Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old May 28, 2010 | 11:01 PM
  #421
link62's Avatar
Originally Posted by RoadSpike
Mind sending me the rom you are using right now? I would like to look at your maf scaling values. The load you hit isn't extremely high but it is a bit higher than what you capped at last time.
Thinking if the maf scaling is tweaked a bit it would add more fuel where it needs to be.
ok ill send it to you and yea i raised the maf a bit towrds the top but i noticed that i cant go higher the 255 and when it was stock the highest was 319
Old May 28, 2010 | 11:25 PM
  #422
RoadSpike's Avatar
Thats probably my fault with the scaling its set to unit8 which is different than stock.
I noticed though that my attempt at uncapping the load wasn't quite right. The value we changed is a cap but i'm not sure to what. Let me research the load cap a little more.
Old May 28, 2010 | 11:38 PM
  #423
link62's Avatar
ok cool so was the fuel uncap correct also?
Old May 29, 2010 | 12:01 AM
  #424
RoadSpike's Avatar
I think so it looks like it went above 14.33 ipw so probably did it right but i want to be sure
Old May 29, 2010 | 12:12 AM
  #425
RoadSpike's Avatar
Ok there is a crap ton of code to go through for the MAF to IPW but i'm pretty sure of two things.
1) The fuel cap was correct
2) the load cap was off just by a few bytes doing a very simliar thing but not the right location.
Link set your load cap back to the original 0x2ab1 setting
Then right click and edit the map and change the address to 245da
It should also be 2ab1 change that to 0x9 and give it another shot
Edit:
BTW if you want you scaling back on the maf scaling thing just set it from unit8 to airflow8 on the top scaling. Mafhz is correct thats the left hand side.
Getting so close to being a total 100% release
Old May 29, 2010 | 10:57 AM
  #426
link62's Avatar
Edit:
i think that did it cause now when i go wot im at least in the 14 afrs so i guess i just need to tune the maf scaling and a few other things and also i think the mdp in the mod list is making my get the code p1400 cause i poped up again when i started the car so i turned it off and gonna see if it pops up again
edit: looking at the logs my max ipw is 21 now also when i convert the maf scaling back i can only see the first number and a few dot on the right side is there a way to enlarge the window?
Old May 29, 2010 | 11:11 AM
  #427
ClixT's Avatar
damn, ive been gone for a month and boom, a lot of new things and im lost lol
anyhow, you guys are awesome.
Old May 29, 2010 | 11:13 AM
  #428
link62's Avatar
haha yea u missed a lot welcome back
Old May 29, 2010 | 11:37 AM
  #429
ClixT's Avatar
thnx link
Old May 29, 2010 | 06:31 PM
  #430
RoadSpike's Avatar
WB ClixT
Awesome hey link it will probably be easier to just up the value for maf size a bit rather than mess with the scaling seems like its just slightly off and your maf scaling is maxing out anyhow.
p1400 hmm?
Fack you know i just noticed in my map sensor table i've screwed up the min and max voltage spots lol. Anyways the ones at this time labled.
1) MAP Test 1: Mid VE Min Voltage
2) MAP Test 2: Low VE Max Voltage
Set them both to 5 volts and the problem should go away :P
Oh another thing you should do is cancel out lean spool yes its somehow enabled but i'm not sure what periphery bit it really is. Probably bit 3 in the FBA but i'm unsure.
Just set the start and stop rpm to something REALLY high like 11000rpm.
Edit:
To enlarge the window just close the program and reopen it it will size it again then.
Old May 29, 2010 | 06:53 PM
  #431
RoadSpike's Avatar
Whew bro you know you hit 95% IDC ?? lol you may not have enough injector left man and will need to get evo stock injectors.
Looking at the knock sum code i don't see anything that really stick out as hey something odd is going on.
So what i think I'll do if get you to load up the knocksum variable, cel flash time, and the current tephra settings variable which should give me an idea whats being set.
Hopefully its nothing big
Knock Sum
MUT00 = 6D1C
MUT01 = 6D1D
Flash time:
MUT02 = 8D02
MUT03 = 8D03
Settings Var:
MUT04 = 8D00
MUT05 = 8D01
Old May 29, 2010 | 07:19 PM
  #432
link62's Avatar
ok map volts fixed and lean spool fix and got the muts in so im ready to test it out now
Really lol my scaling is 375 and i recently bumped it up to 390 to raise my fuel trim closer to 0 but im wondering if my fuel pump isnt pumping enough fuel, cause i have a TRE and not a walbro but claims to be 255lph lol i only got it cause it said not as loud as walbro, but i might get it soon just to have peace of mind lol also i need to get my evo fpr on cause that might help also.
I started the car to move it so my mom can get out of the garage and my knock light went off for a quick second and i was oh great im getting knock at start up also
Old May 29, 2010 | 07:20 PM
  #433
RoadSpike's Avatar
Lol ok probably not knocking there hopefully its something i can find out quickly for you
Already sent you an email but maybe you should copy the low octane fuel map over
Old May 29, 2010 | 07:25 PM
  #434
link62's Avatar
ok cool be back in a bit and lol i just replied back asking if i should but i will now
Old May 29, 2010 | 07:56 PM
  #435
link62's Avatar
ok so i was able to dip down in to the low 13 and and high 12 so getting there
and i forgot to turn mpd on the first time and when i did i got the code again at start up
