New FP Green! FP54 57lbs/min
Old May 19, 2016 | 04:20 PM
  #241
Erik@MIL.SPEC's Avatar
THe FP54 is a 57# a minute turbo. Which means, on kill mode with all the supporting mods, should be able to make ~570whp.
Old May 19, 2016 | 04:25 PM
  #242
revhappy's Avatar
Originally Posted by kaj
I have the HTZ wheel. I'm at a very safe 450whp track tune, on e85. I have minimal supporting mods. I can't imagine 500 being too tough?
How is the spool?
Old May 19, 2016 | 04:34 PM
  #243
kaj's Avatar
kaj
Originally Posted by revhappy
How is the spool?
I sadly don't have an FP54. Mine has the larger turbine wheel. Don't get me started on why LOL.
Old May 19, 2016 | 05:36 PM
  #244
LetsGetThisDone's Avatar
The turbine on the FP54 is much smaller. Which means it flows less.
Old May 19, 2016 | 06:13 PM
  #245
kaj's Avatar
kaj
So mine is more than 57lbs/min? Either way, i still think I may be better off with the one I got.
I love the HTA71 for the street...but maybe the 54 is even better. Results pending.
Old May 19, 2016 | 06:23 PM
  #246
The compressor is the same 73htz that flows 57lbs/min. The turbine is not included in the lb/min flow rating.
Old May 19, 2016 | 11:47 PM
  #247
mrfred's Avatar
Originally Posted by Erik@MIL.SPEC
I may know someone who is working on one. But I've probably said too much already lol
I hope it happens.
Originally Posted by nemsin
Better yet, you could have it 3d printed in Inconel 718 http://www.industrial-lasers.com/art...pace-apps.html
718 + 3D = $$$$$. No way it would ever be affordable. The raw 718 alone would be around $700. 3D printing would be well over that cost, then it has to be heat treated, and then remachined because heat treating will cause some minor shape change.
Old May 20, 2016 | 05:34 AM
  #248
schuhie's Avatar
I have an 73HTA and on E I make a touch over 500whp dynojet. I'd imagine the FP54 should be able to make it too 500 as well
Old May 20, 2016 | 07:50 AM
  #249
LakerRaider's Avatar
they went on to explain that every turbo has a limit to how fast it can spin, and were skeptical of 500 on the fp54...though they wouldn't say for sure that 500hp would bring this turbo over that limit
Old May 20, 2016 | 08:08 AM
  #250
The compressor will do it. It's a question of the turbine being able to flow that much.
But, seeing as how guys routinely get over 450whp on a max effort 71hta, I would venture to say the FP54 will do 500 just fine.
Old May 20, 2016 | 12:05 PM
  #251
kaj's Avatar
kaj
In that case, I'm very glad I got the larger one.
My 450whp is @ around 25psi with lots of fuel and mild timing. Even with the smaller turbine, I gotta imagine 500whp would come pretty danged easy.
Old May 20, 2016 | 12:50 PM
  #252
vr4gasmtt's Avatar
My eyes are playing tricks on me, did the price go up on fp54?
Old May 24, 2016 | 11:48 AM
  #253
WhiteHat's Avatar
Looks like they include the coating of the housing in the price now for 100 more, before it was just an option.
Old May 24, 2016 | 11:57 AM
  #254
nemsin's Avatar
Have them do a TS hotside that fits EFR supercores, similar to what Boost Resource is doing for the X
http://www.evoxforums.com/forums/sho...d.php?t=321914
http://www.boostresource.com/product...hi-evo-x-2008/
Old May 24, 2016 | 12:17 PM
  #255
From what little I do know, these housings are being made because you can't put a "real" sized turbine in the 8/9 housing. What was explained to me is that FP can only make the turbines so big, otherwise you put holes in the housing when machining it.
And I could be wrong, but I don't think there is room to fit bigger than a 7163 in the OEM location for the Evo 8/9. I think the Evo X has a lot more room for things on the back of the engine.
