Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old May 30, 2010 | 12:05 AM
  #451
link62's Avatar
Originally Posted by RoadSpike
Hey link I noticed when i sent you the 1byte load thing i put in 1.3 as the scaling factor but in the rom its only 1.2.
either fix the scaling factor in evoscan or probably more easily fix the scaling factor in the rom to 1.3 instead of 1.2 so it matches
ok got it
Old May 30, 2010 | 12:14 AM
  #452
RoadSpike's Avatar
Originally Posted by link62
ok got it
Awesome now all we need is more testers lol
Old May 30, 2010 | 10:49 AM
  #453
ClixT's Avatar
hey roadspike, i could do some testing but im not turboed..
also, im lost lol. i forgot pretty much everything.
Old May 30, 2010 | 02:39 PM
  #454
RoadSpike's Avatar
It wont matter if your turbo'ed or not
Just set your maf scaling appropriately and change up the fuel and ignition tables to what you need. Email me I can't remember which email address was yours.
Old May 30, 2010 | 04:14 PM
  #455
link62's Avatar
ok so far no code for the mpd or for the rear o2
Old May 30, 2010 | 04:29 PM
  #456
RoadSpike's Avatar
Sweet we can probably call this a 100% release then?
Perhaps I'll dig up the xml needed for the rear o2 heater circuit later so it can be completely disconnected.
Old May 30, 2010 | 05:15 PM
  #457
link62's Avatar
ok cool and im guessing so
Old May 30, 2010 | 05:30 PM
  #458
ClixT's Avatar
@RS: pm sent =)
so whats new with this?
bigger maps? still the 512kb rom?
Old May 30, 2010 | 05:56 PM
  #459
RoadSpike's Avatar
@RS: pm sent =)
Pretty much any v7 feature than can be enabled is.
Valet mode via tps
Valet mode via fresh ignition
Big maps
Launch Maps
-Control timing and fuel via tps and speed
MDP averaging
Rear 02 simulator
IPW restriction disabled
Load restriction disabled
Alt maps possible
-They can be enabled only at this time via TPS ADC0f isn't found
-Can have its own injector scaling
All maps defined there are many :P
ODBII force pass untested but defined should work its very simple
Old May 31, 2010 | 09:19 AM
  #460
ClixT's Avatar
got ur email but its links rom, is it gonna work with me?
Old May 31, 2010 | 11:22 AM
  #461
RoadSpike's Avatar
Its all stock settings for a lancer 02-04 automatic should be fine. Regardless save a copy of your original rom the full 512kb version.
The only real trouble maker is the timing map and fuel map be careful in that regard.
To really use this right you should have a wideband to test it and adjust the timing and fuel map to suit you
Edit:
To really use them you'll need the read templates as well as the rom you have them right?
Old May 31, 2010 | 01:27 PM
  #462
ClixT's Avatar
Edit:
yup. still have em.
imma tune the map first, which might take me awhile.
Old May 31, 2010 | 02:25 PM
  #463
RoadSpike's Avatar
yup. still have em.
Well i check out the timing and fuel map and compared them against stock.
Looks like the timing map is just slightly lower than stock and the fuel map is lower than stock at high rpm but leaner at very low rpms like 1000-2500 rpm. So it should be pretty safe but still wouldn't run without a wideband.
Old May 31, 2010 | 02:28 PM
  #464
ClixT's Avatar
sucks for not having a WB.
Old May 31, 2010 | 02:33 PM
  #465
link62's Avatar
clixt go buy one now lol
