Utah Evos
Old Feb 4, 2009 | 12:38 PM
  #19996
UT_Evo's Avatar
Ryan, did you need something? I'm at work. So I can't answer my phone, you can text me though.
Old Feb 4, 2009 | 12:46 PM
  #19997
33's Avatar
33
My Supervisor asked if I did installs or knew any good car audio shops. Couldnt remember where you went.
Old Feb 4, 2009 | 01:08 PM
  #19998
UT_Evo's Avatar
Did you remember? It was car concepts, and they're even better now that they have a dedicated really nice new building downtown. If you tell him to ask for Cory or Travis and tell em Jake sent em they may even get a slight discount.
Old Feb 4, 2009 | 01:54 PM
  #19999
IXrs's Avatar
Originally Posted by ~booster~
yo, i got a set of these in hyper gun metallic in near mint in 18 x 9 w/nitto invo
they look hella sicky on x's.
those do look good. Are you seeling them or something?
Old Feb 4, 2009 | 02:09 PM
  #20000
Evolution IVGSR's Avatar
Man I think for a Evo X you should have at least 9.5" wide wheels for the X personally I would like 10" or 10.5" for aggressiveness haha but thats just me and I like aggressive If anyone it thinking of Rotas go 18x9.5 I think they have a few good ones too...
Old Feb 4, 2009 | 02:20 PM
  #20001
33's Avatar
33
hey thanks, jake
Old Feb 4, 2009 | 03:18 PM
  #20002
Fairclough's Avatar
Autorama is March 27th-29th @ Southtown Expo Center. Who's going besides me?
Old Feb 4, 2009 | 03:34 PM
  #20003
UT_Evo's Avatar
Bleh, Autorama has been awful the few times I've been... Not me!
Old Feb 4, 2009 | 03:37 PM
  #20004
IXrs's Avatar
Yeah, I like so many, its hard to decide which ones. The rotas' are still at the top of my list thus far.
I will be going down. I havent been to one yet, so i'd like to check it out.
Old Feb 4, 2009 | 04:52 PM
  #20005
wesside's Avatar
you bish you never answer your phone anyways
Old Feb 4, 2009 | 05:41 PM
  #20006
I will probably go for fun as always
Old Feb 4, 2009 | 05:45 PM
  #20007
Fairclough's Avatar
I put some stars on your cars! You need to add more pics.
Old Feb 4, 2009 | 05:46 PM
  #20008
IXrs's Avatar
I was just checking out the "specialty-x" catback, it looks to be pretty good, and they got some significant hp increase from it.
http://www.specialtyx.com/catbacks.htm
Old Feb 4, 2009 | 06:21 PM
  #20009
UT_Evo's Avatar
You always call me to say stupid ****, just because your fingers are too big to push the buttons on your phone to text
Old Feb 4, 2009 | 06:30 PM
  #20010
gear head's Avatar
I havent even checked my email yet sorry. I've been having super bad left side pain around my rib cage been in pain all day. Do you think I should have the alt-map tables scaled out too?? And no I didn't know you could only adjust the "high gear range" gosh I was trying to figure out what tables to touch & leave alone.
Yes the mac valve is a 3port
Bummer, hope all is well.
The thing about scaling is if you change the scaling on one map in a catagory(timing, fuel, boost or whatever) they all change in that catagory. Yes, I would rescale the load on fuel & timing
If you stay on a non_tephra ROM the "low gear tables" will work....Tephra is fixing this in the next versionFor the most part you can get away with adjusting these tables for load based boost...Boost desired engine load, Boost control load offset, Base wastegate duty cycle, turbo boost error correction, boost load cut..the others are pretty much for fine tuning the system.
I thought it was a 3-port...in that case you will NOT want to hook it up like the diagram posted. Check the GM 3-port thread & hook it up the same way
