Kinugawa 25g turbo thread
Old Mar 13, 2013 | 09:19 AM
  #331
VIIIdriver's Avatar
Originally Posted by klever
After delaying I finally bought:
billet wheel TD06SL2R 25G 11.5T housing w/ anti surge cover, 2.0bar billet wastegate with braided steel line evo install kit...
Will take pixs when I get...
Awesome,
Old Mar 13, 2013 | 09:31 AM
  #332
ineedboostman's Avatar
My turbo showed up with the bullet actuator for some reason. I didn't order it that way. Seems to open slightly at 20 and fully between 25-30. Im goin to install it this weekend. I'll add some preload and see where that takes me but the billet actuator seems to operate flawlessly.
Old Mar 13, 2013 | 09:32 AM
  #333
Does appear to be a vented style too. I'd show some pictures but idk how to post the damn things.
Old Mar 13, 2013 | 02:18 PM
  #334
SANDIEGOSFINEST's Avatar
Nice choice! I too recently bit the bullet and purchased the billet 25g cw and will be installing it into my fpred turbo (fpred had a beat up compressor wheel so this wheel is replacing it). Ill take pics as well of the wheel when it arrives. Should be here friday...
Old Mar 13, 2013 | 02:37 PM
  #335
Originally Posted by EnlOOow
Old Mar 13, 2013 | 07:04 PM
  #336
rickja's Avatar
When taking the oil from the oil filter area to the turbo, is it necessary to add a filter?
Old Mar 18, 2013 | 10:41 AM
  #337
klever's Avatar
Booo , they sent it wrong.. got a cast wheel TD06SL2R 25G 10.5T housing w/ anti surge cover, 2.0bar billet wastegate with regular evo install kit... Lets see how is there customer service...
Attached Thumbnails Kinugawa 25g turbo thread-cimg5140.jpg   Kinugawa 25g turbo thread-cimg5143.jpg   Kinugawa 25g turbo thread-cimg5145.jpg   Kinugawa 25g turbo thread-cimg5146.jpg   Kinugawa 25g turbo thread-cimg5148.jpg
Old Mar 18, 2013 | 11:26 AM
  #338
todd6027's Avatar
the 11.5 housing still have 10.5 on the cast marking
Old Mar 18, 2013 | 11:37 AM
  #339
todd6027's Avatar
pics in here
https://www.evolutionm.net/forums/ev...ybody-try.html
Old Mar 18, 2013 | 05:36 PM
  #340
FastGti69's Avatar
Sorry to hear you got the wrong turbo, keep us posted on the customer service LOL. BTW, I'm kinda going the same route with a custom 25g. What power do you expect on 91? Since you're a local Socalian.
Old Mar 18, 2013 | 08:22 PM
  #341
klever's Avatar
91 24-25 psi in the 400whp range...
Old Mar 18, 2013 | 08:27 PM
  #342
klever's Avatar
Cool, but most important is the billet wheel..
Old Mar 18, 2013 | 08:39 PM
  #343
FastGti69's Avatar
Awesome, that sounds good.
Old Mar 19, 2013 | 02:08 PM
  #344
rstchris's Avatar
Currently at a flat 430hp tune on e85 with the 10.5cm housing. I took off to tx2k13 so I still need to finish it up. Thinking of doing the 11.5 with a ported stock mani, I think it will better suit the billet cw.
Old Mar 19, 2013 | 06:34 PM
  #345
I know I've read in this thread about people using a restrictor with feed line. The kit I just got with the turbo came with everything. The one Bango bolt that looks like it goes with the feed line is already restricted. The holes about the size of a paper clip it looks like. Is this what everyone else has used? I already have a an fp feedline on the car from the previous owner. It has this aluminum block coupler with fp ingraved where 2 stainless lines come together. Anyone know if that is a restrictor aswell. It had just a normal banjo bolt that I took out of the stock turbo. Idk if I should just put the normal bolt back In or use the restricted one.
