Philadelphia's Classiest Drunkards
Old Jun 12, 2012 | 06:37 AM
  #37336
chu's Avatar
chu
^I'm at 1.19s according to Marc's timer. My car was running 21psi, straight 93 pump, and street tires. Come at me Mike.
Old Jun 12, 2012 | 06:39 AM
  #37337
grillpt's Avatar
^ I was actually refering to his comment about dropping time on Thunderbolt, but really it applies to all tracks. As for Lightning, low 1:17's are some of my faster laps, I hope to turn some 16's at this upcoming event. 40lbs of boost, VIII turbo, pump gas, street tires.
Mike, you're not running on your starspecs?
Also, on a different note... Looks like Philly Region has the SM & T-SM/Sp guys running last again this Sunday. Total BS if you ask me... If that is indeed the case, I will not be going to Dover.
Old Jun 12, 2012 | 06:43 AM
  #37338
AlwaysinBoost's Avatar
^ 19's, and that's with me holding you back from upshifting and downshifting on T6 & T7. No doubt you'll be in the 17's once you work on those things we discussed and don't have an extra 185# in the car yelling in your ear.
Old Jun 12, 2012 | 06:47 AM
  #37339
Mr. MR's Avatar
I am running my Toyo RA1 from last decade, need to use them up, they are 17" - Robispec old set up. If they suck it I will throw on the star specs.
Chu you talkin to meh?? Better watch out for me when were out there, don't need you holding me up forgetting to point me by.
Old Jun 12, 2012 | 06:49 AM
  #37340
Mr. MR's Avatar
I have a question, watching your videos no one seems to rev match their down shifts. Am I missing something, is that not necessary? It is something I have always tried to do in my cars, was taught that somewhere I think by an instructor. Rev matching makes things much slower and complicated, so you guys do it or not? What about your drive-train, any probs?
Old Jun 12, 2012 | 06:56 AM
  #37341
honda-guy's Avatar
i always heel/toe rev match. saves the clutch and synchro and smoother weight transfer during braking and down shift. watch my video and look at the tach.
Old Jun 12, 2012 | 06:57 AM
  #37342
Your instructor was wrong. No need to rev-match, just jam it in there. IF it won't go in then push harder till it does.
I only upshift anyways, never down shift since it will slow you down. <-- pro tip right there!
Old Jun 12, 2012 | 07:06 AM
  #37343
honda-guy's Avatar
chasing Marc around. he was on Chu's A6 tires and i was on street tires on sunday 2nd session. you need to step up your game son if i can keep up with you on street tires.
our power/weight level is about the same cause i only pull on him slightly on the straight, mainly cause i'm drafting him. i was only running 20 psi in this session because of street tires.
Old Jun 12, 2012 | 07:24 AM
  #37344
chu's Avatar
chu
That was a fun event. That's the fastest I've ever driven at Lightning.
Old Jun 12, 2012 | 07:38 AM
  #37345
http://www.youtube.com/watch?v=FjYSCVUpfmc
that was the session you let me run Chu's tires but I was running them with the beat side on the driver side, so I didn't have the grip you did on your sessions. I am also on 19-20psi and you are roughly 300# lighter than me and running 275 Nittos and 24-25psi... With that said it did look like you were keeping up
Old Jun 12, 2012 | 07:55 AM
  #37346
BBS's Avatar
BBS
Any of you X guys feel like the 4b shouldve been a 2.4? Given the increased weight and all. Seems like they just cheaped out and changed the ratios instead.
Old Jun 12, 2012 | 07:58 AM
  #37347
chu's brother's Avatar
Probably because WRC is limited to 2.0 motors only. While Mitsubishi no longer have a factory team, there are other teams out there that uses the evo. Not sure about other forms of rally like IRC though. Just a thought.
Old Jun 12, 2012 | 08:00 AM
  #37348
oneday.js's Avatar
Granted I have no idea what kind of times my M will do in it's current configuration (i'd be happy with 1:20s), but 1:19s seem slow to me...I was doing 1:19s in a Spec E30 (168hp/2895lbs) on horrible, full tread RA1s. I was doing 1:22s in our $500 crap can (160ish hp/2900lbs) on Star Specs.
Old Jun 12, 2012 | 08:01 AM
  #37349
honda-guy's Avatar
^ that would have been a better motor. isn't the motor in the dodge caliber srt-4 2.4L the same as or similar to the evo X motor.
Old Jun 12, 2012 | 08:04 AM
  #37350
any of ya'll have advice on which aftermarket radiator to get? was seeing high 190's low 200 coolant times this weekend on low boost. WOuld like to finally upgrade my 120k mile OEM radiator.
