Let's see your fully tuned timing maps
Old Oct 13, 2010 | 03:21 AM
  #631
VGergo's Avatar
and a n00b quest, why are in evo 9 edm stock rom 3 high and low octane timing map ? I did a log and seems like using only one how it should. also in tehpra v7 edm rom has only 1 timing map.
Old Oct 13, 2010 | 06:26 AM
  #632
Appauldd's Avatar
Your timing looks pretty good. It can use a little smoothing here and there, but over all....you are doung well.
What about your AFR?
As for the question about 3 timing maps...They were discoverd to basically be the same thing just called for by different parameters (if my memory suits me well). Thus, all are usually made to be the same. V7 eliminated this by making the maps the same in the background (saves some work). At least I believe that is what is was all about.
Old Oct 13, 2010 | 06:40 AM
  #633
Jack_of_Trades's Avatar
Its been a while but I can't remember if the 3 maps had anything to do with the three ACD settings (gravel,Tarmac,snow). I could be 200% wrong though lol, it's been a while since we didn't have tephra mods haha.
Old Oct 13, 2010 | 07:34 AM
  #634
mifesto's Avatar
Originally Posted by donour
I suppose my timing maps is probably never going to be "fully tuned", but here is one from today.
Example pulls here: https://www.evolutionm.net/forums/ev...no-5500-a.html
d
man your timing at spool up is really low (atleast compared to mine), maybe you can add abit to improve midrange torque alittle... then again im trying to reduce mine as i get some knock in the mids
ill post my revised timing chart when i go home
Old Oct 13, 2010 | 07:35 AM
  #635
Raptord's Avatar
Isn't #1 for warmup, #2 main map and #3 for a fault?
Quote from Merlin's tuning guide:
The Evo7 and Evo8 have one high octane ignition map while the Evo9 has 4 high octane ignition maps. Map #1 is used when the engine temperature is below 149ºF. Map #2 is used as the normal ignition map engine warmed-up and no fault conditions. Map #3 is used in the event of a major sensor fault for example a MAF failure. Map #4 has more cruise timing and a block or retarded timing, its use is currently unknown.
Old Oct 13, 2010 | 07:48 AM
  #636
mrfred's Avatar
On Evo 9s, the three maps are related to whether MIVEC angle is steady, increasing, or decreasing.
Old Oct 13, 2010 | 08:59 AM
  #637
VGergo's Avatar
thank you ! Afr : 12.7-12.5 spool up, 11.7-11.6 @ peak than slowly tapper to 10.9-11 until 7000rpm.
Okay, so by the V7 tuning an Evo 9 only by 1 timing map is much simple
Old Oct 13, 2010 | 10:56 AM
  #638
Appauldd's Avatar
On 100 octane fuel you have a little room to go a little bit leaner up top. Try to hold mid 11s from peak load to top rpm.
To gain a little low end torque, richen the mixture a little bit more from just after about 5-7psi boost until peak load. (like 11.3 or so). The added fuel gives a little longer and cooler burn that helps torque.
Back on topic TIMING....cough, cough.
Old Oct 13, 2010 | 01:57 PM
  #639
VGergo's Avatar
thank you, will try it !
Old Oct 25, 2010 | 08:47 AM
  #640
Egolution's Avatar
evo IX FPred 64mm, gsc s1, 50/50 meth work in progress
thats just my number 08 ROM uploaded in my car.
Stock block.
GSC S1
FP red 64MM
Works Exhaust.
Injen Pipes
Greddy intercooler
AEM W/M Injection Kit. (boost juice 50/50)
11 psi actuator. 28.5 29 psi peak and tapering to 26 psi
im steel working on the map... Methanol is the best choice for de crappy Fuel of my country...
im still smothing my AFR and giving more timing
any recomendation ?
Attached Thumbnails Let's see your fully tuned timing maps-work-progress.jpg   Let's see your fully tuned timing maps-work-progress-afr-.jpg   Let's see your fully tuned timing maps-log.jpg
Old Oct 25, 2010 | 12:58 PM
  #641
mt057's Avatar
I would think that it could take some more timing from about >6000rpm. What size jets are you using?
Old Oct 25, 2010 | 01:11 PM
  #642
Egolution's Avatar
the bigger jet size..
thanks for recomendation im steel tweaking more more timing...
with that setting the cars fells fast and in dyno charts around low 400 hps
Old Oct 25, 2010 | 05:43 PM
  #643
wizzo 8's Avatar
Stock block.
GSC S1
FP red 64MM
Works Exhaust.
Injen Pipes
Greddy intercooler
any recomendation ?
Yes more timing and maybe more boost or just more boost maybe. What octane fuel?
Old Oct 26, 2010 | 06:19 AM
  #644
Egolution's Avatar
91 or less oct. in my country...
in result i cant espect the same numbers of USA.
Old Oct 26, 2010 | 08:49 AM
  #645
Stradag's Avatar
21-22 psi tapering to 19.5
tephra v7, ix turbo, hks 280 cams. pte 1200cc, full exh. fp intake pipe, ams balance shaft delete, muse uicp, xs pwr fmic, xspwr licp grimmspeed 3 port 93 oct gas
If I try to do a log starting from 2500 rpm or even 3000 rpm I get knock right away cant figure it out. AFR is around 11.7 tapering to 11.3.
p.s. this is not a english racing tune. getting a english racing tune if I can not figure out knock by myself.
