Kinugawa 25g turbo thread
Old Feb 9, 2013 | 03:46 AM
  #286
mean4g63's Avatar
Originally Posted by VIIIdriver
That's pretty low for E85, i myself have quite a bit of cutomers over 400hp with Evo ix turbos on pump gas, check us out i have some of my customers dyno sheets on FB
www.facebook.com/DMTTuning
+1. I actually post 390-400 WHP VD numbers on an evo 8.5 turbo, 28 pounds of boost falling to 24 on pump gas. Certainly is possible with the right combinations and supporting mods.
Old Feb 9, 2013 | 04:43 AM
  #287
VIIIdriver's Avatar
^^ nice!
Old Feb 9, 2013 | 04:47 AM
  #288
VIIIdriver's Avatar
Originally Posted by welshevo
Any problems with space between turbo and rad fan with the koyo (full size) or will
I need to get a slim fan?
I did have to trim the blades and the right side of the shroud to be able to use the stock fan, not a biggie though, pretty easy to do.
Old Feb 9, 2013 | 09:02 PM
  #289
welshevo's Avatar
Awsome exactly what I wanted to hear. Thanks
Old Feb 10, 2013 | 08:14 AM
  #290
VIIIdriver's Avatar
^^ No problem, glad i could help !
Old Feb 12, 2013 | 10:37 AM
  #291
Cadmonkey's Avatar
i was previously thinking of going FP green, but after reading this thread i may go with the 25g 11.5 with a billet wheel. supporting mods will be a 2.0 long rod block, gsg s2 cams w/ springs and retainers, ets 3.5 fmic and ets pipes, 1200cc injectors (for e85 if i decide to use it), ported intake mani, and other little things (see sig)
im hoping for 420~440 ish on 91 but i may have to go with 91+meth or straight to e85
im also interested to see what a long rod 2.0 will do with the 25g. anyone have any input on my goals?
Old Feb 12, 2013 | 01:39 PM
  #292
VIIIdriver's Avatar
With your set up you should easily put down more than 440-450 on pump, E85 should be real fun on your set up, Long rods will allow you to run higher rpms so that's always a good thing, specially with the 11.5 housing making power on the top end !
Old Feb 18, 2013 | 03:03 AM
  #293
Ragin-Azn's Avatar
I kinda wanted one of these but I had a buddy get one back in 2011 and it didn't perform well. It spooled slower than bigger jb t3 turbos and didn't make much power. Think it made 277whp on buschurs dyno on 20+ psi. Maybe he just got a bad one lol
Old Feb 18, 2013 | 04:35 PM
  #294
rstchris's Avatar
I have the same mods only with stock block. I ordered the billet 25g w/10.5 and billet wga cause for some reason they don't offer the billet CW with 11.5 on their site. It's been on order for 2 weeks cause the cnc machine was not working and couldn't cut my wheel. It needs to show up already, got a fresh barrel of e85 to see what it can do at 30psi. I'll keep you posted on results with VD.
Old Feb 18, 2013 | 06:24 PM
  #295
rickja's Avatar
If you search for turbo failure here you will find a lot of different turbo manufacturers have had several failures on their turbos also, even turbos that cost 3 times as much as this one, no turbo manufacturer is gonna be 100% problem free 100% of the time, imo you shouldn't base your purchase decision solely on the experience of a few, i personally know of several of my tuning customers throuh out the U.S. that own this turbos that are still working reliably even at thigh boost, i personally beat on my car every day at 30 psi and 510hp and the turbo is still going strong with no signs of early wear, i should be installing the billet wheel some time next week, when i do it will be rebuilt by a proffesional local turbo repair facility at which time i will take pictures of the internals to asses the condition of such after the abuse i've put it through already.
What size line are you running? Did you use a restrictor? What size restrictor? I went the route of buying the compressor housing and 25g wheel and did the necessary machining to the cartridge. Recently had a failure which could be tied to oiling. I am running the stock oil supply from the head. The internals (thrust plate etc.) were not upgraded.
Any advise since I just re-ordered a new wheel and gonna give it a shot again?
Thanks in advance.
Old Feb 18, 2013 | 07:41 PM
  #296
VIIIdriver's Avatar
Sounds like a plan, definitely keep us updated!
Old Feb 18, 2013 | 07:44 PM
  #297
VIIIdriver's Avatar
Thanks in advance.
The line is -4an line, i got it from Kinugawa's site, i'm not running a restrictor, restrictors are mostly for ball bearing turbos which don't need the extra oil pressure. Definitely update to the oil filter housing feed line .
Old Feb 18, 2013 | 10:46 PM
  #298
evo7_8u's Avatar
i got a restrictor fitting with my kinugawa td06 kit .
Old Feb 19, 2013 | 05:03 AM
  #299
Sil'vr-Boi6's Avatar
Do you have a link/ or picks of oil feedlines you're using. I'm not sure which line to use on their website. And are you drawing from the head?
Old Feb 19, 2013 | 10:21 PM
  #300
evo7_8u's Avatar
yes mines plumbed upto the head and i'm using the lines that came with the kit.
