razorlab's simple build(s)
Most of the groups I run with are self-tech.
But seriously, there are a bunch of things with the surge tank I want to change in the near future. The actual lines running under the back seat cushion to the tank top is the first thing I want to change to running to bulkheads and under the car to the tank top.
The car has got to the point of where I told myself I wouldn't get to with this one compared to my Evo 8. Oh well, so is life.
Also going to probably put a roll-bar in it very soon as well.
It's scary fast on the street. I cannot imagine what it's going to be like at the track. Hopefully I will find out in Feb-March.
of course, 59580004 right?
Code:
<scaling name="Load_div_2" units="Load" toexpr="x*2*10/32" frexpr="x*32/10/2" format="%.1f" min="0" max="300" inc="1" storagetype="uint8" endian="big"/> <table name="Disable STFT Calcs below this Load" address="57d6c" category="Misc" type="2D" scaling="Load_div_2"> <table name="RPM" address="6233e" type="Y Axis" elements="14" scaling="RPM"/> </table> <table name="Enable STFT Calcs above this Load" address="57d7e" category="Misc" type="2D" scaling="Load_div_2"> <table name="RPM" address="6233e" type="Y Axis" elements="14" scaling="RPM"/> </table>
any way you could get this for 2011 GSR? let me send you some paypal.
Sorry to hijack your thread @razorlab
Took the car out yesterday as I will be away from home for two weeks.
By the time I got back home the turbo was smoking way more again. So bad that I had to throw my clothes in the laundry because they reeked of burnt oil. I also felt a little light headed as well.
So not what I just spent $15k+ and waited a year of my life for. Once I get back I’ll figure out what to do next. Maybe I’ll go back to a stock frame.
New cars are looking good again. Wah.
after all the modding and stuff i just had to get away from doing power-adders. for me, not worth the continuous worry and headache, and i just run in a lower class now. i'll have a separate track tune though.
So here is a new one. Something with the Radium pump hanger came loose and is banging around inside the tank now. Every time I come to a stop it clanks around.
Fun times.
I'll pull the hanger tomorrow to see what's up.
Fun times.
I'm guessing your PTE is a BB unit? I can't even count on both of my hands how many of my friends have had their BB PTE turbos chew oil and/or blow up within 2k miles. I had a friend go through 3 BB PTEs in one year. I don't mean to bash on PTE but this is the reason I always prefer BW or Garrett turbos over PTE. Their JB turbos don't seem to be nearly as faulty.
Got a new video camera the other day. It's a Rylo 360 video camera. It's pretty awesome. You basically record with it stationary in the car and it records a full 360* view which you can then edit after the fact with their app. You can do cool things like follow subjects, look at different points, etc. Has really great stabilization, etc
It's going to be awesome on track! The audio kind sucks, gets blown out easily as it seems overally sensitive, this was with the windows closed as well. I might try stick some foam on the mic openings.
I'm still playing around with the editing settings and such but it shows promise for sure.
That looks really cool. Can you edit the video so you don't always have to do a 180* pan to cut between the rear shot and front shot? So you just snap back to a straight forward angle again?
I think I figured something out today. I did an oil change. Before today my dip stick read between the two dots and the car was barely smoking at all, I could actually drive around with my windows down.
Today I did the oil change and it's filled right before the second dot. Now my car smokes again!
Could it be that when it's fuller it backs up the turbo oil return? So weird.
Yes, it could be it.
Try to enlarge the oil return lines from turbo to the sump if you haven't done it already.
Should be at least -10an if not bigger.
Make some in car videos once you get it out there. Or if you ever "take a trip to Mexico"
