front and rear roll resistance. Increasing the rear roll resistance relative to the front will make the rear outside tire bear a larger portion of the overall lateral load transfer. The net lateral load transfer isn't changed, though, so that means the front outside tire now bears a smaller portion of that lateral load transfer. The opposite occurs on the other side of the vehicle, with the front inside tire bearing more load and the rear inside bearing less load (or even lifting up in the air).
The Evo is a front-heavy platform, so the front outside tire is naturally heavily loaded in a turn. Increasing rear roll resistance (springs and/or bars) relative to the front is therefore helpful to shift the responsibility for some of that lateral load transfer away from the outside front and toward the outside rear tire. Net grip is increased, not decreased.
This where street car experience differs from offroad. You put too stiff of a spring on the front and the car can't dive (especially in braking bumps) on the brakes, you will find a lack of front grip, especially in the mid and rear engine buggies. This is also on a surface where a lot less than adequate traction is available. I literally observed this. We moved to a different spring setup that had a lower rate through the middle of the travel, but also a higher bottoming rate, fixed the valving, and the car worked. It's a much different scenario, but it's where I learned, which is why input is welcome.
Same thing with sway bars. Helped tune a few trophy trucks where ditching the front sway bar and getting proper springs significantly reduced under steer. Put sway bar back on with new springs, understeer. Remove sway bar, reduce understeer. Tells me the swaybar reduces grip.
Old Dec 7, 2016 | 01:51 PM
  #187
Construct's Avatar
Now that sounds like fun. I wouldn't try to translate too much of that experience to a road-going, short-travel vehicle though. When your suspension travel is measured in feet you can no longer ignore height changes for your center of mass, or geometry changes due to dive/squat.
There's also something to be said for keeping the suspension on the compliant side over rough surfaces. For your off-road vehicle you want the suspension to soak up bumps under braking, not bounce off of them. With cars on smooth asphalt that's not as much of a concern. It can still be a problem on rougher AX lots, though. Dallas J posted some good videos of stiff springs causing braking problems on rough lots a while ago.
Again, RWD Trophy Trucks with travel measured in feet won't really translate well to our AWD cars on relatively smooth surfaces. Understeer and oversteer don't necessarily imply less grip or being slower. When I soften my RSB my car feels more neutral less prone to understeer, but I also go slower every time.
We can talk theory all day, but of course what matters is finding a setup that works with your own personal driving style. Just be sure to measure carefully to ensure it's actually faster, because I've been through a few configurations that felt faster but were actually slower for me.
Old Dec 7, 2016 | 02:01 PM
  #188
ReaperX's Avatar
MrAWD
Construct
Dallas J
ReaperX
griceiv
Old Dec 7, 2016 | 02:02 PM
  #189
Absorbing bumps generally comes down to valving in the shocks unless spring rates are way way off. Typically, an offroad car with not enough spring will rely to much on the shock, which will result in limited shaft speed (teams have data logged 600-700in/s on well setup vehicles), a very rough ride, and shocks that overheat quickly. Conversely, to much spring and you have to add too much rebound damper, which also overheats the shocks and makes the car feel like a pogo stick. Have to find the medium of springs/valving.
back to the street car discussion. I now have a better perspective in thinking that we are affecting load transfer % vs where I was yesterday.
Old Dec 7, 2016 | 02:33 PM
  #190
griceiv's Avatar
Seems like we're heading in the correct direction now.
I'd add that there are really two main factors to keep in mind with spring selection.
-load transfer due to inertial effects of accelerating the mass of the car
and
-load transfer due to road surface imperfections.
What Construct/Dallas said above is applicable to the first item, where springs do not change the amount of load transfer, as long as the road is perfectly flat/smooth.
now consider the load transfer effects due to bumps, whoops, ruts, etc. springs/bars absolutely do impact the amount of load transfer due to those things. lets say as an example you run over a 1" bump with only one tire and you have 1000lb/in wheel rates. that is going to transfer a huge amount of load (give or take 1000 lbs) to the tire that is on the bump even if the car is not accelerating in any direction. obviously not going to be good for maximum grip. go over that same bump with a 100 lb/in wheel rate and it's hardly noticeable.
the optimum compromise between controlling the contact patch geometry with stiff springs/bars and minimizing load transfer due to surface imperfections is going to depend on how smooth the surface is you're driving on and to some extent the speed that you hit those imperfections with. low speed cars on smoothish surface (autox) can run much stiffer than a non-aero road course car, and can run WAY stiffer than something that drives off road.
Old Dec 7, 2016 | 05:53 PM
  #191
amn_suazo's Avatar
When you hit the brakes and the car decelerates, load transfer to the front occurs even in completely rigid suspension setups (e.g. karts). For acceleration/braking it's a function of acceleration, wheel base, vehicle mass, and center of mass height. Stiffer springs result in less compression for a given deceleration, but only because the stiffer spring compresses less for a given load. The load transfer is still there even though you don't see as much suspension compression.This is also incorrect: In steady-state cornering, lateral load transfer is a function of the lateral acceleration, track width, vehicle mass, and center of mass height. You can't reduce that load transfer with stiffer springs or bars (again, ignoring dynamic center of mass height differences).
With your explanation of distributing roll resistance with a RSB, what would a bigger FSB do?
Old Dec 7, 2016 | 06:31 PM
  #192
MrAWD's Avatar
There will be no difference more or less when using a car that is somewhat balanced (or close to it). Same principles apply.
The major difference comes from the car like a stock EVO, which has extremely soft springs on both ends. Due to the weight of the front end combined with that low roll resistance, body leans so much during the lateral acceleration that geometry of outside wheel is very compromised (aka, positive camber gets to be quite large). Stiffening FSB helps a bit with increase of that resistance, so outside front doesn't gain original amounts of positive camber, which improves grip on that end. The good part of this change it that rear grip is increased as well (see original explanation above), so overall grip is increased on both ends.
Of course, once your FSB gets too strong/big, you will start loosing grip on that end. But I don't think we can get there with stock ride height and OEM springs.
Old Dec 8, 2016 | 05:45 AM
  #193
honda-guy's Avatar
here's my car on ohlins 12k/14k, whiteline front and rear swaybar, RCK, and at 3420 lbs competition weight, on hoosier A7 255/35/18. a bit of trail braking but the right inside tire barely touching the ground.
Old Dec 8, 2016 | 11:28 AM
  #194
kaj's Avatar
kaj
My inside, rear tire spends more time in the air than the ground, I bet
Old Dec 12, 2016 | 08:15 AM
  #195
Gah. Waiting on these things to show up is like pulling teeth LOL.
