Annnd this is one of many reasons I always delete drum based e-brakes on dedicated track cars lol.
Just sounds like a bit of un-luck in the adjustment after getting hot. Usually E-brake sees pretty much no heat buildup and why we do almost no service on them. Its 99% there to hold the car and using it in an emergency to actually stop is pretty dangerous (Tug the ebrake mid corner and see what happens
I would just replace the rotors and anything else that looks bad and follow FSM to adjust and send-it.
). I would just replace the rotors and anything else that looks bad and follow FSM to adjust and send-it.
ViciousLSD
close
- Join DateOct 2011
- LocationHouston
iTrader Positive Feedback100
iTrader Feedback Score(2)
Liked:600 Times in 499 Posts
I just ordered new stoptech rear rotors + EvoX front rotors + SS pistons + SRF.Originally Posted by Dallas J
).I would just replace the rotors and anything else that looks bad and follow FSM to adjust and send-it.
my question is what happened to the self adjustment of the drum pads? Shouldnt that work? unless my drum shrunk instead of elongating, it shouldnt grab. wondering if the parking brake mechanism needs a full refresh
BTW I had to keep the emergency brake pulled way into the turn. its pretty smooth and no lock, thats why I thought I may have different pads than you guys
kaj
close
- Join DateMar 2006
- LocationFresno, CA
iTrader Feedback Score(60)
Liked:824 Times in 685 Posts
Did you apply the E brake while stopped and the brakes were still hot?
ViciousLSD
close
- Join DateOct 2011
- LocationHouston
Quote:
at grid before that run i did test my handbrake but not park with it engaged. my pedal was getting mushy (or i'm extra paranoid now) so I checked on my backup brakes :POriginally Posted by kaj
Did you apply the E break while stopped and the brakes were still hot?
ViciousLSD
close
- Join DateOct 2011
- LocationHouston
So while shopping for rotors, I read that OE blank rotors has about 64 cooling vanes while 4lbs-lighter-Stoptech-like 'sport' rotors only has 34 cooling vanes. Has there been any discussion around this for track usage? I wonder if we should consider installing OE blanks for track... theyre cheap and easy to install
LetsGetThisDone
close
- Join DateOct 2013
- LocationLas Vegas
iTrader Feedback Score(1)
Liked:1,629 Times in 1,392 Posts
Quote:
Thats not an issue with drum ebrakes.Originally Posted by kaj
ViciousLSD
close
- Join DateOct 2011
- LocationHouston
Quote:
Theyre was an experienced track guy there with a camaro who insisted on learning his tire on the curb since he wont use the parking/ebrake, I guess theres something to itOriginally Posted by letsgetthisdone
Quote:
Yea, never use your ebrake after a session. Just put it in gear or use wheel chocks.Originally Posted by ViciousLSD
Some parking brakes use a drum and some use the rear caliper itself. I think GM uses the main caliper. You def dont want to set that between runs/sessions. I wouldnt set my drum e-brake between track sessions but between autox runs I have no problem.
ViciousLSD
close
- Join DateOct 2011
- LocationHouston
This seems like a good list. I just learned about "pad knockback" (#11). thats probably why i still felt some mushyness mid run. my hub/bearing are all good tho
https://nomoneymotorsports.com/2020/...akes-on-track/
ViciousLSD
close
- Join DateOct 2011
- LocationHouston
Quote:
I checked the camaro (pretty much every car these days) have drum ebrakes. some seat function in MBs (to get out of the car) needs atleast one click of the ebrake to work Originally Posted by Dallas J
kaj
close
- Join DateMar 2006
Quote:
to this day, I can not bring myself to do this..it's a phobia, or something Originally Posted by razorlab
Quote:
I have THE longest list of reasons not to buy a newer car. I'll add that to the Originally Posted by ViciousLSD
section LOLViciousLSD
close
- Join DateOct 2011
- LocationHouston
Quote:
I disconnected the clutch switch. I'll be honestly, 95% of the time, I forget when the car is in gear Originally Posted by kaj
Everyone that drives my car knows to never leave it it gear and never start with the clutch in. Cause I will be on you every single time! Aint need that thrust bearing wear unnecessarily.
But I'm the only driver on track and no problems with E-brake in AutoX. Front gets crazy hot but not rear.
