500 whp on pump gas
Old Sep 2, 2015 | 02:10 AM
shob33's Avatar
500 whp on pump gas
Fully built 2.0L
GSC S2 Cams with beehive valve springs and Ti retainers
3 inch turbo back exhaust
Full race T3 manifold
ID2000 Injectors
Walbro 255 pump
ETS 3.5 inch intercooler with 2.5 inch custom piping
Looking for a turbo which will make 500+ WHP at about 28-30 psi, Pls keep in mind that we have 98 RON here. Not planning on using meth injection.
Need help to decide between the following
Precision 6062 Gen 2 ball bearing
Precision 6266 Gen 2 ball bearing
Precision 6466 Gen 2 Ball bearing
Any input would be much appreciated, since there is not much to go on about 6062 and there are almost no tests on any evo of this turbo, I just want to know if it will get me there or not.
Old Sep 2, 2015 | 04:24 AM
Cogito's Avatar
98 RON is roughly the equivalent of US' 93 octane (RON + MON / 2), since on average MON is approx. RON - 10. You can pretty much compare results with US forum members that are using 93 oct.
On that note, I don't think running 28-30psi on 98 RON and 35+ deg Celsius is a good idea.
Old Sep 2, 2015 | 04:59 AM
theblackbeast11's Avatar
6466 for the win
Old Sep 2, 2015 | 05:41 AM
shob33's Avatar
500 whp on pump gas
Thanks for the input guys. Much appreciated. In the past we have run 35+ psi on 35r. Mind it its a low comp piston setup (8.2:1) and we dont run high timing here and try to keep it on the rich side. With meth we have run 50 psi on pump on a 67mm turbo. So our pump gas supports good boost given ofcourse the tuning is non aggressive. 6466 is the biggest of my 3 choices and also the laggiest. This will be used as a dd so want to achieve my goal of 500whp with as little lag as possible.
Old Sep 2, 2015 | 07:35 AM
lag is only a problem for people that can not drive!!!!!!!!!!!
Old Sep 2, 2015 | 07:41 AM
e_kobz's Avatar
Those are some massive injectors for pump gas.
Old Sep 2, 2015 | 10:19 AM
shob33's Avatar
500 whp on pump gas
Yup, we managed to run 85% duty cycle with intank 300lph pump and an inline bosch 044... Pump n meth... 67mm turbo 50+ psi
Old Sep 3, 2015 | 01:21 AM
shob33's Avatar
500 whp on pump gas
So I emailed precision and they suggest the 6062 GEN 2 for 500 whp on a 2.0 on pump gas... Any body have any experience with this turbo yet?
Old Sep 3, 2015 | 09:36 AM
evo8426's Avatar
Stupid statement. Go with the absolute smallest turbo you can, I have the Red and it sucks to drive in my opinion. I can only imagine how much worse a bigger turbo would be.
Old Sep 3, 2015 | 10:55 AM
awhit17's Avatar
Originally Posted by evo8426
stupid statement. Go with the absolute smallest turbo you can, i have the red and it sucks to drive in my opinion. I can only imagine how much worse a bigger turbo would be.
qft
Old Dec 16, 2015 | 08:30 AM
mushasho's Avatar
Originally Posted by awhit17
qft
https://www.evolutionm.net/forums/ev...20-torque.html
Old Dec 16, 2015 | 08:41 AM
LetsGetThisDone's Avatar
You need to find a good MHI housing to get machined and put on that thing. Or build a 2.3L. I imagine getting a turbine housing will be cheaper...lol
Old Dec 17, 2015 | 05:36 AM
evo8426's Avatar
Haha if I didn't blow money on buying the stm downpipe and modding my exhaust, it would be have been taken off by now and put back to stock turbo. No point in buying another downpipe and taking such a hit just to be back to where I began. Giant mistake changing the turbo, my previous experience with the Red is what sold me. Blah.
CP9APTY
Mar 1, 2017 04:11 PM
konstantinosIX
318
Sep 24, 2008 10:48 PM
David Buschur
45
Jul 22, 2008 07:33 PM
assembeldbygod
41
Apr 23, 2008 07:32 PM
DynoFlash
Feb 21, 2005 01:49 PM
