BW S362 SXE TwinScroll Project
Old May 19, 2019 | 07:43 AM
  #106
240Z TwinTurbo's Avatar
I posted numerous graphs showing boost vs rpm
boost response is good so not interested in a smaller turbine housing
Sound favors the BW in terms of compressor loudness
It's a 68mm turbine wheel vs ~62mm turbine wheel so it doesn't want to slow down as quickly between shifts, but no actual data available to compare transient response
Now that it is pretty much dialed in I like this setup better. The sound of the exhaust is definitely different and especially when you start trying to make boost. Hard to explain, but I assume it is due to the larger turbine wheel. The car is making more power on the topend with equivalent spool, but that is slightly unfair to the GTX since I modified the MIVEC to run more advance. Perhaps a GEN II GTX3582r would have made similar results, but the larger turbine wheel seems to make the car less knock prone likely because my drive pressure is lower. I am running the car in 25F to 35F hotter conditions and consistently running 34psi without any knock and I could not do that on the GTX. Now that I think about it, I might as well add 1-2deg on the top and see if it likes it since adding timing at peak torque didn't induce knock.
If I did anything (assuming my life would not end due to my wife killing me) turbo wise I would go with the S364.5 SXE because it would be a directly bolt on to my current setup and flows another 100hp. (64.5/68 vs my current 62/68).
Old May 19, 2019 | 03:47 PM
  #107
211Ratsbud's Avatar
Faster or slower, IMO the best thing is how it feels to the driver . So much data here, all I want to do is go for a ride. 🤣 It appears faster and it appears just as fun.
Waiting patiently for your next build. 🤺
Also where is the boost overlay for the elbow comparison 🤷*♂️ lol
Old May 19, 2019 | 04:29 PM
  #108
when I opened EvoScan yesterday morning I had to select the “ECU” for some reason as it didn’t seem to remember my default settings
After the run I noticed the units were default to Imperial so my “boost” was in kpa
Old May 19, 2019 | 04:31 PM
  #109
211Ratsbud's Avatar
Any perceivable change in boost without the elbow?
Old May 19, 2019 | 04:59 PM
  #110
No, subsequent logs verify boost has not changed. Gonna configure it to where I can make a quick change on the Dyno to switch between the two setups.
Old May 19, 2019 | 07:00 PM
  #111
Dyno appointment is tentatively set for May 30 and this was the soonest he could get me in.
Old May 20, 2019 | 08:44 AM
  #112
heel2toe's Avatar
Awesome, great results and tons of data shared
Pretty decent power for pump fuel. It's too bad your dont have access to e85 as that would really wake this thing up! Curious, I noticed with your new motor you dropped the compression...is that bc you only run pump fuel? I had this dilemma when I was doing my motor as far as higher comp and less boost or lower comp and more boost. Seems it might end up being a wash but being that I predominantly run e85 I rolled the dice and went 10:1
Old May 20, 2019 | 11:20 AM
  #113
10:1 was not a standard offer so I chose the off the shelf 9.5:1
Old May 30, 2019 | 09:53 AM
  #114
DYNO Results....
https://www.evolutionm.net/forums/ev...l#post11874284
Old May 30, 2019 | 06:18 PM
  #115
KingTal0n's Avatar
Whats that spray coming out of the bypass when you lift, methanol injection?
I am having trouble with 35psi of boost and 93 octane with 12:1 air fuel ratio.
The most I've ever seen on 93 solo was about 22psi.
Are there any other cars with similar setups as far as pump fuel and 35psi. I'm trying to figure out why every other platform stops at 20psi for 93 octane usually.
Although I do recall some 10 years ago seeing a 4g63 pull a similar stunt.
Anyways, regardless, congrats on finishing and then taking it one step further and the dyno trial. It was quick and concise.
Might be time to consider moving on to airplanes or something more complicated, seeing how there isn't much more room to grow without getting extravagant, onwei
Old May 30, 2019 | 06:48 PM
  #116
No meth injection, just straight shell 93. It is compressed air so I assume it is reacting to the pressure change once the BOV opens. If you spray compressed air using a blower nozzle it will sometimes look like that. Not sure what makes it look like that, but I am sure there is a reason based on simple physics.
You are not giving me enough credit...AFR is actually 12.66:1 at 35psi and ~4700rpm Car actually spikes 36-37psi on the street since it loads it more than the dyno and then tapers to 33psi. GTX would knock past 32psi, but this setup seems to be much less knock prone due to header design and larger turbine wheel. My buddy Walker at www.mpfab.com runs the same setup and he also runs 37psi on pump tapered to 33psi, but his setup makes ~650@wheels EVO 8. He has a high rpm cam (S3 like) and AMS intake manifold so those both flow more on the topend, which is why he makes more power. My wastegates are recirculating and his are open dump, which he says were worth 40hp on his setup.
30+psi is very common in the EVO community on 93 pump.
Old May 30, 2019 | 09:04 PM
  #117
spdracerut's Avatar
Rapid decompression of air will make it very cold. If you're a cyclist and have used the CO2 tire inflators, they get very cold as you let out the pressure quickly from the CO2 cartridge and into the tire. I'm guessing it was pretty humid, so the water in the air is condensing. That's my guess
Old May 31, 2019 | 12:03 AM
  #118
MR ArcticC's Avatar
Congrats, nice results on your new build.
Is there 3" or 3.5" exhaust on Walker's Evo? Asking because of the 40whp advance of the open dump.
Old May 31, 2019 | 04:57 AM
  #119
Originally Posted by mr arcticc
congrats, nice results on your new build.
Is there 3" or 3.5" exhaust on walker's evo? Asking because of the 40whp advance of the open dump.
3.5”
Old Jun 2, 2019 | 04:25 PM
  #120
Went out and made a few passes to clean up the AFR upon initial boost hit. Although it doesn't knock probably better to be safe than sorry. Dyno Run AFR vs Street AFR after tuning.
