***ECUFlash Now For Base Lancers!***
Old Sep 2, 2007 | 06:17 PM
  #661
slipshft's Avatar
Originally Posted by Silens
have you tried one for an 04?, it should work, same setup
Thanks, I am ordering my cable and will try this when it get here.
Old Sep 4, 2007 | 12:28 PM
  #662
Tweak3D's Avatar
I just oredered my cable the other day, I am curious though has anyone dumped the 02-03 rom for an automatic? I am an auto sadly but would love to tune my care this way not only for the knowledge but because I am going turbo and will not only save me money but probably give me more gains over the piggy back. so has anyone pulled the auto rom yet?
Old Sep 4, 2007 | 05:02 PM
  #663
sykou's Avatar
try pm zlancer to see if he can make one for you....
Old Sep 5, 2007 | 07:51 AM
  #664
elcausa's Avatar
mine is an 03 auto, def files might be different tough
Old Sep 5, 2007 | 05:28 PM
  #665
Tweak3D's Avatar
am I allowed to post my rom so I can have a def file made or will I get into trouble? I just pulled my rom and cannot do anything with it yet.
Old Sep 6, 2007 | 01:42 PM
  #666
senate6268's Avatar
Post it up. Just be sure that you include all the details about your car: year, model, manual or auto, etc. That way others may be able to use the metadata file created for their own ROM.
Old Sep 6, 2007 | 03:09 PM
  #667
Tweak3D's Avatar
alrighty guys, here is my rom, I just need a def file for it. here are the relevant stats.
2003
lancer oz
Automatic
eveything else should be common info that you guys would know. need anything else let me know, cannot wait to start tuning.
http://home.comcast.net/~tweak3d/200..._stock.hex.zip
-Justin
Old Sep 9, 2007 | 07:17 AM
  #668
elcausa's Avatar
ok looks like my def files fit yours note that i only defined the fuel and ignition maps.
was lazy and just copied zlancerman instruction hope he doesn't mind
File Type: zip
Old Sep 9, 2007 | 01:58 PM
  #669
Tweak3D's Avatar
well it now lets me see the data but the units are all messed up. like rpm and load are all just a bunch of random numbers. same goes for the timing table, the data itself though appears to be good though, will this affect my flashing since I know what the units are or does this need to be fixed?
Old Sep 9, 2007 | 06:40 PM
  #670
elcausa's Avatar
really it shows fine on mine? did you put inherit from def 8100016.
if you did and nothing post a shot of it so that i can attempt to fix it
Old Sep 9, 2007 | 07:12 PM
  #671
Z_Lancer_Man's Avatar
If the units are messed up, then it sounds like the memory addressed is incorrect, and that that def file won't work with your ROM. I'm currently working on someones 03 AT rom.
Old Sep 9, 2007 | 07:15 PM
  #672
Tweak3D's Avatar
hats probably mine, I sent you a copy of my rom via e-mail the other day
Old Sep 10, 2007 | 07:19 AM
  #673
Mr. Evo IX's Avatar
What loads are you guys rescaling the timing / fuel maps to? Or has anyone actually tried to use the OEM ECU for complete engine management yet? This is a preliminary map that I just threw together for like 8-11lbs of boost.
WARNING.. Do not put on your car! untested maps, I dont even own a lancer but I've got a friend who is interested in getting tuned. I've got some experience with ECU Flash.. Just an idea here.. comments please.. anyone want to discuss?
Also, it looks like their are no definitions for the MAF Scaling table yet. I'm guessing this might be necessary to use the MAF for measuring higher loads. Discuss?
Old Sep 10, 2007 | 03:14 PM
  #674
Mr. Evo IX's Avatar
wow, someone just told me that even at 11psi it just barely overruns the 100% column. Ok, back to the drawing board. I guess I'll just rescale to 120% load instead of 150%. this will be better anyhow as there will be more break points that will make for more granularity.
Old Sep 10, 2007 | 06:56 PM
  #675
senate6268's Avatar
At idle my load is about 15-20%. Cruising on the highway at 80mph my loads are 45-65%. After shifting into 2nd while at full throttle my loads are above 110% and slowly climb to 115 and taper back down to 105-110% by redline.
