New Full Blown 70mm cast TB
Old Jan 31, 2012 | 10:52 PM
  #106
10isace's Avatar
Installed. It looks like a pretty good gain in HP/TQ (19/25), but I'm attributing a lot of it to fixing the boost leak with this TB. I'm just so happy that the boost leak is gone and the car drives better than it EVER has since I've owned it in 5 years!!! Also, when I'm ready to upgrade IM, I have a TB that is ready to go with it.
Old Jan 31, 2012 | 11:14 PM
  #107
EvoFredo's Avatar
sounds like positive results for you. can you post install pics ? id like to see that reducer adapter installed. thanks .
Old Feb 1, 2012 | 09:04 AM
  #108
10isace's Avatar
Here you go. It's pretty easy:
  1. OEM gasket
  2. adapter with small side towards IM
  3. 70mm gasket
  4. 70mm TB
Old Feb 1, 2012 | 07:28 PM
  #109
wizzo 8's Avatar
Are those gains from a stock t/b or a ported t/b? Also do you have a picture of the adapter plate before install? How is the idle without the idle controller screw?
Old Feb 1, 2012 | 08:14 PM
  #110
10isace's Avatar
It was a stock t/b, but realize I had a boost leak. I replaced the throttle shaft seals a few months back, but it was now leaking on the component below that. I don't know what it's called and Mitsu doesn't sell the o-ring for it. I was going to match one up, but decided to go this route.
There is an idle screw. I'll take a pic later. It idles great! All dialed in.
The only problem I have is I can't get ecu to see 100% TPS. I can get it to say 99.60784314 at WOT and 17.64705882 at idle. On the stock tb it said 100% at WOT and 12.15686275 at idle. When I set the TPS to around 12 for idle it shows up around 96% at WOT.
Old Feb 1, 2012 | 08:22 PM
  #111
wizzo 8's Avatar
You want to set it up for WOT. Not idle. Loosen up screws on tps and with the gas pedal floored (eng off of course) get the reading to 100%. Then tighten screws. Done!.
Old Feb 1, 2012 | 08:26 PM
  #112
10isace's Avatar
Thanks man! I'll do that tonight.
Old Feb 1, 2012 | 08:36 PM
  #113
wizzo 8's Avatar
No problem. Also remember idle wont be 0% like some people think. And once in a while if you only see 99% throttle when floored that's ok also
Old Feb 6, 2012 | 08:20 AM
  #114
Mauricio Evo IV's Avatar
Any updates??
I would like to buy this Full Blonw TB for my evo 4.. someone know if it´s fit this TB in an Evo 4???
I just bought an Evo 8 stock ported intake manifold to replace ths stock evo 4 intake manifold.
Old Feb 6, 2012 | 10:44 AM
  #115
10isace's Avatar
Originally Posted by Mauricio Evo IV
Any updates??
It'll fit the 8 IM. What's it ported to? You may need to either have MAP or someone in your parts to build up the IM to 70mm or port the adapter to whatever your IM is bored out to (65mm I assume).
Update: I love it so far. The only problem I'm having is with the TPS. Now that I have it reading close to 100% at WOT the injectors won't shut off when I lift off the gas. TPS reads 17% when throttle is closed. I think it needs to be around 13% for injectors to shut off. Is that true? Is there a way to adjust injector shut off to 17% and will that affect anything else?
Old Feb 6, 2012 | 12:43 PM
  #116
thanx for your answer!
Yeah, well, I bought the stock IM ported but I don´t know who ported. I asume is opened to 65mm if not, I will port the IM to 65mm. (the intake is in transit to my country) I bought it in ebay.
Here:
http://www.ebay.com/itm/330676304044...84.m1423.l2649
I saw that MAP sale this throttle and AWD too. So, he sale with the plate to fit in stock evo 8 IM?
Old Feb 6, 2012 | 08:33 PM
  #117
10isace's Avatar
Here:
That's funny, I was watching that IM on ebay. The adapter plate was included with my TB, same as the one in post 108.
Old Feb 6, 2012 | 09:05 PM
  #118
nice! Thanx man
Old Feb 21, 2012 | 11:38 PM
  #119
10isace's Avatar
Update: So far, love the TB. The only problem I'm having is that I can't get enough slack in the cable so the butterfly will close. It's about the same distance as the adapter plate. I believe once I am able to take off the adapter, then the butterfly will close all the way.
Old Feb 22, 2012 | 07:34 PM
  #120
wjamyers's Avatar
Originally Posted by n2oiroc
vacuum is vacuum. grab it anywhere from the intake manifold, but dont tee it off the fuel pressure regulator. if you dont have any open ports, get a vacuum block.
http://vibrantperformance.com/catalo...Path=1022_1028
If I grabbed it with a T off my boost gauge line would that explain why my gauge is so damn slow? Or should I have bought Defi instead of prosport? Got any ideas about this? Where else could I grab it from?
btw, this throttle body idles and drives like stock very smooth. But I also had it installed with the MAP Rev3 Modified Intake Manifold and all this stuff:
ETS 3.5" FMIC
FIC 1100
BBK Full
TBE
Forge UNOS MBC
Spoolin Up COP
Synchronic DV
Walbro 255 LPH
Stock Intake with Amsoil Filter
Boost gauge is sloooooooow.
