COBB AccessTUNER Pro for 2008 EVO X (merge)
Old Dec 31, 2008 | 10:32 AM
  #181
Rob@cobbtuning's Avatar
Originally Posted by goofygrin
Rob, what does a tune cost at the Plano location?
I assume you need to buy an access port and then there is some cost associated?
I'd need at least two and likely three tunes (91, 93, & STU legal [ie. no boost changes ])
I'm thinking that the cost of the tunes will be > than the cost of the accessport.
Quite honestly I'm not sure on cost. Contacting Chris @ the Plano location would probably be best. We should already have tunes that will be very close for 91, 93, and STU. That being said each map should only need minor changes for your specific motor and modifications. I believe the STU tune was/will be created on Brian's MR of www.vorshlag.com. Here is their project thread http://vorshlag.com/forums/showthread.php?t=6369&page=2.
Thanks,
Rob
Old Dec 31, 2008 | 10:34 AM
  #182
goofygrin's Avatar
Originally Posted by Rob@cobbtuning
Quite honestly I'm not sure on cost. Contacting Chris @ the Plano location would probably be best. We should already have tunes that will be very close for 91, 93, and the STU. That being said each map should only need minor changes for your specific motor and modifications.
Thanks,
Rob
Chris @ cobbtuning.com? I'm out of town and calling is a PITA.
Old Dec 31, 2008 | 10:37 AM
  #183
chris DOT fleming AT cobbtuning DOT com
FYI, he's also be a big autocross nut.
Old Dec 31, 2008 | 10:44 AM
  #184
Papi4baby's Avatar
FYI i got quoted around 400 for dyno tuning on top of the price of the AP at a different location out east.
Old Dec 31, 2008 | 10:48 AM
  #185
goofygrin's Avatar
Ouch. If you though ECUTek was pricey at $700, then ~$1,000 for an access port and custom tune is a kick square in the nuts.
I sent Chris an email, we'll see what he says.
Old Jan 3, 2009 | 07:47 AM
  #186
PlayinWithFire's Avatar
I have the injen intake and a fujitsubo exhaust and was just checking to make sure I will be fine with the stg II when it comes out. Thanks!
Old Jan 4, 2009 | 10:44 AM
  #187
Japistani's Avatar
Originally Posted by razorlab
They don't switch, they interpolate, depending on knock counts, etc
What kind of knock counts are acceptable when running a stage 1 map? I logged knock retardation, and have noticed sporadic knock retardation of .35, and .7... the majority of the time it's at 0...
If anyone has any thoughts, that would be greatly appreciated!
Old Jan 4, 2009 | 03:43 PM
  #188
Q15H's Avatar
M<y results agree with yours [on the knock count numbers and frequency].
Old Jan 4, 2009 | 04:27 PM
  #189
funks's Avatar
Double post.. sorryl
Old Jan 4, 2009 | 04:28 PM
  #190
funks's Avatar
Any California owners using the 91 octane map? Is the timing retarded a bit to make sure it doesn't knock with our crap gas?\
I believe it's called the ACN91 GSRv100 MAP (Arizona/California/Nevada crap gas tune).
Old Jan 5, 2009 | 08:38 AM
  #191
Black-X's Avatar
So will the Accessport help with the crappy quirks of the Mitsu factory reflash? I'm sick of it.
-X
Old Jan 5, 2009 | 10:18 AM
  #192
Papi4baby's Avatar
-X
Hey if you are going to order and everyone is the same price. Go with Perrin, they offer an extra Stage 1 map made by them, and it seems to give more juice than the COBB map.
Old Jan 5, 2009 | 10:20 AM
  #193
scottatyamaha's Avatar
^thanks for the heads up on that.
Old Jan 5, 2009 | 01:14 PM
  #194
Papi4baby's Avatar
Old Jan 5, 2009 | 02:35 PM
  #195
-X
The AP most definitely will smooth out the driving experience while adding a good dose of power. One point we really work on is the transition points and making them very smooth.
Thanks,
