Ams Evo Cam Test
Old May 8, 2008 | 03:40 PM
  #121
Jeeperjunior's Avatar
Subscribed!! I'm getting ready to buy cams... So I'll wait to see what happens.
Old May 8, 2008 | 04:24 PM
  #122
JC evo1's Avatar
Why are the graphs all scaled differently? It would be easier to compare if you kept the scaling on all graphs the same.
Old May 8, 2008 | 04:27 PM
  #123
Guerillah's Avatar
It looks like the FP 4R is close to the same specs as a JUN 272, should be interesting...
Old May 8, 2008 | 05:28 PM
  #124
jhanksevo's Avatar
cant wait to see S2 results
Old May 8, 2008 | 05:42 PM
  #125
evovin's Avatar
Old May 8, 2008 | 05:48 PM
  #126
wshihdnevo's Avatar
Same here. The TURBO mag will prob come out before we see it here though.
Old May 8, 2008 | 05:53 PM
  #127
Cirrusly Evolvd's Avatar
The second mag is already out, and the S2 cams are not in that one. Still a good write up though...more info than I could've imagined.
  #128
2k4EvoVIII's Avatar
Old May 8, 2008 | 06:22 PM
  #129
navysandsquid's Avatar
I just ordered the kelford 272s I wanna see what the outcome would be
Old May 8, 2008 | 06:23 PM
  #130
CanadianTSi's Avatar
All graphs are scaled the same, they all go up in 50hp increments...
Its just the first graph doesn't goo all the way to 600 because it would just be alot of empty space...
Old May 8, 2008 | 06:48 PM
  #131
wshihdnevo's Avatar
Originally Posted by 2k4EvoVIII
Old May 8, 2008 | 11:26 PM
  #132
JC evo1's Avatar
they might go in the same increments but their not scaled the same, look at speed along the bottom, one graph starts at 15mph, one starts at 0. All i was trying to do was overlay the different curves to get a comparison from Tomei 280 vs Crane. If the graphs were scaled the same on both mph and power axis this would make it very simple to overlay any dyno in the test and get an accurate comparison. If all graphs posted were set up the same, we can easily compare any cams we want by overlaying the 2 dyno sheets.
you can see what i mean here.. It appears the tomei 280 has the same midrange as the crane 272, but the Tomei overpowers them in the top end.
Old May 8, 2008 | 11:37 PM
  #133
JC evo1's Avatar
also, which tomei 280 was posted, the hydrolic or solid?
Old May 8, 2008 | 11:45 PM
  #134
P-ROY's Avatar
Will AMS do this on a MIVEC head?
Originally Posted by AutoMotoSports
Yes, this is on an EVO VIII
Eric
Old May 9, 2008 | 01:21 AM
  #135
tumtum411's Avatar
bump
