Let's see your fully tuned timing maps
Old Oct 28, 2010 | 08:21 AM
  #661
Raptord's Avatar
Most likely to hold more boost between shifts.
Old Oct 28, 2010 | 09:19 AM
  #662
Jack_of_Trades's Avatar
You generally will stay above 150 load during a quick shift. If you want to hold boost between shifts you need to NOT close the throttle plate. To do that you just need the Tephra No-Lift-To-Shift feature. Some do it old school still too. That is strictly a launch/boost building area that he adjusted. You most definitely will pass thru that area under certain circumstances. That's what the Tephra V7 launch maps are for.
Old Oct 28, 2010 | 09:46 AM
  #663
Raptord's Avatar
Guess I don't shift fast enough then
Old Oct 28, 2010 | 09:55 AM
  #664
SyZyGy1394's Avatar
Originally Posted by mt057
I am not slowly rolling on to the throttle after switching gears. I am slow to shift though. It takes me roughly .6 to .8 of a second btwn 100% tps on my data logs. I tried lowering it help keep the turbo spooled btwn gears. I need to reduce a little more timing out in the 200 range to make it pretty smooth timing transition even when shifting. I never see that area in DD. I am going to keep testing it out at the drag strip vs the normal timing and see if I find any gain. If not I will use the normal timing in that area. I am not trying to shoot flames ect. Just trying to improve my 1/8th mi. times. I am trapping 91.6mph with a horrible 7.7-7.8 et.
Ahh I kinda figured this map wouldn't be used on any kind of road course action.
Old Oct 28, 2010 | 10:54 AM
  #665
evo8426's Avatar
Here is my timing map. I hit 26psi hold 25 through 5000, drops to 24psi and then tapers to 21-22 at 7000. At peak torque it is 11.6 afr and drops to 11.4 at 7000 on pump 93. I use the NGK Iridiums gapped at .022
Old Oct 28, 2010 | 12:31 PM
  #666
mt057's Avatar
I am going to try NTLS and the launch maps this weekend. I have been nervous to try them out lol. I have since put the timing back to original form. Thank you for the responses/help everyone.
Old Oct 28, 2010 | 01:09 PM
  #667
Benja's Avatar
Originally Posted by evo8426
why do you have the timing set so retarded in the 4000-7000 and 0-140 load range? there is no way i would want my car shooting flames.
ill post my map up later on when i get out of class, 26psi on stock turbo 11.6afr.
Just playing around to get some nice flames on gearchange/back off.
Dont recommend it under 3k, affects drivability just a little.
Yes NLTS is the better option, I'll just wait til my EGR is blocked off and get the ALS working.
Old Oct 28, 2010 | 01:19 PM
  #668
boosted91t's Avatar
I was nervous at first, but that dreaded clunk when shifting everyone including myself complaned about, I have not heard it since the day I went to NLTS. Its soo smooth now.
Old Oct 29, 2010 | 06:38 AM
  #669
One of the biggest myths is that NLTS is 'worse' abuse on the drivetrain when in reality a lightning fast NLTS shift is less severe. Allowing more 'preload' (for lack of a better term off the top of head) on the gearing, then SLAMMING the gears back together will increase your chances of damage.
Old Oct 29, 2010 | 07:13 AM
  #670
mifesto's Avatar
EvoScanDataLog_2010.10.29_07.17.57.zip
EvoScanDataLog_2010.10.29_07.20.50.zip
here is my log i ran this morning. boost is set about 23 psi and falls to 21 up top. AFR is about 12's in midrange, falling to 11:5 up top. it seems when i start my 3rd gear pull around 3500rpm, i get almost no knock. when i start around 2500rpm before spool, maybe the lean spool and high timing is causing knock and actually carrying that knock into my midrange.. thats my hunch atleast. i have alot more work to do to chase down this knock but wanted some feedback so far.
Old Oct 29, 2010 | 07:34 AM
  #671
Raptord's Avatar
Would you mind elaborating a bit JoT? Not sure I follow you there. Are you talking about NLTS on v7 or straight up NLTS with no ecu mods?
Old Oct 29, 2010 | 08:43 AM
  #672
mt057's Avatar
If the smoothing can not fix you know down low. You might be in the same boat I was and need to raise your know threshold down low. I had tried smoothing and reduceing timing etc., but for me it never seemed to go away so I raised the threshold and its gone.
Why such high timing at idle. I though that was mainly done to help compensate for large cams.
I think that JOT was refering to the nlts mod and not the old school way, although I could be wrong.
Old Oct 29, 2010 | 09:26 AM
  #673
Egolution's Avatar
+10
i fell that i abuse to less if i use NLTS
1)less abuse
2)BOOST not fall to 0 psi between shift
3)the car keep desplacing.
i am a NLTS adicct fells like you have a dogbox its just a perfect shift and less chance to fail shifting or blow engine overrev...
Old Oct 29, 2010 | 10:19 AM
  #674
mifesto's Avatar
i bumped idle slightly and really helped smooth out the cam lopyness....
do you think lean spool is giving me trouble in the mid range? sometimes i get clean runs but when i get "messy" runs, its the peak torque area that i get most of my knocks.... im going to try disabling lean spool and i hope i dont feel any noticable turbolag
Old Oct 30, 2010 | 01:07 AM
  #675
Egolution's Avatar
Thumbs up
you gona love tune your car without LSU more acurrate AFR and just adjust your afr in the spool area to heat the turbine enought to get fast spool 12.5 12.9
for me 12.5 its good...
