Kinugawa 25g turbo thread
Old Jul 5, 2013 | 07:30 AM
  #541
WikdEvo's Avatar
Hmm. I'm betting The spring in your Waste gate is too soft and the exhaust gases are pushing the wastegate flapper open
Old Jul 5, 2013 | 07:40 AM
  #542
dimacoupe's Avatar
maybe... but we blow to actuator and spring in them real 2.0 bar. on boost off i have only 1.2 bar, but must 2.0
Old Jul 5, 2013 | 07:45 AM
  #543
WikdEvo's Avatar
Did you do that test with the arm on the flapper?
Old Jul 5, 2013 | 07:58 AM
  #544
dimacoupe's Avatar
yep
Old Jul 5, 2013 | 08:08 AM
  #545
WikdEvo's Avatar
You must be leaking exhaust around the flapper then. Are you using a divided o2 housing?
Old Jul 5, 2013 | 08:32 AM
  #546
dimacoupe's Avatar
checked, no leaks. invidia o2 housing.
Old Jul 5, 2013 | 09:07 AM
  #547
WikdEvo's Avatar
Haha. I'm out of opinions then. My setup runs just fine. Viiidriver ran the same setup with no issues as well
Old Jul 5, 2013 | 09:26 AM
  #548
dimacoupe's Avatar
by viiidriver graph i'm buy kinugawa ))
https://www.evolutionm.net/forums/10004227-post19.html
tell me please, you have billet wheel? where your turbo spool up? show VD graph, please.
on viiidriver all very delicious, but no one not repeat this
i have td06 25g with billet wheel, anti-surge and 11.5cm hot housing
Old Jul 5, 2013 | 09:48 AM
  #549
evoiao's Avatar
Originally Posted by wisniaPl
lots of Watergate problems...did anyone tried diff wastegate?? like fp 25psi one? will it fit??
This is the auestion I have asc well
I think there is another thread where the op is using a forge wastegate.
Are either one of these wgs capible of holding 30# psi?
Old Jul 5, 2013 | 10:56 AM
  #550
WikdEvo's Avatar
I'm on stock cams, exhaust mani, and tb for now. Also this is on pump gas.
I have the td06 25g, billet wheel, 10.5, light port and polish.
Old Jul 5, 2013 | 12:27 PM
  #551
dimacoupe's Avatar
Tom, your car on SD or MAF? if MAF, how much airflow?
Old Jul 5, 2013 | 01:49 PM
  #552
WikdEvo's Avatar
Sd
Old Jul 5, 2013 | 10:15 PM
  #553
VIIIdriver's Avatar
I haven't forgotten about you guys, been busy tuning locally and traveling for tuning, i still have a video i have to post for you to enjoy, my customer that bought my turbo on the dyno!, i will only say that he cleared 500 hp easy i will post it soon. Tom's car was nice to tune , pulls hard even on pump, can't wait to finish his tune on E85 and put that thing on a Dyno !
Old Jul 6, 2013 | 01:20 AM
  #554
dimacoupe's Avatar
recorded the last several logs with preload adjuster +5 full 360" from zero preload, just to make sure... i think, my turbo maxed out. There is no big difference if preload adjuester fully screwed or not. max airflow 350 g/s.
guys, when you buy your turbo? i'm in sep 2012. maybe i have some old version of billet wheel or smth like this
Old Jul 6, 2013 | 05:25 AM
  #555
WikdEvo's Avatar
Put a stiffer spring in there. If you really wanted to see if you could boost more. You could zip tie the waste gate arm shut and do a pull
It sounds crazy but that's the only way I know that you could check it.
