View Poll Results: EVO X Transmission Problem POLL
Notchy, grinding, or difficult to engage gears (all the time)
689
40.08%
Notchy, grinding, or difficult to engage gears (only when car is cold)
646
37.58%
Difficult to engage Reverse gear (cold or warm)
146
8.49%
No problems at all
238
13.85%
Voters: 1719. You may not vote on this poll
The official Evo X notchy/grinding transmission thread
Old Apr 10, 2009 | 05:08 PM
  #406
Thegame's Avatar
^ I'm almost positive that this won't be a recall. Not everyone seems to have issues with the shifter. And recalls are mostly safety issues. There will just be a TSB with info on the updated cables and to replace them for those who complain. And in most cases, it'll take most dealerships 6 month to learn about it and you'll have to fight with them about whether such a TSB does exist. lol.
Old Apr 15, 2009 | 08:32 AM
  #407
tsitalon1's Avatar
Did the revised cables help?
Old Apr 15, 2009 | 09:25 AM
  #408
Clipse3GT's Avatar
Yes, update please.
What Month and Year was the car made in as well? Maybe that has something to do with it?
Old Apr 15, 2009 | 10:07 AM
  #409
Callabrator's Avatar
Yes, I too am very interested to hear if the new cables helped.
I was talking with one of the head mechanics at my dealer last week about this very issue, and he said "that's just they way they are". Hopefully these new parts can prove him wrong...
Old Apr 15, 2009 | 10:27 AM
  #410
Clipse3GT's Avatar
Yup
Old Apr 15, 2009 | 11:39 AM
  #411
Thegame's Avatar
https://www.evolutionm.net/forums/ev...s-fitment.html
Check this thread out. And look at the guys shifter cable. It's different than ours. That's why his AMS bushings didn't fit. Granted he's in a different country, but that shouldn't matter. I wonder if this is an updated cable?
Old Apr 15, 2009 | 12:35 PM
  #412
HarrisRacing's Avatar
Post Whoa?!
Here we go!
Attached is my receipt on the repairs. As you might notice it also includes a seat upholstery repair that did not pose a solution either.
The link that was posted above to the "WHY DO MY AMS SHIFTER BUSHINGS NOT FIT?" is exactly the "fix" I received on my car. His pictures are exactly what my cables look like now and yes it is DEFINITELY different parts from the factory USDM 2008 GSR set. Now, if I think it is a fix or not...I don't know yet as I have not had the car back long enough to gather any substantial info (I JUST picked the car up from the dealership and it was already warmed up from driving it around). I will drive it tomorrow morning, so expect a post sometime around then with me driving in the conditions that I normally would complain about.
I will say that the shifter feels TOTALLY different. This isn't just some crazy "I hope my car is better placebo-like" statement, it is WAY stiffer than the other setup. What I mean is, when I move the shifter around it is HEAVIER feeling...like you are pushing it through something sticky or viscous. With the factory parts, the shifter would just move easily to where you wanted it to go and now it is substantially "sludgier" feeling. It also feels like the gates have at different angle to them (very very slight) at the shifter lever. It may be stiffer, but it's also like the bushings or cables are stickier (imagine your cables with honey inside them).
This MUST be the 2009 shifter cable set...please read part numbers off if someone has one!
This revised shifting action leads me to ponder 3 things:
1) Is this just a solution to slow down the standard shifting action by making the shifter harder to throw and make me not notice the wall I was hitting when trying to get into 2nd (not that I shifted fast anyway)?
2) It's actually a revised part that fixes where the sliders are in reference to the shifter by tightening everythign up and changing geometry.
3) It's just stiff because it's not yet broken in.
So there you have it...stay tuned for tomorrow morning. I will have DEFINITE results by then.
Patrick
File Type: pdf
Old Apr 15, 2009 | 01:26 PM
  #413
Originally Posted by bouncintiga
how much are you spending out of pocket for these revised shifter cables for parts and installation? is it a warranty covered item?
Warranty work. $0.00
Old Apr 15, 2009 | 01:47 PM
  #414
Clipse3GT's Avatar
Thanks for the info.
Waiting to hear the results.
If that's the case , you might as well change out the tranny fluid, shifter, and bushings, then just call it a day. Might be a better fix than the one from Mitsu.
Old Apr 15, 2009 | 02:10 PM
  #415
Thegame's Avatar
Thanks for posting
Old Apr 16, 2009 | 05:26 AM
  #416
Update:
It was exactly as described. "It might not solve the problem, but it should make the shifter 'feel' better". Yes it does FEEL better, but this morning the grind is still there. But, it still feels drastically different than the stock USDM GSR shifter...So I guess I start going after a new trans now. Perhaps the 2009 trans is better too then??
Patrick
Old Apr 16, 2009 | 05:29 AM
  #417
Clipse3GT's Avatar
Patrick
So it's just probably better off to not even bother with the revised shifter linkage?
Old Apr 16, 2009 | 06:42 AM
  #418
tsitalon1's Avatar
Patrick
Patrick,
If you don't mind, please report back when you have had a little more time with the new cables....Did they also replace the shift levers that go inside the tranny and connect to the shift forks?
I wanna know more about the "MT shft kit" listed in the reciept.
Old Apr 16, 2009 | 10:08 AM
  #419
smoothevo's Avatar
Thanks for the update - please let us know if anything changes that is worth mentioning.
Old Apr 16, 2009 | 10:19 AM
  #420
Originally Posted by tsitalon1
Patrick,
Yes, it has new linkages that go inside the tranny to the forks. So the complete kit is: Cables, washers, bracket for cables at trans, and levers that pentrate the case from the cables to the shift rails.
Patrick
