Kinugawa 25g turbo thread
Old Mar 19, 2013 | 07:13 PM
  #346
klever's Avatar
Originally Posted by rstchris
Currently at a flat 430hp tune on e85 with the 10.5cm housing. I took off to tx2k13 so I still need to finish it up. Thinking of doing the 11.5 with a ported stock mani, I think it will better suit the billet cw.
what psi, safe tune? I am running 30 psi on my stock 9 2.3L 280 cams e85 pushing 415awp
Old Mar 20, 2013 | 09:53 PM
  #347
EEHVOH's Avatar
Here in Aus, tuners make sure all tunes are conservative because parts/repairs/labour is all very expensive! I'm considering this and plan on a few bits and pieces to assist (if funds allow ) and so far, my JDM 8 MR is completely stock. The only significant mod is a Walbro 255l/h fuel pump. Everything else is completely stock. Was being convinced by one of the MR owners here to keep it stock but I'm not happy with 160kw (214hp) at the wheels. I don't plan on selling the stock parts when I replace with aftermarket, then again I don't plan on selling the car - ever lol.
Viii driver, can you see this turbo with the 25g billet 11.5 do any damage to a completely stock block? or would it be safe with a 3port that I will be installing and tuning to 22psi (stock turbo)?
Old Mar 21, 2013 | 04:45 AM
  #348
VIIIdriver's Avatar
Withe the proper mods this turbo has no chance in messing up your stock block my friend, it is also a very good idea to use a 3port, i always recommend it to my local or remote tuning customers. However i do recommend more than 22 psi even on a stock short block.
Old Mar 21, 2013 | 09:24 AM
  #349
ineedboostman's Avatar
Any insight on the restricted bolt?
Old Mar 21, 2013 | 02:40 PM
  #350
EEHVOH's Avatar
Well considering the MR has the 10.5 housing and low mileage on the engine, I might stick to the stock turbo until I want to do major upgrades. Eventually will go for 2.4 (maybe longrod) etc. I may hit you up with some tips on tuning when I put in the 3 port and get some US insight
Thanks mate
Old Mar 21, 2013 | 05:19 PM
  #351
silentkiller's Avatar
Anyone has the link to email kinugawa straight
Rather then go thru the main dealer??
Old Mar 21, 2013 | 10:05 PM
  #352
Try Service@kinugawaturbo.com
Old Mar 22, 2013 | 05:51 PM
  #353
jono2626's Avatar
I have a question. I have a standard Evo 7 with basic mods daily driven but im torn between a 20 or 25g? Which would be the better option as a daily?
Old Mar 22, 2013 | 10:13 PM
  #354
FastGti69's Avatar
I'm pretty sure the 20g will be more than satisfying for a 400whp DD if I'm not mistaken. I'm not familiar with evo's so I can be wrong. However, I know the 25g is a monster in top end power and has a noticable lag.
Old Mar 23, 2013 | 02:17 PM
  #355
todd6027's Avatar
Its a journal bearing turbo doesnt need a restrictor , oil feed from stock location .
Old Mar 23, 2013 | 02:18 PM
  #356
todd6027's Avatar
go with 25g then you have room for more mods
Old Mar 23, 2013 | 05:38 PM
  #357
The restricted banjo bolt came with the kit. It goes with the new feed from the head. I already have it feeding from the oil filte housing it had a normal banjo bolt in the stock turbo. Guess I'll just put it back together the way I took it apart.
Old Mar 23, 2013 | 06:11 PM
  #358
klever's Avatar
Customer service has been great, my billet 25g 11.5t is on its way
Old Mar 23, 2013 | 08:32 PM
  #359
rstchris's Avatar
Stock 2.0, stock head, 274 (s2) cams/springs, e85, 30psi, VD shows 430 by 6k and stays flat til 7500. up to 20* up top and wants more. Zero counts of knock. I need bigger injectors before I can max out my setup.
Old Mar 24, 2013 | 04:38 PM
  #360
VIIIdriver's Avatar
Nice results dude, That's pretty much the power i got on pump so i'm sure you can get more out of it
