Let's see your fully tuned timing maps
Old May 7, 2013 | 04:11 PM
  #2191
r3dtr1ckz's Avatar
Originally Posted by ToddRhodes
Stop running boost, get tuned, send oil sample to Blackstone Labs to check for bearing junk in your oil.
Sorry dude That is aggressive timing for sure. How much boost? Other mods?
the boost was at 20, but i turned it down to 15 recently. 3065 turbo kit, 272 cams, 255 walbro, no cat, 02 dump, aquamist system ( currently off ). Stock injectors, stock motor. Car originally made 504whp 449tq before my aquamist junction box went, so my tuner supposedly "detuned" the car for me until i got a new one, and pretty much went missing, so ive never really messed with the car since.
Old May 7, 2013 | 04:14 PM
  #2192
211Ratsbud's Avatar
Well there's some facts that make a difference. .. How about a log?
Old May 7, 2013 | 04:22 PM
  #2193
r3dtr1ckz's Avatar
I was waiting for the spec ops cable to hook up my aem to evoscan before i logged it, supposed to get it on thursday or friday, also my knock sensor is disabled from what im seeing lol. Here was my dyno sheet when i was making 504
Old May 7, 2013 | 07:52 PM
  #2194
Raptord's Avatar
Originally Posted by r3dtr1ckz
Havent really touched my car in 2-3 years, this was the map that was left on it from the guy who tuned the car, im sure its a disaster, just started learning about tuning recently, so any help would be greatly appreciated.
Too much timing at peak torque for pump gas. Transitions need work too.
Old May 8, 2013 | 04:36 AM
  #2195
r3dtr1ckz's Avatar
When you say peak torque, are you looking in the rpm range? Or just the load? I see peak torque mentioned a lot on this thread and I'm trying to fully understand where on the timing map I should be looking.
Old May 8, 2013 | 06:07 AM
  #2196
Raptord's Avatar
Peak torque is usually around the area where load is at it's highest.
Old May 8, 2013 | 09:53 AM
  #2197
killerpenguin21's Avatar
heres my latest and greatest.
makes power too.
Old May 8, 2013 | 10:26 AM
  #2198
Raptord's Avatar
That's a purdy map Mr. Penguin, makes me want to go play with mine some more
Old May 8, 2013 | 11:08 AM
  #2199
evo8426's Avatar
It has been quite some time since I last posted mine. This is not meant to be an all out power tune. I did that in the past and had my fun but now I don't care to spike 400tq and possibly put a rod through the block. I've got a ton of runs repeating these numbers time and time again but just one graph is good enough for me. (Since its not dyno and tuning results )
Megan o2 , AMS TBE with resonator, ETS 3" FMIC, Nisei LICP, Kelford 272s and beehives, headstuds, STM 3" intake pipe with Vibrant filter inside stock airbox, ported intake manifold, Walbro, PTE 1200s, stock BCS with upgraded boost pill, Stage 2 Comp Clutch, and stock turbo on speed density.
Old May 8, 2013 | 11:10 AM
  #2200
r3dtr1ckz's Avatar
Does this look any safer for 93?
Attached Thumbnails Let's see your fully tuned timing maps-screen-shot-2013-05-08-2.07.52-pm.jpg
Old May 8, 2013 | 12:19 PM
  #2201
Anarchy99's Avatar
What the poop?
Move to V7 at least and get a pro to rework it. Timing should never go down and then up again at redline.
Old May 8, 2013 | 12:51 PM
  #2202
211Ratsbud's Avatar
If your doin wi/ meth you need a failsafe set up.
Old May 8, 2013 | 01:03 PM
  #2203
211Ratsbud's Avatar
Nice I like the color it's pretty lol
Old May 8, 2013 | 01:55 PM
  #2204
it should be...its been 3 damn years in the making
im struggling to tweak the fuel now tho...having trouble compensating for the delay of my wide band (which shouldnt be terrible because im logging via serial) and finding that dip at peak torque.
Old May 8, 2013 | 04:27 PM
  #2205
r3dtr1ckz's Avatar
no more meth, just pump. I just loaded the stock map for my car instead to be safe, and play with it from there.
