Philadelphia's Classiest Drunkards
Old Oct 13, 2010 | 06:12 AM
  #12376
turbotekray's Avatar
so who's corn fed horse did not want to start this morning?, it was 25 degrees here and my car did not want to start. literally took me about 2 minutes. i guess i'm done with e85 till spring.
Old Oct 13, 2010 | 06:24 AM
  #12377
dek0026's Avatar
Keep the faith ray
Old Oct 13, 2010 | 06:27 AM
  #12378
AlwaysinBoost's Avatar
Originally Posted by Mr. MR
Dude, lesson for you to learn, always check your tire pressures after each run (that's assuming you even adjusted them prior to running). When I checked the pressures you were anywhere from 2-7 lbs. more pressure than what I normally run. Tire pressure affects handling more than people realize, especially that amount over.
As far as the course, it was tight but challenging. If you look at the overall PAX results, the top 10 are the usual top 10 that we have in our region. So overall the course did not humble the "top" guys in the region. Maybe just you SM **** got humbled...... (I actually screwed the pooch too, but my dirty run would have given me 2nd in class and PAX, pisses me off because I barely hit it).
the tire pressure thing was a total oversight on my part. I don't know what i was thinking there. I heard Simmons say it was taken care of and I assumed I was good for the whole event... don't know why I thought that.
I guess the course is what it is. It just looked funny cause Steven beat me and Bob was 8th... which NEVER happens. He is usually a good driver. Judging by how everyone else did I agree with you.
Originally Posted by evremonde
Word. Feel free to yell at me if I ever sound genuinely cocky.
That said, i plan to pull another one out next time. Chu is hooking me up with some illest stickers and a chrome overflow tank firebird said thats worth .5 seconds
Dude, you better keep smack talking while you can cause you never know what will happen next event.
Old Oct 13, 2010 | 06:33 AM
  #12379
igo4bmx's Avatar
Originally Posted by dek0026
Keep the faith ray
i need faith in my own body-
both my shoulders are destroyed- 11 years of working out has done it.
benching last night i couldn't even stretch my arms out completely.
Old Oct 13, 2010 | 06:35 AM
  #12380
Keep the faith ray
I'm trying Dan
Old Oct 13, 2010 | 07:00 AM
  #12381
evremonde's Avatar
Originally Posted by AlwaysinBoost
It just looked funny cause Kenny was .6 seconds from beating me
Its ok, you'll get used to it eventually. (hows that for smack talk?)
I need help with tire pressures, I have no clue what I'm doing with them. Pete was yelling at me for being all over the sidewalls.
Old Oct 13, 2010 | 07:04 AM
  #12382
dek0026's Avatar
Originally Posted by turbotekray
I'm trying Dan
i was talking to josh about it on sunday and he seems to think the 4g63's have more trouble starting up than the 4b11 in the cold on e85 (or maybe it's simply the tuning). mine takes a few extra cranks but it starts in seconds. i wonder how it would be when it gets really cold......the winter blend should help it a bit though.
Old Oct 13, 2010 | 07:16 AM
  #12383
chu's Avatar
chu
4 tries.....
Can I use your Hoosiers at the next event?!!!
Old Oct 13, 2010 | 07:21 AM
  #12384
thats a good start... very good start. I would have added something about the fact that you were driving an underprepped BSP car on all seasons in SM, but you did good for your first attempt.
Tire pressures really need to be figured out with a tire temp gauge. I had one with me on Sunday but sadly it was malfunctioning. Hopefully I can get it working correctly before the next event on the 24th and actually adjust the tire pressure this time around. I can tell you that you're probably wearing the outsides too much because you're camber limited, but thats as far as I will go with help cause I have to maintain my edge.
Old Oct 13, 2010 | 07:27 AM
  #12385
evremonde's Avatar
No more all seasons, ps2's. And underprepped for BSP? ****, im under prepped for ST.
You will help me with my tire pressures ::jedi hand wave::
Old Oct 13, 2010 | 07:30 AM
  #12386
these aren't the droids we're looking for... wait, what?
Old Oct 13, 2010 | 07:32 AM
  #12387
evremonde's Avatar
wait, what?
what? what?
Old Oct 13, 2010 | 07:38 AM
  #12388
igo4bmx's Avatar
Kenny i'm going to fill my tires up with cement- should make them nice and stiff
Old Oct 13, 2010 | 08:50 AM
  #12389
Tims2006MR's Avatar
hopefully my gtworx springs will be in before the 24th, not that its going to help im still on a/s tires lol
Old Oct 13, 2010 | 08:59 AM
  #12390
Mr. MR's Avatar
what? what?
If your tire side walls look all scuffed up, you are rolling over the side wall. That is probably not enough camber and not enough tire pressure. If it were me I would get as much neg. camber as your set up will allow. This will make your car a little darty on the highway, but I lived with it for a long time. Keep in mind toe is what kills tires not negative camber. Next I would increase your tire pressures. I think a good starting point would be 38 front 36 rear. I actually only mess with R compounds now, but I think that would work for street tires. Prior to doing your run you should mark your tire sidewalls with some white shoe polish (that may be in the tech box or in the truck, but I would just bring my own if I were you). The mark should be where the tread meet the side wall. After your runs you need to look and see if the shoe polish gets rubbed, that will tell you your tires are rolling over or you are good. An increase in tires pressure will stiffen the tire sidewall and help fight against this happening. The other thing to consider is how you think the car feels. I would establish what it takes the tires to stop rolling over and then tweek that with how you like the car to feel. If you really play around with it you will see how much tire pressure affects a run.
BTW if you can't get the alignment still do the tire pressure.
All of you guys running Autox should be messing with your tire pressures every time you run. I hope the guys who are not changing tires are not running the course with the same pressures you run on the street. If so, you guys are wrong and need to add some pressure.
