View Poll Results: Warranty claim problems/ No claim problems.
Submitted claim, wasn't honored or had problems
129
58.90%
Submitted claim, no problems getting it fixed.
93
42.47%
Multiple Choice Poll. Voters: 219. You may not vote on this poll
Warranty Issues <Mega Merge>
Old Dec 31, 2005 | 12:40 PM
  #1876
Ultimate CC's Avatar
I know some people that run flashes and UTEC, have a flash for daily driving and then self tuned maps for race gas and what not
Old Dec 31, 2005 | 01:27 PM
  #1877
Warrtalon's Avatar
That's one hell of an expensive way to tune just for race gas occasionally.
Old Dec 31, 2005 | 03:04 PM
  #1878
Your not kidding, haha, I know 3 people running that setup, makes no sense.
Old Dec 31, 2005 | 03:37 PM
  #1879
BMan's Avatar
Originally Posted by hillbilly8R
I am happy with stock thank you, but, I like reading what you mod happy guys do. I have searched this and remember seeing a response being specific on what would and wouldn't void your warranty. I may get the mod bug one day but do like having the warranty in tact. Now I know some are going to say Nothing and others are going to say their dealer is cool. I'll start with what I think would be good starts that would not effect warranty.
Exhaust-as long as you use original mounting brackets (correct?)
Air filter
spark plugs
wheels and tires (no spacers)
clutch (not under warranty anyway)
I know this is not much, which is why I asked. Flame away if you feel the need, but I know some of you know other things that would get a few hp and not come close to effecting warranty. I also read someone stating the IX BOV is much better. Wondering if it would be a direct replacemnt for the VIII (and or beneficial). So burn me or learn me, your choice
Light bulbs.
It depends on your dealer.
Old Jan 1, 2006 | 08:05 AM
  #1880
Ronin17's Avatar
Originally Posted by silverEVO8
The ECUs are specific for each car.... I don't think you can swap them from car to car. I don't know if you can buy a new one that will work with your car either.....
Huh? Where are you getting this information. Just as an example, there's no reason a new ECU from a 05 Evo won't work in another 05 Evo.
Old Jan 7, 2006 | 04:54 AM
  #1881
silex's Avatar
I don't know about you, but ecu's are not cheap. I think a better option is to just go standalone or piggyback for the second one with a quick disconnect harness and remove it before going to the dealer and dial in the stock parameters.
As for the cat-back comment; where does it say that you can't do a TBE unless you want to void your warranty? But void only the warranty on the exhaust correct? Not for the entire car I would presume.
Old Jan 7, 2006 | 05:05 AM
  #1882
wingless's Avatar
Wing delete mod
Old Jan 7, 2006 | 05:06 AM
  #1883
silverEVO8's Avatar
I don't know exactly why, but in the '03 EVOs the ECUs would not swapt uot from car to car. Maybe it had something to do with the keys, but I definitely remember something along those lines.
Old Jan 7, 2006 | 05:11 AM
  #1884
wingless's Avatar
Except for the passive transducer chip that will imobolize the car if not coded to the correct key. You have to go to the dealership with the correct ID tag to re-flash the ECU for a new key. After all that it is only possible to code one ECU to one car at a time. (can't swap different flashed ECUs).
It will work, but it's a total PITA.
  #1885
silverEVO8's Avatar
Anything that affects the function of the engine can have negative effects. The TBE can most definitely affect the flow of air and fuel through the engine, therefore could argue that some engine or even some drive train failure could have been caused by the customer altering the car and thusly deny the warranty......
Old Jan 7, 2006 | 05:14 AM
  #1886
silex's Avatar
So you're saying that if we care about our warranty at all, we shouldn't even consider a TBE; cat-back is our only option? There's no way around this? I guess if we ever want to void later, we could get the cat-forward at a later date.
Old Jan 7, 2006 | 05:22 AM
  #1887
wingless's Avatar
Well technicallya dp could change A/Fs and the operating temp of the catalyst. On the topic of the converter, TBE implies adding a hi-flow cat or test pipe, both of which are illegal in most or all states.
Obvoiusly mitsu can't back anything illegal or take responsibility for unknown parameters.
Old Jan 7, 2006 | 05:30 AM
  #1888
silverEVO8's Avatar
No, I'm not saying anything quite like that... Actually, even the catback can be cause for a denial of warranty..... Look, I have had my highly modified EVO repaired under warranty even though they could have easily argued that the mods caused the damage (in my case, they really did cause at least part of the problem). The dealer was very cool and they worked with me so I only paid for the part of the repair which was questionable.
I think your concerns are valid about the warranty and I just wanted to inform you that "any" modification that alters the function of the engine or any part of the car could be argued to be the cause of some failure. In this case, can deny or try to deny the warranty. However, in real life, things can go either way and it basically boils down to the persons involved. They can work with you or against you, no matter what modifications you might or might not have in your car.
Old Jan 8, 2006 | 06:09 PM
  #1889
jxn evo 8's Avatar
warranty question
The other day I had to go and get a new valve cover gasket from the dealer. When I went to get it they said that they had to have me vin # to order the part. I have no problem giveing them my vin cause my warranty has been voided. Is mitsu requiring vin #'s to void warranties? IF so sould we start some type of list of vin #'s on evos that are already voided to protect the others on the site that still have warranties? Let me know what you guys think
Old Jan 8, 2006 | 06:11 PM
  #1890
BoostWhore's Avatar
I always wondererd that. Maybe just to confirm parts with the correct year.... Id just tell them sorry you dont need it
