Let's see your fully tuned timing maps
Old Feb 2, 2013 | 04:11 PM
  #2086
MercenaryX2's Avatar
Sorry for no clarification. That's from an VIII.
Old Feb 2, 2013 | 04:59 PM
  #2087
dolphin888's Avatar
That is not so bad then, if it's on stock turbo... Of course there is too much advance at peak boost range (probably over MBT), but going to the redline timing looks alright for me.
Old Feb 2, 2013 | 05:07 PM
  #2088
Dragracer187's Avatar
did you log the car, did it knock? or any other problems? Did you check if it was advanced past MBT? How did you check that it is too much timing?
Old Feb 2, 2013 | 10:28 PM
  #2089
Yeah I had about 2 counts of knock at peak then 1 all the way to redline. The tuner has no clue how to tune. He keeps tuning for knock.
Old Feb 3, 2013 | 12:36 AM
  #2090
domyz's Avatar
X2 i agree,
from what we usually see this is overall a smooth well construct map
Old Feb 3, 2013 | 07:07 AM
  #2091
ExViTermini's Avatar
Too bad his bottom end won't be smooth and well constructed if he keeps running it.
Old Feb 3, 2013 | 08:25 AM
  #2092
dolphin888's Avatar
OK, what's wrong in that map in your opinion?
Old Feb 3, 2013 | 08:41 AM
  #2093
domyz's Avatar
Old Feb 3, 2013 | 11:19 AM
  #2094
ReaperX's Avatar
Too aggressive I would say for a stock bottem end.
Old Feb 3, 2013 | 11:32 AM
  #2095
domyz's Avatar
This guy needs a dyno run.
Old Feb 3, 2013 | 11:42 AM
  #2096
dolphin888's Avatar
Too agressive all over? At all RPM range?
Old Feb 4, 2013 | 02:55 AM
  #2097
The whole map is bad dude. Too much timing at spool up, too much timing at redline. It knocks on e85 and isn't smooth. Its a crap map. BTW this WAS tuned on a dyno.
Old Feb 4, 2013 | 04:40 AM
  #2098
dolphin888's Avatar
Come back later and show final map of that car.
Old Feb 9, 2013 | 09:47 PM
  #2099
211Ratsbud's Avatar
ive been working to establish trends in a clear manor . More experimenting. I'm pretty sure my spool timing is lacking a few degrees
s2 cams
skunk2 ported intake manifold
stock exhaust manifold
HTA 71 with 84 cover and intake tube
type s bov
jmfab intercooler
Im gonna work on getting the spool timing back in, rough 2-4 degrees
I thought I had more timing in there at peak load but im gonna work on that ramp! peak load at 3750 - 340 ish
7500 - 270ish
Old Feb 10, 2013 | 12:15 AM
  #2100
domyz's Avatar
Originally Posted by 211ratsbud
Hey guys hows this look? 350-360 load @ 3750-4k down to 260-270 load by 7k
s2 cams
type s bov
jmfab intercooler
Looks good 211ratsbud. To me your spool area from 100 to 160 low RPM doesn't lack timing. You could try more, but what I can say is that my VIII starts to knock at even lower timing / 13-12.5-12.0 AFR.
