New FP Green! FP54 57lbs/min
Old May 13, 2016 | 11:03 AM
  #211
kaj's Avatar
kaj
Originally Posted by ixbreaker
I work for the parent company Edelbrock and Russell is next door. I asked my fellow engineer and he thinks we can piece this together for way cheap. Might come up with something better as well. Just have some concerns about this inline filter setup.
Nice! It should be super cheap for you. I didn't see a better way to do it; it's just an oil feed line.. but if you think of something, let us know!
as for the inline filter, people have been using them for quite some time without failure (due to the filter, that is), so I wouldn't worry about it too much
Old May 16, 2016 | 07:03 AM
  #212
Locdizzel's Avatar
I got mine a few weeks ago but the car is in pieces while i replace the trans and suspension. what oil are your all going to be running with this?
Old May 16, 2016 | 08:05 AM
  #213
LetsGetThisDone's Avatar
Run something off the FP recommended list. Amsoil Zrod or Valvoline VR1 synthetic are good choices. 10w30 or 20w50 will work, whichever you prefer.
Old May 16, 2016 | 08:11 AM
  #214
XSivPSI's Avatar
Off topic but which weight would be least likely to burn oil in their BB turbos? I emailed michael but no response. Seems like there are two conflicting issues. I assume thinner will drain better but will also seap past seals more easily and vice versa for the heavier oil.
Mine burns Rotella T6 5w-40 which is right in the middle so I wanted to go one way or the other to try to help the issue.
Old May 16, 2016 | 08:23 AM
  #215
Mine does fine on either, so, Idk. The only time mine smokes is the same as Abacus's, which is at the track, after a session, and idling through the pits. Other than that it doesn't smoke. Just a small amount of oil in the IC pipe after a few thousand mile.
Old May 16, 2016 | 11:52 AM
  #216
kaj's Avatar
kaj
VR1 20w50 because the car pretty much only sees track time. The heavier weight was recommended by FP and the VR1 is on their list.
If i weren't tracking the car, I'd run 10w30. The 50 is pretty danged thick and I feel it needs to be warmed a bit more before driving, which can be a bit of a pain for day-to-day operation.
**edit: mine is the 73htz, but still a Green.
Old May 17, 2016 | 06:49 AM
  #217
Locdizzel's Avatar
I think ill be trying VR1 till the clutch is broken in then switch to amsoil for the tune
Old May 17, 2016 | 07:41 AM
  #218
XSivPSI's Avatar
Any reason for those recommendations over Brad Penn? It was recommended by name during one of my calls to FP.
Old May 17, 2016 | 08:21 AM
  #219
Penn is fine too
Old May 18, 2016 | 09:08 PM
  #220
jk_evo8's Avatar
Ordered the second to last mhi housing turbo according to fp sales person. Said there will be no more mhi housing offered again. Can't wait to get it.
Old May 18, 2016 | 10:42 PM
  #221
mrfred's Avatar
I think FP said the same thing a few years ago. Perhaps it will be true this time. I keep hoping that FP or someone will start producing a quality TS hotside housing.
Old May 19, 2016 | 06:03 AM
  #222
kaj's Avatar
kaj
Unfortunately, I don't think there is enough of a market to justify the cost.
Old May 19, 2016 | 06:41 AM
  #223
Idk, they seem to be selling plenty of single scroll EVO turbos...
Old May 19, 2016 | 07:27 AM
  #224
kaj's Avatar
kaj
Pretty much. Seems the only ones that really need mhi housings are we California folk. The rest of you guys can move on to anything you want. . Lucky.
Old May 19, 2016 | 08:11 AM
  #225
You could move on to a better state...lol
